In the Subnet settings, when setting as Templates proxy a smart proxy the template rendering will allways renders the HTTPS URL regardless of smart-proxy template settings
The rendered foreman_url(‘provision’) is alway https://smart-proxy.foreman.org:9090/…
This will principally work but anaconda will not be able to verify/trust the SSL certificate so it will noch be able to download the template.
Would there be a way to update the initrd.img to include more Root CA?
Should return a URL depending on what is set in /etc/foreman-proxy/settings.d/template.yml.
foreman-1.18.0-2.el7.noarch
katello-3.7.0-4.el7.noarch
foreman-proxy-1.18.0-1.el7.noarch
There are no error in logs since the template rendering works but doesn’t return the expected value
Any Idea?
rgds,
Arsene
