So I haven’t seen this supported natively but in some searching came across a (very) out dated plugin (mentioned in Feature #11733: Assign tags to hosts - Foreman), but how feasible is it to tag hosts. So say I have 5 hosts. A single host group doesn’t always fit as things may over lap. Nesting doesn’t fit because of layering. Being able to set a couple values based on tags where it doesn’t matter what the hierarchical grouping is seems like it would offer significantly increased flexibility. Is something like this in/on the roadmap at all?
I don’t know if this should be a “replacement” to host groups or something that can augment host groups. I can see some arguments on all sides.
While not being exactly what you are looking for, maybe you could achieve your goal via Fact based matchers? Here is the docs on that: Foreman :: Manual
Depending on what exactly you are basing the differentiation of the hosts on, maybe checking for a simple fact could be enough?
If that does not solve your problem, I know of no other solution. There is to my knowledge currently no tagging mechanism in Foreman, especially none that would allow to be used as a matcher for Smart Class Parameters.
