Due to the proxy sync memory issues with the elasticsearch repositories I have switched them to additive mirroring policy, retaining three versions.
I have noticed that I cannot download packages for elastic 7.x (repository URL https://artifacts.elastic.co/packages/7.x/yum) from my foreman content proxy because clients get a ‘404 not found’.
For instance when trying to update metricbeat:
[MIRROR] metricbeat-7.17.29-1.x86_64.rpm: Status code: 404 for https://foreman8-content.example.com/pulp/content/ORG/Production/alma8-epel8/custom/elastic/elasticsearch-7-x/Packages/m/metricbeat-7.17.29-1.x86_64.rpm
In the repository on the main server the rpm filename is filebeat-7.17.29-x86_64.rpm.
The problem seems to be that in the upstream elastic repository, all packages are release version “1” but the location points to a filename without release version, e.g.
<package type="rpm">
<name>filebeat</name>
<arch>x86_64</arch>
<version epoch="0" ver="7.17.29" rel="1"/>
<checksum type="sha256" pkgid="YES">c5c29a65b7471f8c13f5c46882c5f20a40c7649f40a870f91d54a7520d5ae269</checksum>
<summary>Filebeat sends log files to Logstash or directly to Elasticsearch.</summary>
<description>Filebeat sends log files to Logstash or directly to Elasticsearch.</description>
<packager><@e19274952431></packager>
<url>https://www.elastic.co/beats/filebeat</url>
<time file="1750299221" build="1750264623"/>
<size package="37158206" installed="137188994" archive="137460020"/>
<location href="7.17.29/filebeat-7.17.29-x86_64.rpm"/>
<format>
<rpm:license>Elastic-License</rpm:license>
<rpm:vendor>Elastic</rpm:vendor>
<rpm:group>default</rpm:group>
<rpm:buildhost>e19274952431</rpm:buildhost>
<rpm:sourcerpm>filebeat-7.17.29-1.src.rpm</rpm:sourcerpm>
<rpm:header-range start="4504" end="246273"/>
<rpm:provides>
<rpm:entry name="filebeat" flags="EQ" epoch="0" ver="7.17.29" rel="1"/>
<rpm:entry name="filebeat(x86-64)" flags="EQ" epoch="0" ver="7.17.29" rel="1"/>
</rpm:provides>
<rpm:requires>
<rpm:entry name="/bin/sh" pre="1"/>
</rpm:requires>
<file>/etc/filebeat/fields.yml</file>
<file>/etc/filebeat/filebeat.reference.yml</file>
<file>/etc/filebeat/filebeat.yml</file>
</format>
</package>
Katello syncs the rpm with the original filename filebeat-7.17.29-x86_64.rpm and keeps that name, but puts filebeat-7.17.29-1.x86_64.rpm into the primary.xml instead. This is already inconsistent in the Library view on the main server https://foreman8.example.com/pulp/content/ORG/Library/custom/elastic/elasticsearch-7-x/
katello-4.18.1-1.el9.noarch
foreman-3.16.2-1.el9.noarch
AlmaLinux 9.7
