System hostname fact in discovery
Problem: Unable to change “Hostname facts” in Settings/Discovery.
It results in “Error updating setting: Invalid single-table inheritance type: Setting::Discovered is not a subclass of Setting”
Expected outcome: hostname fact should be set in the discovery
Foreman and Proxy versions: foreman-3.3.1
Distribution and version: CentOS 7.9
In production.log i find the following piece:
2022-12-13T16:53:05 [I|app|678b4448] Backtrace for 'Action failed' error (ActiveRecord::SubclassNotFound): Invalid single-table inheritance type: Setting::Discovered is not a subclass of Setting
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/inheritance.rb:241:in `find_sti_class'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/inheritance.rb:215:in `discriminate_class_for_record'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/persistence.rb:257:in `instantiate'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/querying.rb:58:in `block (2 levels) in find_by_sql'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/result.rb:62:in `block in each'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/result.rb:62:in `each'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/querying.rb:58:in `map'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/querying.rb:58:in `block in find_by_sql'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/querying.rb:56:in `find_by_sql'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/relation.rb:824:in `block in exec_queries'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/relation.rb:842:in `skip_query_cache_if_necessary'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/relation.rb:811:in `exec_queries'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/relation.rb:626:in `load'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/relation.rb:250:in `records'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/relation/finder_methods.rb:499:in `find_take'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/relation/finder_methods.rb:98:in `take'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/relation/finder_methods.rb:81:in `find_by'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/querying.rb:21:in `find_by'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/core.rb:183:in `find_by'
 678b4448 | /usr/share/foreman/app/services/setting_registry.rb:181:in `_find_or_new_db_record'
 678b4448 | /usr/share/foreman/app/services/setting_registry.rb:82:in `set_user_value'
 678b4448 | /usr/share/foreman/app/controllers/api/v2/settings_controller.rb:54:in `update'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/abstract_controller/base.rb:195:in `process_action'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/rendering.rb:30:in `process_action'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/callbacks.rb:112:in `block in run_callbacks'
 678b4448 | /usr/share/foreman/app/controllers/concerns/foreman/controller/timezone.rb:10:in `set_timezone'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/callbacks.rb:121:in `block in run_callbacks'
 678b4448 | /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in `clear_thread'
 678b4448 | /usr/share/foreman/app/controllers/concerns/foreman/controller/topbar_sweeper.rb:12:in `set_topbar_sweeper_controller'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.9.0/lib/audited/sweeper.rb:14:in `around'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/callbacks.rb:139:in `run_callbacks'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/abstract_controller/callbacks.rb:41:in `process_action'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/rescue.rb:22:in `process_action'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/notifications.rb:180:in `block in instrument'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/notifications.rb:180:in `instrument'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/abstract_controller/base.rb:136:in `process'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/rendering.rb:39:in `process'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal.rb:190:in `dispatch'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal.rb:254:in `dispatch'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/routing/route_set.rb:33:in `serve'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/routing/mapper.rb:48:in `serve'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/journey/router.rb:49:in `block in serve'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/journey/router.rb:32:in `each'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/journey/router.rb:32:in `serve'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/routing/route_set.rb:834:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.5.1/lib/katello/middleware/organization_created_enforcer.rb:18:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.5.1/lib/katello/middleware/event_daemon.rb:10:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/static.rb:126:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-dsl-2.4.0/lib/apipie_dsl/static_dispatcher.rb:67:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/static_dispatcher.rb:66:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/extractor/recorder.rb:137:in `call'
 678b4448 | /usr/share/foreman/lib/foreman/middleware/libvirt_connection_cleaner.rb:9:in `call'
 678b4448 | /usr/share/foreman/lib/foreman/middleware/telemetry.rb:10:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/tempfile_reaper.rb:15:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/etag.rb:27:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/conditional_get.rb:40:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/head.rb:12:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
 678b4448 | /usr/share/foreman/lib/foreman/middleware/logging_context_session.rb:22:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:266:in `context'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:260:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/cookies.rb:654:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/callbacks.rb:101:in `run_callbacks'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/rack/logger.rb:37:in `call_app'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/rack/logger.rb:28:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
 678b4448 | /usr/share/foreman/lib/foreman/middleware/logging_context_request.rb:11:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/request_id.rb:27:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.5.1/lib/katello/prevent_json_parsing.rb:12:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/method_override.rb:24:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/runtime.rb:22:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/executor.rb:14:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/sendfile.rb:110:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/ssl.rb:74:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/host_authorization.rb:97:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-6.3.0/lib/secure_headers/middleware.rb:11:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/engine.rb:527:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/railtie.rb:190:in `public_send'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/railtie.rb:190:in `method_missing'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/urlmap.rb:74:in `block in call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/urlmap.rb:58:in `each'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/urlmap.rb:58:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.6.2/lib/puma/configuration.rb:252:in `call'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.6.2/lib/puma/request.rb:77:in `block in handle_request'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.6.2/lib/puma/thread_pool.rb:340:in `with_force_shutdown'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.6.2/lib/puma/request.rb:76:in `handle_request'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.6.2/lib/puma/server.rb:441:in `process_client'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.6.2/lib/puma/thread_pool.rb:147:in `block in spawn_thread'
 678b4448 | /opt/theforeman/tfm/root/usr/share/gems/gems/logging-2.3.0/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2022-12-13T16:53:05 [I|app|678b4448]   Rendering api/v2/errors/standard_error.json.rabl within api/v2/layouts/error_layout
2022-12-13T16:53:05 [I|app|678b4448]   Rendered api/v2/errors/standard_error.json.rabl within api/v2/layouts/error_layout (Duration: 2.6ms | Allocations: 272)
2022-12-13T16:53:05 [I|app|678b4448] Completed 500 Internal Server Error in 21ms (Views: 8.6ms | ActiveRecord: 1.7ms | Allocations: 4062)
I think you are affected by Bug #35686: Can't change Discovery Hostname facts in Settings Discovery tab - Discovery - Foreman, which should be solved in foreman-discovery 21.0.4
What version of foreman-discovery do you have installed? (The package name on EL7 is tfm-rubygem-foreman_discovery).
If it is not 21.0.4, you should update to that version and rerun foreman-installer to let migrations run.
thank you very much - very helpful.
foreman_discovery was indeed too old!
If your problem is solved, please mark my answer as solution so others can see at a glance that there is no more help required here :slight_smile:
