when i’m using Smart Proxy Upgrade Playbook it will not Update Katello repo
This is from Remote Excecution Preview:
- hosts: all
vars:
target_version: "4.12"
tasks:
- name: Gather the rpm package facts
package_facts:
manager: auto
- name: Fail if the target server is a Foreman server
fail:
msg: "This playbook cannot be executed on a Foreman server. Use only on a Smart Proxy server."
when: "'foreman' in ansible_facts.packages"
- name: Install foreman release gpg key
rpm_key:
state: present
key: http://yum.theforeman.org/releases/{{ target_version }}/RPM-GPG-KEY-foreman
when: target_version != "nightly"
- name: Update foreman repositories
package:
name: https://yum.theforeman.org/releases/{{ target_version }}/el{{ ansible_distribution_major_version }}/{{ ansible_architecture }}/foreman-release.rpm
state: installed
- name: Clean yum metadata
command: yum clean all
- name: Update all packages
package:
state: latest
- name: Run the installer
shell: foreman-installer
As you can see, it will only update foreman repo
When you going to check in Katello > Administer > About
it only shows foreman Version
If you look at katello > Infrastructure > Smart Proxies
It’s showing status > green
when you look at a smart proxy, it only shows foreman Version
According to Upgrade docs, i need to also Update Katello Repo
https://docs.theforeman.org/3.10/Upgrading_Project/index-katello.html#upgrading_smart-proxy_server_upgrading-connected
So we need to manually update Katello Repo on Smartproxies?
Or am i missing something
I’m on Katello 4.12.1 fully upgraded
greetings
Dominik
