Created a smart-proxy with the hopes to use it for PXE booting and deployment in remote environment. Install went well and I was able to sync my Centos7 CV from the main server to it with no errors reported. But when deploying a machine its unable to retrieve any packages and also fails looking for squashfs.img as the folder location doesn’t have LiveOS or images folders synced. Local curl to the same locations also return 404, but the same locations on the main server show Packages and other files as expected.
Location Client is looking for: http://(smartproxy)/pulp/repos/Default_Organization/Library/CentOS7_CV/custom/Centos_7/CentOS7_BaseOS//Live_OS/squashfs.img
Local disk location I find the packages:
/var/www/pub/yum/http/repos/Default_Organization/Centos7/CentOS7_CV/custom/Centos_7/CentOS7_BaseOS//var/www/pub/yum/http/repos/Default_Organization/Centos7/CentOS7_CV/custom/Centos_7/CentOS7_BaseOS/
even if I change the url to better match the local path, I still get 404 errors.
I tried snooping around in the httpd configs to try and find where it was looking for the files. This seemed to point to /var/www/pub/yum/http/repos/ where I found all the files, but on the Foreman server that path is empty so I don’t know where it looks for files, my guess is inside /var/lib/pulp as thats the only location with files of the right size, but they appear to be all hash names.
Proxy would communicate where its repo is being published and it would be reachable from the client PXE booting, and from basic curl commands.
Foreman server and the proxy are both 2.3.2
Foreman Versions:
- candlepin-3.1.22-1.el7.noarch
- candlepin-selinux-3.1.22-1.el7.noarch
- foreman-2.3.2-1.el7.noarch
- foreman-cli-2.3.2-1.el7.noarch
- foreman-client-release-2.0.3-1.el7.noarch
- foreman-debug-2.3.2-1.el7.noarch
- foreman-dynflow-sidekiq-2.3.2-1.el7.noarch
- foreman-installer-2.3.2-1.el7.noarch
- foreman-installer-katello-2.3.2-1.el7.noarch
- foreman-libvirt-2.3.2-1.el7.noarch
- foreman-postgresql-2.3.2-1.el7.noarch
- foreman-proxy-2.3.2-1.el7.noarch
- foreman-release-2.3.2-1.el7.noarch
- foreman-selinux-2.3.2-1.el7.noarch
- foreman-service-2.3.2-1.el7.noarch
- foreman-vmware-2.3.2-1.el7.noarch
- katello-3.18.1-1.el7.noarch
- katello-ca-consumer-stwf-katello-01.ad.starwolfhome.com-1.0-1.noarch
- katello-certs-tools-2.7.3-1.el7.noarch
- katello-client-bootstrap-1.7.5-1.el7.noarch
- katello-common-3.18.1-1.el7.noarch
- katello-debug-3.18.1-1.el7.noarch
- katello-default-ca-1.0-1.noarch
- katello-repos-3.18.1-1.el7.noarch
- katello-selinux-3.5.0-1.el7.noarch
- katello-server-ca-1.0-1.noarch
- pulp-client-1.0-1.noarch
- pulp-deb-plugins-1.10.2-1.el7.noarch
- pulp-docker-plugins-3.2.8-1.el7.noarch
- pulp-katello-1.0.3-1.el7.noarch
- pulp-puppet-plugins-2.21.5-1.el7.noarch
- pulp-puppet-tools-2.21.5-1.el7.noarch
- pulp-rpm-plugins-2.21.5-1.el7.noarch
- pulp-selinux-2.21.5-1.el7.noarch
- pulp-server-2.21.5-1.el7.noarch
- pulpcore-selinux-1.2.3-2.el7.x86_64
- puppet-foreman_scap_client-0.4.0-1.el7.noarch
- python-gofer-qpid-2.12.5-3.el7.noarch
- python-pulp-common-2.21.5-1.el7.noarch
- python-pulp-deb-common-1.10.2-1.el7.noarch
- python-pulp-docker-common-3.2.8-1.el7.noarch
- python-pulp-oid_validation-2.21.5-1.el7.noarch
- python-pulp-puppet-common-2.21.5-1.el7.noarch
- python-pulp-repoauth-2.21.5-1.el7.noarch
- python-pulp-rpm-common-2.21.5-1.el7.noarch
- python-pulp-streamer-2.21.5-1.el7.noarch
- python2-qpid-1.37.0-5.el7.noarch
- python2-qpid-proton-0.33.0-1.el7.x86_64
- python2-qpid-qmf-1.39.0-1.el7.x86_64
- python3-pulp-2to3-migration-0.6.0-2.el7.noarch
- python3-pulp-certguard-1.0.3-1.el7.noarch
- python3-pulp-container-2.1.0-1.el7.noarch
- python3-pulp-deb-2.7.0-1.el7.noarch
- python3-pulp-file-1.3.0-1.el7.noarch
- python3-pulp-rpm-3.7.0-1.el7.noarch
- python3-pulpcore-3.7.3-1.el7.noarch
- qpid-cpp-client-1.39.0-1.el7.x86_64
- qpid-cpp-client-devel-1.39.0-1.el7.x86_64
- qpid-cpp-server-1.39.0-1.el7.x86_64
- qpid-cpp-server-linearstore-1.39.0-1.el7.x86_64
- qpid-dispatch-router-1.14.0-1.el7.x86_64
- qpid-proton-c-0.33.0-1.el7.x86_64
- qpid-qmf-1.39.0-1.el7.x86_64
- qpid-tools-1.39.0-1.el7.noarch
- rubygem-foreman_maintain-0.7.1-1.el7.noarch
- rubygem-foreman_scap_client-0.4.6-2.el7.noarch
- stwf-katello-01.ad.starwolfhome.com-apache-1.0-1.noarch
- stwf-katello-01.ad.starwolfhome.com-foreman-client-1.0-1.noarch
- stwf-katello-01.ad.starwolfhome.com-foreman-proxy-1.0-1.noarch
- stwf-katello-01.ad.starwolfhome.com-foreman-proxy-client-1.0-1.noarch
- stwf-katello-01.ad.starwolfhome.com-puppet-client-1.0-1.noarch
- stwf-katello-01.ad.starwolfhome.com-qpid-broker-1.0-1.noarch
- stwf-katello-01.ad.starwolfhome.com-qpid-client-cert-1.0-1.noarch
- stwf-katello-01.ad.starwolfhome.com-qpid-router-client-1.0-1.noarch
- stwf-katello-01.ad.starwolfhome.com-qpid-router-server-1.0-1.noarch
- tfm-rubygem-actioncable-6.0.3.4-1.el7.noarch
- tfm-rubygem-actionmailbox-6.0.3.4-1.el7.noarch
- tfm-rubygem-actionmailer-6.0.3.4-1.el7.noarch
- tfm-rubygem-actionpack-6.0.3.4-1.el7.noarch
- tfm-rubygem-actiontext-6.0.3.4-1.el7.noarch
- tfm-rubygem-actionview-6.0.3.4-1.el7.noarch
- tfm-rubygem-activejob-6.0.3.4-1.el7.noarch
- tfm-rubygem-activemodel-6.0.3.4-1.el7.noarch
- tfm-rubygem-activerecord-6.0.3.4-1.el7.noarch
- tfm-rubygem-activerecord-import-1.0.0-2.el7.noarch
- tfm-rubygem-activerecord-session_store-1.1.1-4.el7.noarch
- tfm-rubygem-activestorage-6.0.3.4-1.el7.noarch
- tfm-rubygem-activesupport-6.0.3.4-1.el7.noarch
- tfm-rubygem-addressable-2.6.0-2.el7.noarch
- tfm-rubygem-algebrick-0.7.3-7.el7.noarch
- tfm-rubygem-amazing_print-1.1.0-1.el7.noarch
- tfm-rubygem-ancestry-3.0.7-1.el7.noarch
- tfm-rubygem-anemone-0.7.2-17.el7.noarch
- tfm-rubygem-angular-rails-templates-1.1.0-1.el7.noarch
- tfm-rubygem-ansi-1.5.0-2.el7.noarch
- tfm-rubygem-apipie-bindings-0.4.0-1.el7.noarch
- tfm-rubygem-apipie-dsl-2.3.0-1.el7.noarch
- tfm-rubygem-apipie-params-0.0.5-4.el7.noarch
- tfm-rubygem-apipie-rails-0.5.17-3.el7.noarch
- tfm-rubygem-audited-4.9.0-3.el7.noarch
- tfm-rubygem-bcrypt-3.1.12-3.el7.x86_64
- tfm-rubygem-builder-3.2.4-1.el7.noarch
- tfm-rubygem-bundler_ext-0.4.1-5.el7.noarch
- tfm-rubygem-clamp-1.1.2-6.el7.noarch
- tfm-rubygem-concurrent-ruby-1.1.6-2.el7.noarch
- tfm-rubygem-concurrent-ruby-edge-0.6.0-2.fm2_1.el7.noarch
- tfm-rubygem-connection_pool-2.2.2-2.el7.noarch
- tfm-rubygem-crass-1.0.6-1.el7.noarch
- tfm-rubygem-css_parser-1.4.7-4.el7.noarch
- tfm-rubygem-daemons-1.2.3-6.el7.noarch
- tfm-rubygem-deacon-1.0.0-4.el7.noarch
- tfm-rubygem-deep_cloneable-3.0.0-3.el7.noarch
- tfm-rubygem-deface-1.5.3-2.el7.noarch
- tfm-rubygem-domain_name-0.5.20160310-4.el7.noarch
- tfm-rubygem-dynflow-1.4.7-1.fm2_3.el7.noarch
- tfm-rubygem-erubi-1.9.0-1.el7.noarch
- tfm-rubygem-excon-0.76.0-1.el7.noarch
- tfm-rubygem-facter-2.4.0-7.el7.x86_64
- tfm-rubygem-faraday-0.17.3-1.el7.noarch
- tfm-rubygem-fast_gettext-1.4.1-4.el7.noarch
- tfm-rubygem-ffi-1.12.2-1.el7.x86_64
- tfm-rubygem-fog-core-2.1.0-3.el7.noarch
- tfm-rubygem-fog-json-1.2.0-3.el7.noarch
- tfm-rubygem-fog-libvirt-0.7.0-2.el7.noarch
- tfm-rubygem-fog-vsphere-3.4.0-1.el7.noarch
- tfm-rubygem-fog-xml-0.1.2-8.el7.noarch
- tfm-rubygem-foreman-tasks-3.0.3-1.fm2_3.el7.noarch
- tfm-rubygem-foreman-tasks-core-0.3.4-1.fm2_1.el7.noarch
- tfm-rubygem-foreman_ansible-6.1.1-1.fm2_3.el7.noarch
- tfm-rubygem-foreman_ansible_core-4.0.0-1.fm2_3.el7.noarch
- tfm-rubygem-foreman_discovery-16.3.4-1.fm2_3.el7.noarch
- tfm-rubygem-foreman_openscap-4.1.2-1.fm2_3.el7.noarch
- tfm-rubygem-foreman_remote_execution-4.2.2-1.fm2_3.el7.noarch
- tfm-rubygem-foreman_remote_execution_core-1.4.0-1.el7.noarch
- tfm-rubygem-formatador-0.2.1-12.el7.noarch
- tfm-rubygem-friendly_id-5.3.0-1.el7.noarch
- tfm-rubygem-fx-0.5.0-1.el7.noarch
- tfm-rubygem-get_process_mem-0.2.1-4.el7.noarch
- tfm-rubygem-gettext_i18n_rails-1.8.0-2.el7.noarch
- tfm-rubygem-gitlab-sidekiq-fetcher-0.6.0-1.el7.noarch
- tfm-rubygem-globalid-0.4.2-1.el7.noarch
- tfm-rubygem-graphql-1.8.14-2.el7.noarch
- tfm-rubygem-graphql-batch-0.3.10-2.el7.noarch
- tfm-rubygem-gssapi-1.2.0-7.el7.noarch
- tfm-rubygem-hammer_cli-2.3.0-1.el7.noarch
- tfm-rubygem-hammer_cli_foreman-2.3.0-1.el7.noarch
- tfm-rubygem-hammer_cli_foreman_bootdisk-0.3.0-1.el7.noarch
- tfm-rubygem-hammer_cli_foreman_docker-0.0.7-1.el7.noarch
- tfm-rubygem-hammer_cli_foreman_tasks-0.0.15-1.fm2_2.el7.noarch
- tfm-rubygem-hammer_cli_katello-0.24.2-1.el7.noarch
- tfm-rubygem-hashie-3.6.0-2.el7.noarch
- tfm-rubygem-highline-1.7.8-5.el7.noarch
- tfm-rubygem-http-cookie-1.0.2-4.el7.noarch
- tfm-rubygem-i18n-1.8.2-1.el7.noarch
- tfm-rubygem-ipaddress-0.8.0-12.el7.noarch
- tfm-rubygem-jwt-2.2.1-2.el7.noarch
- tfm-rubygem-kafo-6.1.2-1.el7.noarch
- tfm-rubygem-kafo_parsers-1.1.0-3.el7.noarch
- tfm-rubygem-kafo_wizards-0.0.1-4.el7.noarch
- tfm-rubygem-katello-3.18.1-1.el7.noarch
- tfm-rubygem-ldap_fluff-0.4.7-5.el7.noarch
- tfm-rubygem-little-plugger-1.1.4-2.el7.noarch
- tfm-rubygem-locale-2.0.9-14.el7.noarch
- tfm-rubygem-logging-2.3.0-1.el7.noarch
- tfm-rubygem-loofah-2.4.0-1.el7.noarch
- tfm-rubygem-mail-2.7.1-1.el7.noarch
- tfm-rubygem-marcel-0.3.3-1.el7.noarch
- tfm-rubygem-method_source-0.9.2-2.el7.noarch
- tfm-rubygem-mime-types-3.2.2-4.el7.noarch
- tfm-rubygem-mime-types-data-3.2018.0812-4.el7.noarch
- tfm-rubygem-mimemagic-0.3.5-1.el7.noarch
- tfm-rubygem-mini_mime-1.0.2-1.el7.noarch
- tfm-rubygem-mini_portile2-2.4.0-1.el7.noarch
- tfm-rubygem-multi_json-1.14.1-2.el7.noarch
- tfm-rubygem-multipart-post-2.0.0-2.el7.noarch
- tfm-rubygem-mustermann-1.0.2-4.el7.noarch
- tfm-rubygem-net-ldap-0.16.1-2.el7.noarch
- tfm-rubygem-net-ping-2.0.1-4.el7.noarch
- tfm-rubygem-net-scp-1.2.1-4.el7.noarch
- tfm-rubygem-net-ssh-4.2.0-2.el7.noarch
- tfm-rubygem-netrc-0.11.0-5.el7.noarch
- tfm-rubygem-nio4r-2.5.4-1.el7.x86_64
- tfm-rubygem-nokogiri-1.10.9-1.el7.x86_64
- tfm-rubygem-oauth-0.5.4-4.el7.noarch
- tfm-rubygem-openscap-0.4.9-4.el7.noarch
- tfm-rubygem-optimist-3.0.0-2.el7.noarch
- tfm-rubygem-parse-cron-0.1.4-4.fm2_1.el7.noarch
- tfm-rubygem-pg-1.1.4-3.el7.x86_64
- tfm-rubygem-polyglot-0.3.5-2.el7.noarch
- tfm-rubygem-powerbar-2.0.1-2.el7.noarch
- tfm-rubygem-promise.rb-0.7.4-2.el7.noarch
- tfm-rubygem-public_suffix-3.0.3-2.el7.noarch
- tfm-rubygem-pulp_2to3_migration_client-0.5.0-1.el7.noarch
- tfm-rubygem-pulp_ansible_client-0.4.2-1.el7.noarch
- tfm-rubygem-pulp_certguard_client-1.0.3-1.el7.noarch
- tfm-rubygem-pulp_container_client-2.1.0-1.el7.noarch
- tfm-rubygem-pulp_deb_client-2.7.0-1.el7.noarch
- tfm-rubygem-pulp_file_client-1.3.0-1.el7.noarch
- tfm-rubygem-pulp_rpm_client-3.7.0-1.el7.noarch
- tfm-rubygem-pulpcore_client-3.7.1-1.el7.noarch
- tfm-rubygem-puma-4.3.6-1.el7.x86_64
- tfm-rubygem-puma-plugin-systemd-0.1.5-1.el7.noarch
- tfm-rubygem-rabl-0.14.3-1.el7.noarch
- tfm-rubygem-rack-2.2.3-1.el7.noarch
- tfm-rubygem-rack-cors-1.0.2-2.el7.noarch
- tfm-rubygem-rack-jsonp-1.3.1-9.el7.noarch
- tfm-rubygem-rack-protection-2.0.3-4.el7.noarch
- tfm-rubygem-rack-test-1.1.0-4.el7.noarch
- tfm-rubygem-rails-6.0.3.4-1.el7.noarch
- tfm-rubygem-rails-dom-testing-2.0.3-6.el7.noarch
- tfm-rubygem-rails-html-sanitizer-1.3.0-1.el7.noarch
- tfm-rubygem-rails-i18n-6.0.0-2.el7.noarch
- tfm-rubygem-railties-6.0.3.4-1.el7.noarch
- tfm-rubygem-rainbow-2.2.1-3.el7.noarch
- tfm-rubygem-rb-inotify-0.9.7-5.el7.noarch
- tfm-rubygem-rbvmomi-2.2.0-3.el7.noarch
- tfm-rubygem-record_tag_helper-1.0.1-3.el7.noarch
- tfm-rubygem-redfish_client-0.5.2-1.el7.noarch
- tfm-rubygem-redis-4.1.2-2.el7.noarch
- tfm-rubygem-responders-3.0.0-3.el7.noarch
- tfm-rubygem-rest-client-2.0.2-3.el7.noarch
- tfm-rubygem-rkerberos-0.1.5-19.el7.x86_64
- tfm-rubygem-roadie-3.4.0-3.el7.noarch
- tfm-rubygem-roadie-rails-2.1.1-2.el7.noarch
- tfm-rubygem-robotex-1.0.0-21.el7.noarch
- tfm-rubygem-rsec-0.4.3-4.el7.noarch
- tfm-rubygem-ruby-libvirt-0.7.1-1.el7.x86_64
- tfm-rubygem-ruby2ruby-2.4.2-3.el7.noarch
- tfm-rubygem-ruby_parser-3.10.1-3.el7.noarch
- tfm-rubygem-rubyipmi-0.10.0-6.el7.noarch
- tfm-rubygem-runcible-2.13.1-1.el7.noarch
- tfm-rubygem-safemode-1.3.6-1.el7.noarch
- tfm-rubygem-scoped_search-4.1.9-1.el7.noarch
- tfm-rubygem-sd_notify-0.1.0-1.el7.noarch
- tfm-rubygem-secure_headers-6.3.0-2.el7.noarch
- tfm-rubygem-sequel-5.7.1-3.el7.noarch
- tfm-rubygem-server_sent_events-0.1.2-1.el7.noarch
- tfm-rubygem-sexp_processor-4.10.0-6.el7.noarch
- tfm-rubygem-sidekiq-5.2.7-3.el7.noarch
- tfm-rubygem-sinatra-2.0.3-4.el7.noarch
- tfm-rubygem-smart_proxy_ansible-3.0.1-6.fm2_2.el7.noarch
- tfm-rubygem-smart_proxy_discovery-1.0.5-6.fm2_2.el7.noarch
- tfm-rubygem-smart_proxy_dynflow-0.3.0-2.fm2_3.el7.noarch
- tfm-rubygem-smart_proxy_dynflow_core-0.3.2-1.fm2_3.el7.noarch
- tfm-rubygem-smart_proxy_openscap-0.7.4-1.fm2_2.el7.noarch
- tfm-rubygem-smart_proxy_pulp-2.1.0-3.fm2_2.el7.noarch
- tfm-rubygem-smart_proxy_remote_execution_ssh-0.3.1-1.fm2_3.el7.noarch
- tfm-rubygem-sprockets-4.0.2-1.el7.noarch
- tfm-rubygem-sprockets-rails-3.2.1-6.el7.noarch
- tfm-rubygem-sqlite3-1.3.13-6.el7.x86_64
- tfm-rubygem-sshkey-1.9.0-4.el7.noarch
- tfm-rubygem-statsd-instrument-2.1.4-3.el7.noarch
- tfm-rubygem-stomp-1.4.9-1.el7.noarch
- tfm-rubygem-thor-1.0.1-2.el7.noarch
- tfm-rubygem-thread_safe-0.3.6-5.el7.noarch
- tfm-rubygem-tilt-2.0.8-4.el7.noarch
- tfm-rubygem-tzinfo-1.2.6-1.el7.noarch
- tfm-rubygem-unf-0.1.3-8.el7.noarch
- tfm-rubygem-unf_ext-0.0.7.2-3.el7.x86_64
- tfm-rubygem-unicode-0.4.4.4-3.el7.x86_64
- tfm-rubygem-unicode-display_width-1.0.5-4.el7.noarch
- tfm-rubygem-validates_lengths_from_database-0.5.0-7.el7.noarch
- tfm-rubygem-webpack-rails-0.9.8-5.el7.noarch
- tfm-rubygem-websocket-driver-0.7.1-1.el7.x86_64
- tfm-rubygem-websocket-extensions-0.1.5-1.el7.noarch
- tfm-rubygem-will_paginate-3.1.7-3.el7.noarch
- tfm-rubygem-xmlrpc-0.3.0-2.el7.noarch
- tfm-rubygem-zeitwerk-2.2.2-1.el7.noarch
- tfm-runtime-6.1-4.el7.x86_64
Proxy Versions:
Ansible
Version
3.0.1
Discovery
Version
1.0.5
Dynflow
Version
0.3.0
HTTPBoot
Version
2.3.2
Openscap
Version
0.7.4
Spool errors
None found
Pulp node
Version
2.1.0
Pulp server version
2.21.5
Database connection
Messaging connection
Workers
4
Supported Content Types
- deb
- docker
- file
- puppet
- yum
Registration
Version
2.3.2
SSH
Version
0.3.1
TFTP
Version
2.3.2
TFTP server
false
Templates
Version
2.3.2
Both are:
CentOS Linux release 7.9.2009 (Core)
I couldn’t find any errors in the apache logs, beyond the 404 error.
