I was wondering if there'd be any interest in a future PR to update
theforeman-puppet module to use the inifile provider (or a child provider
named puppet_config) for managing values in puppet.conf. The idea being
such a drastic change would be allow the puppet.conf to be modified by
other community modules or by individual's "site specific" modules while
still being able to use theforeman-puppet. The current number of possible
configuration values and options for puppet.conf is staggering and I'd
consider too great to effectively manage using a template approach without
limiting what users of theforeman-puppet module can do. I'm finding that
as my puppet setup becomes more complex (multiple masters with some clients
using masterless) I'm having to perform a PR on each new configuration
option needed to make my setup possible.
A PR to switch to using a type/provider for managing puppet.conf would
likely include a declaration in the init.pp that sets "resources {
'puppet_config': purge => $purge_puppet_config }" and the default value for
$purge_puppet_config would be true (or false if purging seems too 'harsh').
Thoughts?
Broadly I'm in favour. I'd like to see what the various comparative
benefits are of inifile vs augeas vs $otherthing-ive-not-thought-of
though.
Greg
Seems reasonable to me, and I agree about purging other entries by default.
The inifile type/provider is superior to the Augeas type, so I'd
recommend that. The only other alternative is datacat plus a template,
but I've not used it yet to offer a comparison.
> provider named puppet_config) for managing values in puppet.conf. The
> idea being such a drastic change would be allow the puppet.conf to be
> modified by other community modules or by individual's "site specific"
> modules while still being able to use theforeman-puppet. The current
> number of possible configuration values and options for puppet.conf is
> staggering and I'd consider too great to effectively manage using a
> template approach without limiting what users of theforeman-puppet
> module can do. I'm finding that as my puppet setup becomes more complex
> (multiple masters with some clients using masterless) I'm having to
> perform a PR on each new configuration option needed to make my setup
> possible.
> for $purge_puppet_config would be true (or false if purging seems too
> 'harsh').
> Thoughts?
Dominic Cleal
Red Hat Engineering
As Dominic mentioned, the inifile type/provider is superior to Augeas
and I find it MUCH easier to look at the code given I'm not an Augeas
expert :).
The datacat method could work too, but my initial impression is it is
somewhat more complex to implement. This is going off of looking at
the puppetlabs-mcollective module.
I'll see if I can get this implemented and tested.
>> possible.
>> 'harsh').
>> Thoughts?
> Dominic Cleal
> Red Hat Engineering
> You received this message because you are subscribed to a topic in the Google Groups "foreman-dev" group.
> To unsubscribe from this topic, visit https://groups.google.com/d/topic/foreman-dev/M3r3oq2ofQE/unsubscribe.
> To unsubscribe from this group and all its topics, send an email to foreman-dev+unsubscribe@googlegroups.com.
