Smart_proxy, run with with custom ruby installation
Check its log file, /var/log/foreman-proxy/proxy.log? Also try switching
the daemonize option in settings.yml to false so it remains in the
foreground so you can monitor it.
··· On 10/05/16 18:38, Julio Guevara wrote: > Hi Foreman users, > > I'm having issues trying to make smart-proxy use a custom ruby > installation where i have puppet and augeas gem already installed. > So by default smart_proxy tries to run with the default ruby > installation, but i already have a pre-existent installation with all > gems needed. > > I changed the shebang on the /usr/share/foreman-proxy/bin/smart-proxy > but this causes the script to do nothing. I verified files permissions, > even running the script with user different than foreman-proxy with no > success. Any suggestion?
Dominic Cleal
dominic@cleal.org
