Can someone let me know what actions can trigger a build state on a node that is in the Foreman host list already? For instance, I know that selecting a node and choosing the ‘build hosts’ action obviously will put the node into a ‘pending build’ state, but what else can put it into a ‘pending build’ state? Does ‘rebuild config’ trigger this? Or changing the options in the node’s host group? Or changing the templates that are chosen in its affiliated Operating System?
Or is it only put into a ‘pending build’ state when you select ‘build hosts’ from the action menu for that node?
Foreman 3.5.2
Foreman proxy 3.5.2
foreman_bootdisk 21.0.3
foreman_discovery 22.0.2
foreman_expire_hosts 8.1.0
Rocky 8.7
