We use Intel NUCs, the latest models no longer support legacy bios, so I need to get UEFI boot working for discovery and provisioning. I am trying with pxegrub2_discovery template
I only have the below problem with UEFI boot, legacy pxe (PXELinux global default) discovery is working fine
The discovery image netboots ok, but when it comes to the point where it prompts for the network configuration, and I let it timeout to automatically configure via DHCP it fails to find a suitable interface and does not get a lease
I get the following error on the console log
fdi /usr/bin/discovery-register[2414] Registering host at (https://foreman)
fdi /usr/bin/discovery-register[2414] Could not retrieve fact=‘ipaddress’, resolution=‘anonymous’ : Could not execute ‘host fdi’ : command not found
fdi /usr/bin/discovery-register[2414] Could not send facts to server: getaddrinfo: Name or service not known
if I monitor using wireshark for DHCP/BOOTP I see no requests coming from the discovery image
however if I choose DHCP from the menu and just hit enter through all the options it gets an address fine
Discovery image requests dhcp address when UEFI booting Foreman and Proxy versions:
Foreman 1.17.3
Discovery v3.4.4 image Foreman and Proxy plugin versions:
DNS plugin 1.17.3
Discovery plugin 1.0.3
Wait a minute, when you netboot FDI it does not ask anything, it just registers. FDI looks for “IPAPPEND” kernel command line added by PXELinux or Grub2 template and then it just goes on. Not sure what kind of workflow this is.
Quick google finds that this is a failure coming from facter when package named net-tools is not installed. But this package is present in discovery image for years, including the version 3.4.4. Weird, were you tinkering with the FDI yourself (own build)? The other line looks like when facter is resolving ipaddress fact, it tries to resolve fdi hostname as well which lead to error. In that case I’d say your DHCP configuration is wrong.
Oh this just looks you messed up networking options, you need to provide a valid DNS server, looks like there is a “host fdi” call from facter which actually tries to resolve fdi and that fails for some reason.
I’d be interested however in seing output of “host fdi” after you get into this “weird” state. Can you enable ssh/root access via fdi.ssh=1 fdi.rootpw=somepass and run “facter ipaddress” and then “host fdi” manually?
aaah, right. My boot menu doesn’t have IPAPPEND, I am assuming as it is efiboot it is using some different kernel parameters, including BOOTIF which should be set to the mac address.
It looks like that isnt happening though, if I look at the value of the BOOTIF parameter on the booted failed discovery it shows it as 01-------
so looks like the regexp is not setting the value of the mac.
I changed the flag “rd.neednet=0” to 1 to force the network up. It now gets an ip and I now get the error
Response from server 422: {“message”:“ERF42-6513 [Foreman::Exception]: Unable to detect primary interface using MAC ‘:::::’ specified by discovery_fact ‘discovery_bootif’”}
Which seems to confirm that.
The grub.cfg in /var/lib/tftpboot/grub2 states
# On Debian/Ubuntu grub2 does not have patch for loading MAC-based configs. Also due to bug
# in RHEL 7.4 files are loaded with an extra “:” character at the end. This workarounds both
# cases, make sure “regexp.mod” file is present on the TFTP. For more info see:
I have it in /usr/lib/grub/x86_64-efi/regexp.mod does it need to be in /var/lib/tftpboot/grub2 too?
If so then are there other pieces missing ?
my grub2 folder has just grub.cfg, grubx64.efi and shim.efi
Deciding on that is I have to admit bad, we should do this more explicitly.
Do you have all the bits in place. You copied that correctly from:
But this is a snipped used in this context:
See it’s actually setting the mac variable there to workaround a bug which came with RHEL 7.4 in grub2. Now its fixed so if you are on grub2 from 7.5+ you are good and you can simply use just $net_default_mac.
Thanks a mill for the pointers. my grub2 was looking for regexp.mod in /EFI/BOOT/x86_64-efi/regexp.mod
and not finding it.
Aug 30 17:21:13 foremantest in.tftpd[13860]: RRQ from 192.168.178.172 filename /grub2/grub.cfg
Aug 30 17:21:13 foremantest in.tftpd[13861]: RRQ from 192.168.178.172 filename /EFI/BOOT/x86_64-efi/regexp.mod
Aug 30 17:21:13 foremantest in.tftpd[13861]: sending NAK (1, File not found) to 192.168.178.172
Aug 30 17:21:13 foremantest in.tftpd[13862]: RRQ from 192.168.178.172 filename /grub2/grub.cfg-01------
Once I created that folder structure and copied the file there the regex worked
Aug 30 17:23:38 foremantest in.tftpd[13984]: RRQ from 192.168.178.172 filename /grub2/grub.cfg
Aug 30 17:23:38 foremantest in.tftpd[13985]: RRQ from 192.168.178.172 filename /EFI/BOOT/x86_64-efi/regexp.mod
Aug 30 17:23:38 foremantest in.tftpd[13986]: RRQ from 192.168.178.172 filename /grub2/grub.cfg-01-f4-4d-30-60-d1-fd
and fdi is now successfully registering the discovery in foreman
Bit of a hack, but it’s working. Now to figure out why my grub wants that file/folder structure…
Yes, I used the installer. It didnt install anything into the grub2 folder other than the aforementioned grub.cfg, grubx64.efi and shim.efi(symlink to grubx64.efi)
I’ve messed about a bit with the config and upgraded to 1.18 in the meantime, so I can’t say for sure what a clean 1.18 looks like but I’m going to do a fresh install and I’ll report back
Can you please make a symlink that will make it to use regexp.mod on the correct path so it works also for Ubuntu Server out of box? Then we can add this to our installer so it works out of box.
I’d assume EFI/BOOT/x86_64-efi -> grub2/ but can you confirm?
I faced the same problem. The solution was the following:
mkdir -p /srv/tftp/EFI/BOOT/x86_64-efi
cp /usr/lib/grub/x86_64-efi/regexp.mod /srv/tftp/EFI/BOOT/x86_64-efi
@ekohl No, this fix doesn’t address the same problem.
Foreman 1.24 will now also deploy Grub2 configuration in the form of grub2.cfg-00:11:22:33:44:55:66 so no regular expression tricks will need to happen anymore. The template was updated to simply use MAC address grub2 predefined variable.
