We have upgraded foreman and foreman proxy from 2.3.5 to 2.4.1 using our puppet agents and theforeman puppet modules, the foreman upgrade went successful without issues, the db migration and seed went well as well, however after upgrading the foreman proxy, the puppet agent is now throwing the following error:
Error: /Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[smartproxy1.domain.tld]: Could not evaluate: Error making GET request to Foreman at https://foreman.domain.tld/api/v2/smart_proxies: Response: 401 Unauthorized: Often this is caused by invalid Oauth credentials
I have checked the oauth key and secret which we are passing them through hiera to the foreman server and foreman proxies as follow:
foreman_proxy.yaml:
profiles::foreman::smart_proxy::parameters:
version: '2.4.1'
trusted_hosts:
- 'smartproxy1.domain.tld'
- 'smartproxy2.domain.tld'
- 'smartproxy3.domain.tld'
- 'smartproxy4.domain.tld'
foreman_base_url: 'https://foreman.domain.tld'
oauth_consumer_key: aaabbbccc
oauth_consumer_secret: xxxyyyzzz
puppetca_provider: 'puppetca_hostname_whitelisting'
registration: false
The puppet class profiles::foreman::smart_proxy passes the parameters as follow:
class{ '::foreman_proxy' :
* => $parameters,
foreman.yaml:
profiles::foreman::parameters:
initial_admin_username: 'admin'
initial_admin_password: redacted
initial_admin_first_name: redacted
initial_admin_last_name: redacted
initial_admin_email: redacted
db_manage: false
email_delivery_method: 'smtp'
email_smtp_address: redacted
email_smtp_port: 25
email_smtp_domain: redacted
foreman_url: 'https://foreman.domain.tld'
unattended: true
unattended_url: 'http://foreman.domain.tld'
serveraliases:
- 'foreman.domain.tld'
ssl: false
version: '2.4.1'
plugin_version: 'latest'
db_host: redacted
db_port: 5432
db_database : 'foreman'
db_username: redacted
db_password: redacted
db_sslmode: 'UNSET'
db_manage_rake: false
server_port: 21002
client_ssl_ca: '/etc/puppetlabs/puppet/ssl/certs/ca.pem'
client_ssl_cert: '/etc/puppetlabs/puppet/ssl/certs/foreman_proxy_client.pem'
client_ssl_key: '/etc/puppetlabs/puppet/ssl/private_keys/foreman_proxy_client.pem'
ipa_manage_sssd: false
websockets_ssl_key: '/etc/puppetlabs/puppet/ssl/private_keys/foreman_websockets.pem'
websockets_ssl_cert: '/etc/puppetlabs/puppet/ssl/certs/foreman_websockets.pem'
logging_level: 'info'
logging_type: 'file'
logging_layout: 'json'
jobs_manage_service: false
The puppet class profiles::foreman is loading the parameters as follow:
class { '::foreman' :
* => $parameters,
I have set the logging to Debug and this is what I can see in the foreman production.log file:
{"logger":"app","timestamp":"2023-06-06T10:56:50.201081-05:00","level":"INFO","message":"Started GET \"/api/v2/smart_proxies?search=name%3D%22smartproxy1.domain.tld%22\" for 192.168.0.10 at 2023-06-06 10:56:50 -0500","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.204476-05:00","level":"INFO","message":"Processing by Api::V2::SmartProxiesController#index as JSON","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.204707-05:00","level":"INFO","message":" Parameters: {\"search\"=\u003e\"name=\\\"smartproxy1.domain.tld\\\"\", \"apiv\"=\u003e\"v2\", \"smart_proxy\"=\u003e{}}","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.205169-05:00","level":"DEBUG","message":"Cache read: settings/failed_login_attempts_limit","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.246558-05:00","level":"DEBUG","message":"Cache fetch_hit: settings/failed_login_attempts_limit","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.246824-05:00","level":"DEBUG","message":"Cache read: failed_login_192.168.0.10","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.247207-05:00","level":"DEBUG","message":"Cache fetch_hit: failed_login_192.168.0.10","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.247422-05:00","level":"DEBUG","message":"Cache read: settings/authorize_login_delegation","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.247725-05:00","level":"DEBUG","message":"Cache fetch_hit: settings/authorize_login_delegation","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.247986-05:00","level":"DEBUG","message":"Cache read: settings/oauth_active","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.248272-05:00","level":"DEBUG","message":"Cache generate: settings/oauth_active","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.250723-05:00","level":"DEBUG","message":"Cache write: settings/oauth_active","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.251255-05:00","level":"DEBUG","message":"Cache read: settings/oauth_consumer_key","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.292769-05:00","level":"DEBUG","message":"Cache fetch_hit: settings/oauth_consumer_key","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.293025-05:00","level":"DEBUG","message":"Cache read: settings/oauth_consumer_secret","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.293390-05:00","level":"DEBUG","message":"Cache fetch_hit: settings/oauth_consumer_secret","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.294295-05:00","level":"WARN","message":"OAuth signature verification failed.","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.294512-05:00","level":"WARN","message":"SSO failed","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.294655-05:00","level":"DEBUG","message":"Cache read: failed_login_192.168.0.10","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.294851-05:00","level":"DEBUG","message":"Cache fetch_hit: failed_login_192.168.0.10","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.295098-05:00","level":"DEBUG","message":"Cache write: failed_login_192.168.0.10 ({:expires_in=\u003e5 minutes})","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.297129-05:00","level":"INFO","message":" Rendering api/v2/errors/unauthorized.json.rabl within api/v2/layouts/error_layout","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.298224-05:00","level":"INFO","message":" Rendered api/v2/errors/unauthorized.json.rabl within api/v2/layouts/error_layout (Duration: 0.9ms | Allocations: 339)","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.298886-05:00","level":"INFO","message":"Filter chain halted as :authorize rendered or redirected","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
{"logger":"app","timestamp":"2023-06-06T10:56:50.299145-05:00","level":"INFO","message":"Completed 401 Unauthorized in 94ms (Views: 3.3ms | ActiveRecord: 0.9ms | Allocations: 7632)","mdc":{"remote_ip":"192.168.0.10","request":"1cd7d91e-637b-4d94-b21f-6e5703175835","session":"1cd7d91e-637b-4d94-b21f-6e5703175835"},"ndc":[]}
I have also enabled httpd forensics module to validate if the right oauth keys are being sent in the headers which they look to be the same:
+117875:647f5742:8|GET /api/v2/**smart_proxies**?search=name%253D%2522smartproxy1.domain.tld%2522 HTTP/1.1|Accept:application/json|Content-Type:application/json|Foreman_user:admin|Accept-Encoding:gzip;q=1.0,deflate;q=0.6,identity;q=0.3|User-Agent:OAuth gem v0.5.1|Authorization:OAuth oauth_consumer_key="aaabbbccc", oauth_nonce="redacted_value", oauth_signature="redacted_value", oauth_signature_method="HMAC-SHA1", oauth_timestamp="1686067010", oauth_version="1.0"|Connection:close|Host:foreman.domain.tld|X-Forwarded-For:192.168.0.10|X-Forwarded-Proto:https|X-TLS-Name:TLS13-CHACHA20-POLY1305-SHA256|X-TLS-Version:TLSv1.3|X-TLS-Bits:256
I am not sure why the Foreman_smartproxy function fails to make the API call to foreman if the oauth keys are the same in both setups (foreman and foreman_proxy)
CentOS 7
The puppet modules version are as follow:
mod theforeman/foreman_proxy => 17.1.1
mod theforeman/foreman => 16.1.0
