With the movement to Pulp3 and the removal of MongoDB, a managed database Katello installation now only uses a single database service, PostgreSQL, which contains Foreman, Candlepin, and Pulp databases.
With that said, we also have the capability to deploy with unmanaged databases, and I’d like to start a discussion about the capabilities and installation experience of this feature, specifically regarding the below use cases:
For users who wish to deploy with a single external database server, could we have a single set of parameters for this DB server which simplifies the installation experience for external DBs? I.e. the user would only need to specify once the address and port of the external database server and by default all components would use these.
For very large deployments where Foreman, Candlepin, and Pulp are all competing for PostgreSQL connections, I think we should also make it possible to configure these external DBs separately per service, so that for example repository sync or CV publish/promote performance would not be throttled by the DB during times of high registration load.
Regarding the 2nd use case, it should already be possible with the way Pulp3 is installed to specify a separate external DB, but for Candlepin it’s not the case currently and would require some additional work.
I think a way to achieve both requirements would be implementing parameters such as --candlepin-use-foreman-db and --pulpcore-use-foreman-db which default to true. Then a user who wishes to configure a single external database server can simply pass the --foreman-db* parameters to the installer and candlepin and pulpcore would use the same configuration. However for the user who wants to configure separate DBs per service, those parameters could be changed to false and additional configuration for pulpcore and/or candlepin DBs could be supplied.
Please weigh in if you have any thoughts on this proposed design! Thanks,
