Sync python image from docker hub ends with error "integer out of range"
On Foreman 3.13.0/Katello 4.15.0 and using this conf to sync the python docker image from docker hub:
Sync Settings
Registry URL: https://registry-1.docker.io/
Upstream Repository Name: python
Download Policy: Immediate
Mirroring Policy: Content Only
Include Tags: latest
Production log:
2025-03-31T15:17:07 [I|app|712d38d2] Processing by Katello::Api::V2::RepositoriesController#sync as HTML
2025-03-31T15:17:07 [I|app|712d38d2]   Parameters: {"id"=>"410", "organization_id"=>"1", "api_version"=>"v2", "repository"=>{"id"=>"410"}}
2025-03-31T15:17:07 [I|bac|712d38d2] Task {label: , execution_plan_id: 51c930a7-2c1e-47af-ab8d-6a03148cb3bc} state changed: pending
2025-03-31T15:17:07 [I|bac|712d38d2] Task {label: Actions::Katello::Repository::Sync, id: a4a2fda2-a491-4595-a323-c278e50c95bb, execution_plan_id: 51c930a7-2c1e-47af-ab8d-6a03148cb3bc} state changed: planning
2025-03-31T15:17:07 [I|bac|712d38d2] Task {label: Actions::Katello::Repository::Sync, id: a4a2fda2-a491-4595-a323-c278e50c95bb, execution_plan_id: 51c930a7-2c1e-47af-ab8d-6a03148cb3bc} state changed: planned
2025-03-31T15:17:07 [I|app|712d38d2]   Rendered /usr/share/gems/gems/katello-4.15.0/app/views/katello/api/v2/repositories/sync.json.rabl within katello/api/v2/layouts/resource (Duration: 19.3ms | Allocations: 15435)
2025-03-31T15:17:07 [I|app|712d38d2]   Rendered layout /usr/share/gems/gems/katello-4.15.0/app/views/katello/api/v2/layouts/resource.json.erb (Duration: 19.5ms | Allocations: 15528)
2025-03-31T15:17:07 [I|app|712d38d2] Completed 202 Accepted in 296ms (Views: 18.9ms | ActiveRecord: 22.7ms | Allocations: 100938)
2025-03-31T15:17:07 [I|bac|712d38d2] Task {label: Actions::Katello::Repository::Sync, id: a4a2fda2-a491-4595-a323-c278e50c95bb, execution_plan_id: 51c930a7-2c1e-47af-ab8d-6a03148cb3bc} state changed: running
2025-03-31T15:17:12 [E|bac|712d38d2] integer out of range (Katello::Errors::Pulp3Error)
 712d38d2 | /usr/share/gems/gems/katello-4.15.0/app/lib/actions/pulp3/abstract_async_task.rb:107:in `block in check_for_errors'
 712d38d2 | /usr/share/gems/gems/katello-4.15.0/app/lib/actions/pulp3/abstract_async_task.rb:105:in `each'
 712d38d2 | /usr/share/gems/gems/katello-4.15.0/app/lib/actions/pulp3/abstract_async_task.rb:105:in `check_for_errors'
 712d38d2 | /usr/share/gems/gems/katello-4.15.0/app/lib/actions/pulp3/abstract_async_task.rb:161:in `poll_external_task'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/action/polling.rb:100:in `poll_external_task_with_rescue'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/action/polling.rb:22:in `run'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/action/cancellable.rb:15:in `run'
 712d38d2 | /usr/share/gems/gems/katello-4.15.0/app/lib/actions/pulp3/abstract_async_task.rb:10:in `run'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/action.rb:590:in `block (3 levels) in execute_run'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/middleware/stack.rb:28:in `pass'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/middleware.rb:20:in `pass'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/middleware.rb:33:in `run'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/middleware/stack.rb:24:in `call'
 712d38d2 | /usr/share/gems/gems/katello-4.15.0/app/lib/actions/middleware/remote_action.rb:16:in `block in run'
 712d38d2 | /usr/share/gems/gems/katello-4.15.0/app/lib/actions/middleware/remote_action.rb:40:in `block in as_remote_user'
 712d38d2 | /usr/share/gems/gems/katello-4.15.0/app/models/katello/concerns/user_extensions.rb:21:in `cp_config'
 712d38d2 | /usr/share/gems/gems/katello-4.15.0/app/lib/actions/middleware/remote_action.rb:27:in `as_cp_user'
 712d38d2 | /usr/share/gems/gems/katello-4.15.0/app/lib/actions/middleware/remote_action.rb:39:in `as_remote_user'
 712d38d2 | /usr/share/gems/gems/katello-4.15.0/app/lib/actions/middleware/remote_action.rb:16:in `run'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/rails_executor_wrap.rb:14:in `block in run'
 712d38d2 | /usr/share/gems/gems/activesupport-6.1.7.10/lib/active_support/execution_wrapper.rb:91:in `wrap'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/rails_executor_wrap.rb:13:in `run'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/action/progress.rb:29:in `with_progress_calculation'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/action/progress.rb:15:in `run'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/load_setting_values.rb:20:in `run'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/keep_current_request_id.rb:15:in `block in run'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/keep_current_request_id.rb:52:in `restore_current_request_id'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/keep_current_request_id.rb:15:in `run'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/keep_current_timezone.rb:15:in `block in run'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/keep_current_timezone.rb:44:in `restore_curent_timezone'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/keep_current_timezone.rb:15:in `run'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/keep_current_taxonomies.rb:15:in `block in run'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/keep_current_taxonomies.rb:45:in `restore_current_taxonomies'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/keep_current_taxonomies.rb:15:in `run'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/keep_current_user.rb:15:in `block in run'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/keep_current_user.rb:54:in `restore_curent_user'
 712d38d2 | /usr/share/gems/gems/foreman-tasks-10.0.1/app/lib/actions/middleware/keep_current_user.rb:15:in `run'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/middleware/world.rb:31:in `execute'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/action.rb:589:in `block (2 levels) in execute_run'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/action.rb:588:in `catch'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/action.rb:588:in `block in execute_run'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/action.rb:491:in `block in with_error_handling'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/action.rb:491:in `catch'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/action.rb:491:in `with_error_handling'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/action.rb:583:in `execute_run'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/action.rb:304:in `execute'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:18:in `block (2 levels) in execute'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/execution_plan/steps/abstract.rb:168:in `with_meta_calculation'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:17:in `block in execute'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:32:in `open_action'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:16:in `execute'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/director.rb:95:in `execute'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/executors/sidekiq/worker_jobs.rb:12:in `block (2 levels) in perform'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/executors.rb:18:in `run_user_code'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/executors/sidekiq/worker_jobs.rb:10:in `block in perform'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/executors/sidekiq/worker_jobs.rb:26:in `with_telemetry'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/executors/sidekiq/worker_jobs.rb:9:in `perform'
 712d38d2 | /usr/share/gems/gems/dynflow-1.9.0/lib/dynflow/executors/sidekiq/serialization.rb:28:in `perform'
 712d38d2 | [ sidekiq ]
 712d38d2 | [ concurrent-ruby ]
2025-03-31T15:17:13 [I|bac|712d38d2] Task {label: Actions::Katello::Repository::Sync, id: a4a2fda2-a491-4595-a323-c278e50c95bb, execution_plan_id: 51c930a7-2c1e-47af-ab8d-6a03148cb3bc} state changed: stopped  result: warning
Can someone validate if this also happen on your Foreman/Katello installation? After updating to Foreman 3.14/Katello 4.16 the issue remains for me. All other images pulled from Docker hub works fine. Just the python image that gives me this issue.
Hey there, we ran into this issue as well. Specifying shared tags like 3.13, 3.14, etc, is what no longer works. We were able to get around it by specifying simple tags like 3.13-bookworm, 3.14-bookworm, etc.
