when trying to install the newest rubyracer gem from the SCL, I get the
following error:
[root@puppetmaster ~]# yum install ruby193-rubygem-therubyracer
Loaded plugins: priorities, security
2160 packages excluded due to repository priority protections
Setting up Install Process
Resolving Dependencies
–> Running transaction check
—> Package ruby193-rubygem-therubyracer.x86_64 0:0.11.0-0.9.beta5.el6
will be installed
–> Processing Dependency: ruby193-rubygem(ref) for package:
ruby193-rubygem-therubyracer-0.11.0-0.9.beta5.el6.x86_64
–> Processing Dependency: libv8.so.v8314-3.14.5()(64bit) for package:
—> Package ruby193-rubygem-ref.noarch 0:1.0.0-3.el6 will be installed
will be installed
–> Finished Dependency Resolution
–> Finding unneeded leftover dependencies
Found and removing 0 unneeded dependencies
Error: Package:
(Scientific-SCL-ruby193-6.5-x86_64)
Requires: libv8.so.v8314-3.14.5()(64bit)
This is Scientific Linux 6.6 and I'm running from a local mirror of the
foreman repos and the SCL.
Installing the previous version works:
ruby193-rubygem-therubyracer-0.11.0-0.6.beta5.el6
—> Package ruby193-rubygem-therubyracer.x86_64 0:0.11.0-0.6.beta5.el6
will be installed
–> Processing Dependency: ruby193-v8 for package:
ruby193-rubygem-therubyracer-0.11.0-0.6.beta5.el6.x86_64
–> Processing Dependency: libv8.so.3()(64bit) for package:
—> Package ruby193-v8.x86_64 1:3.14.5.10-2.el6 will be installed
–> Processing Dependency: libicuuc.so.42()(64bit) for package:
1:ruby193-v8-3.14.5.10-2.el6.x86_64
–> Processing Dependency: libicui18n.so.42()(64bit) for package:
–> Processing Dependency: libicudata.so.42()(64bit) for package:
—> Package libicu.x86_64 0:4.2.1-9.1.el6_2 will be installed
Dependencies Resolved
================================================================================================================================================================Package Arch
Version Repository
Size
Installing:
ruby193-rubygem-therubyracer x86_64
0.11.0-0.6.beta5.el6 Scientific-SCL-ruby193-6.5-x86_64
66 k
Installing for dependencies:
libicu x86_64
4.2.1-9.1.el6_2 Scientific-6.5-x86_64
4.9 M
ruby193-rubygem-ref noarch
1.0.0-3.el6 Scientific-SCL-ruby193-6.5-x86_64
13 k
ruby193-v8 x86_64
1:3.14.5.10-2.el6 Scientific-SCL-ruby193-6.5-x86_64
3.0 M
Transaction Summary
Install 4 Package(s)
Total download size: 8.0 M
Installed size: 29 M
Is this ok [y/N]: y
Downloading Packages:
Total
2.1 MB/s | 8.0
MB 00:03
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
Installing : libicu-4.2.1-9.1.el6_2.x86_64
1/4
Installing : 1:ruby193-v8-3.14.5.10-2.el6.x86_64
2/4
Installing : ruby193-rubygem-ref-1.0.0-3.el6.noarch
3/4
Installing : ruby193-rubygem-therubyracer-0.11.0-0.6.beta5.el6.x86_64
4/4
Verifying : ruby193-rubygem-therubyracer-0.11.0-0.6.beta5.el6.x86_64
1/4
Verifying : ruby193-rubygem-ref-1.0.0-3.el6.noarch
2/4
Verifying : libicu-4.2.1-9.1.el6_2.x86_64
3/4
Verifying : 1:ruby193-v8-3.14.5.10-2.el6.x86_64
4/4
Installed:
Dependency Installed:
Complete!
It’d be great if someone could verify this and forward to this to the
responsibles.
Regards, David
