Snippet for creating users when provisioning vm
Hello.
I’m a bit new to foreman and I don’t understand how to create a specific user when provisionning a linux os .
I want to create a user “ansible” with a specifi dsa key and uid/gid
But how to create a snippet /user isn’t very clear for me
1.22.1-1.el7
1.22.1-1.el7
logs
There are already two snippets you can utilize or use as inspiration.
create_users creates user based on the owner of the host.
remote_execution_ssh_keys creates a user based on the settings for the Remote Execution / Ansible Plugin including sudo rules.
In the most cases the last one is enough and you only have to adjust the settings in Foreman, but for the specific uid/gid you will have to adjust it.
Best way to do this would be upstream , but to change it only locally copy the snippet and the template which should include it and in the template change the name of the snippet accordingly.
I’m not really a ruby dev, so it’s a bit difficult for me
