Smart-proxy-openscap-send issues uploading content to Foreman
Problem: I’ve managed to get Foreman to execute a SCAP scan against a host successfully, the scan runs, the report is generated, foreman-proxy receives the report file and places it in /var/spool/foreman-proxy/openscap/arf/hostname/1/etc…
However, the resulting report never makes it into the Foreman interface.
Expected outcome: Results in Foreman
Here’s the versioning info:
Foreman version 1.23.0-1 running on RHEL 7.7
rubygem-smart_proxy_openscap-0.7.2-1
Extra details:
In /var/log/foreman-proxy/proxy.log, I see this message:
2019-11-08T09:30:02  [D] Executing: smart-proxy-arf-json /var/tmp/bc737139-d1bf-4909-9e7a-c5d3d41e6346-hostname-1-1573212957-20191108-17454-5joarn /var/tmp/bc737139-d1bf-4909-9e7a-c5d3d41e6346-hostname-1-1573212957-json-20191108-17454-4ndqdj
2019-11-08T09:30:05  [E] smart-proxy-openscap-send failed to upload Compliance report for hostname, generated on 2019-11-08 06:35:57 -0500. Cause: 500 "Internal Server Error"
In /var/log/foreman/production.log, I get see this:
2019-11-08T09:54:32 [I|app|d2defedf] Started POST "/api/v2/compliance/arf_reports/hostname/1/1573212957" for 10.115.18.198 at 2019-11-08 09:54:32 -0500
2019-11-08T09:54:33 [I|app|d2defedf] Processing by Api::V2::Compliance::ArfReportsController#create as JSON
2019-11-08T09:54:33 [I|app|d2defedf]   Parameters: {"logs"=>"[FILTERED]", "digest"=>"0a21c59e718e85e86701e095d142e4202df587840c527086879f06818b938381", "metrics"=>{"passed"=>101, "failed"=>46, "othered"=>2}, "openscap_proxy_name"=>nil, "openscap_proxy_url"=>nil, "apiv"=>"v2", "cname"=>"hostname", "policy_id"=>"1", "date"=>"1573212957", "arf_report"=>{"logs"=>"[FILTERED]", "digest"=>"0a21c59e718e85e86701e095d142e4202df587840c527086879f06818b938381", "metrics"=>{"passed"=>101, "failed"=>46, "othered"=>2}, "openscap_proxy_name"=>nil, "openscap_proxy_url"=>nil}}
2019-11-08T09:54:33 [W|app|d2defedf] Action failed
NoMethodError: undefined method `[]=' for nil:NilClass
/usr/share/foreman/app/controllers/api/base_controller.rb:237:in `block in assign_lone_taxonomies'
/usr/share/foreman/app/controllers/api/base_controller.rb:231:in `each'
/usr/share/foreman/app/controllers/api/base_controller.rb:231:in `assign_lone_taxonomies'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:426:in `block in make_lambda'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:179:in `block (2 levels) in halting_and_conditional'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/callbacks.rb:34:in `block (2 levels) in <module:Callbacks>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:180:in `block in halting_and_conditional'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:513:in `block in invoke_before'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:513:in `each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:513:in `invoke_before'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:107:in `block in run_callbacks'
/opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.7.1/lib/audited/sweeper.rb:14:in `around'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/callbacks.rb:41:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rescue.rb:22:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/base.rb:134:in `process'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/rendering.rb:32:in `process'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal.rb:191:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal.rb:252:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/mapper.rb:48:in `serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:35:in `each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:35:in `serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:840:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/static_dispatcher.rb:65:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/extractor/recorder.rb:137:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/tempfile_reaper.rb:15:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/etag.rb:25:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/conditional_get.rb:38:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/head.rb:12:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:232:in `context'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:226:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:98:in `run_callbacks'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/rack/logger.rb:38:in `call_app'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/rack/logger.rb:28:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/method_override.rb:22:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/runtime.rb:22:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/sendfile.rb:111:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-6.0.0/lib/secure_headers/middleware.rb:13:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/urlmap.rb:68:in `block in call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `call'
2019-11-08T09:54:33 [I|app|d2defedf]   Rendering api/v2/errors/custom_error.json.rabl within api/v2/layouts/error_layout
2019-11-08T09:54:33 [I|app|d2defedf]   Rendered api/v2/errors/custom_error.json.rabl within api/v2/layouts/error_layout (0.4ms)
2019-11-08T09:54:33 [I|app|d2defedf] Completed 500 Internal Server Error in 106ms (Views: 1.0ms | ActiveRecord: 0.8ms)
I’m noticing that openscap_proxy_name and openscap_proxy_url are both nil in the output. I don’t know where those are configured, however.
Perhaps you are hitting: Bug #28010: 500 Error uploading reports from proxy - OpenSCAP - Foreman
I just gave that a try, and it doesn’t seemed to have helped I have teh same error in the log file. That fix in the bug report may still help, but I’m wondering if the fact that the openscap_proxy_name and openscap_proxy_url being ‘nil’ are part of the issue. Do you know where that is being set from? It’s possible I’m missing an option somewhere, but I can’t find where those are.
I’ll also clear out the old arf report and generate a new one just in case.
Ok, I do have the proxy_name and proxy_urls being sent only when I run the foreman_scap_client on the client machine. If I run smart-proxy-openscap-send on the foreman server to get the proxy to try again, that’s when it ends up as nil. I still have the same error though.
thank you for reporting this. Based on the stack trace you provided, it seems to me there is a problem on the Foreman side. It looks like a valid bug, I am spinning up 1.23 to see if I can reproduce. I’ll report back with the results of my investigation.
Thanks.
I found out this is a bug. Simple workaround for now is to have at least 2 organizations and locations.
Proposed fix:
Yup, that little code change in the bug report did work, I got the report uploaded. I can also do the organizations change as well.
I confirm the patch is working here too. Thanks
