i have uploaded everything according to you required but i have not get any suggestion on it
really it is painful to get resolution about ubuntu installation Please suggest who can help on it
Dear Gvde,
I have not received a response from anyone, so if you could please help me with the Ubuntu installation. I have supplied all the required information, but to no effect.
Kindly ask that you get someone on board who can assist with it.
Hey @srikanthm
Please note that this is a community forum. Everyone that read and/or answered you here has dedicated their own time to help you out. Adding multiple answers in quick fashion one after another does not help.
The community provides documentation on how to provision Ubuntu 20.04.4+ (with AutoInstall):
- Creating an Installation Medium for Ubuntu 22.04
- Provisioning Ubuntu Autoinstall Through Smart Proxies
I’ve linked the latest docs, please also have a look at “3.3” (your Foreman version) by selecting 3.3 in the top right corner.
If you require professional paid support, please have a look at theforeman.org/professional-services.
if any suggestion with below error
operating system used
kindly suggest me if you have any idea on it i will try to sortout it
I just figured that you are using different Ubuntu versions.
I thought you would use an Ubuntu version prior to 20.04.3. But, since you have been using 20.04.6 and now want to use 22.04.2, you must pay attention to the documentation linked by Maximilian.
Moreover, you have to use different templates. For Ubuntu 20.04.3+, you have to use the Autoinstall templates:
- PXELinux:
Preseed default PXELinux Autoinstall - User data:
Preseed Autoinstall cloud-init user data - Partition Table:
Preseed default autointall
Update your Installation Media path to download the correct image as well. And, follow the steps provided before (especially, “creating an Installation Medium”):
thank you for your suggestion.
yes i have tried with earlier with 20.04 with foreman server but unfortunately which is not working so i am following document which is suggested by Maximilian with 22.04 version.
i know you are only the person who can help on ubuntu on this issue.
i will follow your suggestion and update on this issue.
using above autoinstall templates
i have one doubt what about the templates **[ Preseed default finish] and [Preseed default] **
do you want me use above mentioned?
The ones you marked are correct.
Regarding your doubts:
A. Preseed default finish should be used as well, you are right.
B. But, don’t use Preseed default (it is replaced by Preseed Autoinstall cloud-init user data).
installation media updated with 22.04 correct version
configured below operating system with templates as per your suggestion.
if anything templated used wrongly,
Preformatted text please advise meunfortunately, i am getting below same error.
[root@boldforeman foreman]# cat /var/log/foreman/production.log
2023-06-21T08:11:55 [I|app|6b698ef1] Started POST "/console/bea-helpsets/%252E%252E%252Fconsole.portal" for 137.201.104.186 at 2023-06-21 08:11:55 -0600
2023-06-21T08:11:55 [F|app|6b698ef1]
6b698ef1 | ActionController::RoutingError (No route matches [POST] "/console/bea-helpsets/%252E%252E%252Fconsole.portal"):
6b698ef1 |
6b698ef1 | lib/foreman/middleware/logging_context_request.rb:11:in `call'
6b698ef1 | katello (4.5.1) lib/katello/prevent_json_parsing.rb:12:in `call'
2023-06-21T08:12:05 [I|app|8462e23c] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:12:05 -0600
2023-06-21T08:12:05 [I|app|8462e23c] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:12:05 [I|app|8462e23c] Completed 200 OK in 7ms (Views: 0.1ms | ActiveRecord: 1.3ms | Allocations: 1797)
2023-06-21T08:12:05 [I|app|7a3d85c6] Started GET "/discovered_hosts" for 10.68.25.98 at 2023-06-21 08:12:05 -0600
2023-06-21T08:12:05 [I|app|7a3d85c6] Processing by DiscoveredHostsController#index as HTML
2023-06-21T08:12:05 [I|app|7a3d85c6] Rendering /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-21.0.5/app/views/discovered_hosts/welcome.html.erb within layouts/application
2023-06-21T08:12:05 [I|app|7a3d85c6] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-21.0.5/app/views/discovered_hosts/welcome.html.erb within layouts/application (Duration: 6.1ms | Allocations: 6472)
2023-06-21T08:12:05 [I|app|7a3d85c6] Rendered layouts/_application_content.html.erb (Duration: 2.9ms | Allocations: 5713)
2023-06-21T08:12:05 [I|app|7a3d85c6] Rendering layouts/base.html.erb
2023-06-21T08:12:05 [I|app|7a3d85c6] Rendered layouts/base.html.erb (Duration: 19.2ms | Allocations: 24317)
2023-06-21T08:12:05 [I|app|7a3d85c6] Filter chain halted as :welcome rendered or redirected
2023-06-21T08:12:05 [I|app|7a3d85c6] Completed 200 OK in 42ms (Views: 32.4ms | ActiveRecord: 2.7ms | Allocations: 45705)
2023-06-21T08:12:07 [I|app|dfeef58a] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:12:07 -0600
2023-06-21T08:12:07 [I|app|dfeef58a] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:12:07 [I|app|dfeef58a] Completed 200 OK in 5ms (Views: 0.1ms | ActiveRecord: 0.9ms | Allocations: 1813)
2023-06-21T08:12:09 [I|app|3f55f9ab] Started GET "/discovered_hosts" for 10.68.25.98 at 2023-06-21 08:12:09 -0600
2023-06-21T08:12:09 [I|app|3f55f9ab] Processing by DiscoveredHostsController#index as HTML
2023-06-21T08:12:09 [I|app|3f55f9ab] Rendering /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-21.0.5/app/views/discovered_hosts/welcome.html.erb within layouts/application
2023-06-21T08:12:09 [I|app|3f55f9ab] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-21.0.5/app/views/discovered_hosts/welcome.html.erb within layouts/application (Duration: 5.3ms | Allocations: 6469)
2023-06-21T08:12:09 [I|app|3f55f9ab] Rendered layouts/_application_content.html.erb (Duration: 2.7ms | Allocations: 5712)
2023-06-21T08:12:09 [I|app|3f55f9ab] Rendering layouts/base.html.erb
2023-06-21T08:12:09 [I|app|3f55f9ab] Rendered layouts/base.html.erb (Duration: 19.1ms | Allocations: 24315)
2023-06-21T08:12:09 [I|app|3f55f9ab] Filter chain halted as :welcome rendered or redirected
2023-06-21T08:12:09 [I|app|3f55f9ab] Completed 200 OK in 40ms (Views: 31.0ms | ActiveRecord: 2.4ms | Allocations: 45698)
2023-06-21T08:12:10 [I|app|ff734632] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:12:10 -0600
2023-06-21T08:12:10 [I|app|ff734632] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:12:10 [I|app|ff734632] Completed 200 OK in 6ms (Views: 0.1ms | ActiveRecord: 1.0ms | Allocations: 1813)
2023-06-21T08:12:16 [I|app|c5d028d6] Started POST "/console/framework/skins/wlsconsole/images/%252E%252E%252Fconsole.portal" for 137.201.104.186 at 2023-06-21 08:12:16 -0600
2023-06-21T08:12:16 [F|app|c5d028d6]
c5d028d6 | ActionController::RoutingError (No route matches [POST] "/console/framework/skins/wlsconsole/images/%252E%252E%252Fconsole.portal"):
c5d028d6 |
c5d028d6 | lib/foreman/middleware/logging_context_request.rb:11:in `call'
c5d028d6 | katello (4.5.1) lib/katello/prevent_json_parsing.rb:12:in `call'
2023-06-21T08:12:17 [I|app|10a10f06] Started GET "/hosts" for 10.68.25.98 at 2023-06-21 08:12:17 -0600
2023-06-21T08:12:17 [I|app|10a10f06] Processing by HostsController#index as HTML
2023-06-21T08:12:17 [I|app|10a10f06] Rendering hosts/index.html.erb within layouts/application
2023-06-21T08:12:17 [I|app|10a10f06] Rendered common/_pagination.html.erb (Duration: 3.6ms | Allocations: 5754)
2023-06-21T08:12:17 [I|app|10a10f06] Rendered hosts/_list.html.erb (Duration: 21.8ms | Allocations: 21846)
2023-06-21T08:12:17 [I|app|10a10f06] Rendered hosts/index.html.erb within layouts/application (Duration: 30.6ms | Allocations: 30225)
2023-06-21T08:12:17 [I|app|10a10f06] Rendered layouts/_application_content.html.erb (Duration: 3.0ms | Allocations: 6090)
2023-06-21T08:12:17 [I|app|10a10f06] Rendering layouts/base.html.erb
2023-06-21T08:12:18 [I|app|10a10f06] Rendered layouts/base.html.erb (Duration: 16.7ms | Allocations: 24262)
2023-06-21T08:12:18 [I|app|10a10f06] Completed 200 OK in 83ms (Views: 51.6ms | ActiveRecord: 10.3ms | Allocations: 76596)
2023-06-21T08:12:18 [I|app|8c4bd717] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:12:18 -0600
2023-06-21T08:12:18 [I|app|8c4bd717] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:12:18 [I|app|8c4bd717] Completed 200 OK in 5ms (Views: 0.1ms | ActiveRecord: 0.8ms | Allocations: 1813)
2023-06-21T08:12:19 [I|app|67516a78] Started GET "/api/v2/hosts/boldforeman.micron.com/power" for 10.68.25.98 at 2023-06-21 08:12:19 -0600
2023-06-21T08:12:19 [I|app|67516a78] Processing by Api::V2::HostsController#power_status as JSON
2023-06-21T08:12:19 [I|app|67516a78] Parameters: {"apiv"=>"v2", "id"=>"boldforeman.micron.com"}
2023-06-21T08:12:19 [I|app|67516a78] Completed 200 OK in 11ms (Views: 0.2ms | ActiveRecord: 2.2ms | Allocations: 3639)
2023-06-21T08:12:19 [I|app|0750a0b2] Started GET "/api/v2/hosts/bolforemanproxy.micron.com/power" for 10.68.25.98 at 2023-06-21 08:12:19 -0600
2023-06-21T08:12:19 [I|app|0750a0b2] Processing by Api::V2::HostsController#power_status as JSON
2023-06-21T08:12:19 [I|app|0750a0b2] Parameters: {"apiv"=>"v2", "id"=>"bolforemanproxy.micron.com"}
2023-06-21T08:12:19 [I|app|0750a0b2] Completed 200 OK in 10ms (Views: 0.2ms | ActiveRecord: 1.9ms | Allocations: 3598)
2023-06-21T08:12:19 [I|app|c5f5904b] Started GET "/api/v2/hosts/bulforemanproxy.micron.com/power" for 10.68.25.98 at 2023-06-21 08:12:19 -0600
2023-06-21T08:12:19 [I|app|c5f5904b] Processing by Api::V2::HostsController#power_status as JSON
2023-06-21T08:12:19 [I|app|c5f5904b] Parameters: {"apiv"=>"v2", "id"=>"bulforemanproxy.micron.com"}
2023-06-21T08:12:19 [I|app|c5f5904b] Completed 200 OK in 10ms (Views: 0.2ms | ActiveRecord: 1.9ms | Allocations: 3597)
2023-06-21T08:12:19 [I|app|45ba23b2] Started GET "/api/v2/hosts/hylformanproxy.micron.com/power" for 10.68.25.98 at 2023-06-21 08:12:19 -0600
2023-06-21T08:12:19 [I|app|45ba23b2] Processing by Api::V2::HostsController#power_status as JSON
2023-06-21T08:12:19 [I|app|45ba23b2] Parameters: {"apiv"=>"v2", "id"=>"hylformanproxy.micron.com"}
2023-06-21T08:12:19 [I|app|45ba23b2] Completed 200 OK in 11ms (Views: 0.2ms | ActiveRecord: 2.2ms | Allocations: 3597)
2023-06-21T08:12:19 [I|app|db075e3a] Started GET "/api/v2/hosts/hylsubhvm.micron.com/power" for 10.68.25.98 at 2023-06-21 08:12:19 -0600
2023-06-21T08:12:19 [I|app|db075e3a] Processing by Api::V2::HostsController#power_status as JSON
2023-06-21T08:12:19 [I|app|db075e3a] Parameters: {"apiv"=>"v2", "id"=>"hylsubhvm.micron.com"}
2023-06-21T08:12:19 [I|app|db075e3a] Completed 200 OK in 10ms (Views: 0.2ms | ActiveRecord: 1.7ms | Allocations: 3599)
2023-06-21T08:12:25 [I|app|cc4d65c7] Started DELETE "/hosts/hylsubhvm.micron.com" for 10.68.25.98 at 2023-06-21 08:12:25 -0600
2023-06-21T08:12:25 [I|app|cc4d65c7] Processing by HostsController#destroy as HTML
2023-06-21T08:12:25 [I|app|cc4d65c7] Parameters: {"authenticity_token"=>"cOXtehR8//tcM22HTKZkF/tBG+Q5jJJVystYzy0ixSVvX6BsBYJzjVG0pp80vBfK4uwxUsksYtpBT64/XE02LA==", "id"=>"hylsubhvm.micron.com"}
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on host_id 189
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on uuid
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on content_view_id 1
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on lifecycle_environment_id 1
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on kickstart_repository_id
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on content_source_id 3
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on installable_security_errata_count 0
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on installable_enhancement_errata_count 0
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on installable_bugfix_errata_count 0
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on applicable_rpm_count 0
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on upgradable_rpm_count 0
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on applicable_module_stream_count 0
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on upgradable_module_stream_count 0
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on applicable_deb_count 0
2023-06-21T08:12:25 [I|aud|cc4d65c7] Katello::Host::ContentFacet (132) destroy event on upgradable_deb_count 0
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on mac 00:50:56:81:f8:07
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on ip 10.70.87.114
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on type Nic::Managed
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on name hylsubhvm.micron.com
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on host_id 189
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on subnet_id 2
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on domain_id 1
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on attrs {"netmask"=>"255.255.255.0", "mtu"=>1500, "network"=>"10.70.87.0", "speed"=>"1000", "duplex"=>"full", "port"=>"Twisted Pair", "auto_negotiation"=>"true", "wol"=>true}
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on provider
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on username
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on password [redacted]
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on virtual false
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on link true
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on identifier ens192
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on tag
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on attached_to
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on managed true
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on mode balance-rr
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on attached_devices
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on bond_options
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on primary true
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on provision true
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on compute_attributes {}
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on execution false
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on ip6
2023-06-21T08:12:25 [I|aud|cc4d65c7] Nic::Managed (199) destroy event on subnet6_id
2023-06-21T08:12:25 [I|app|cc4d65c7] Delete the TFTP configuration for hylsubhvm.micron.com
2023-06-21T08:12:25 [I|app|cc4d65c7] Processed 4 tasks from queue 'Host::Managed Main', completed 4/4
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on name hylsubhvm.micron.com
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on root_pass
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on architecture_id 1
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on operatingsystem_id 24
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on ptable_id 135
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on medium_id 29
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on build true
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on comment
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on disk
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on installed_at
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on model_id 1
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on hostgroup_id 10
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on owner_id 4
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on owner_type User
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on enabled true
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on puppet_ca_proxy_id
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on managed true
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on use_image
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on image_file
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on uuid
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on compute_resource_id
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on puppet_proxy_id
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on certname
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on image_id
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on organization_id 1
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on location_id 8
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on otp
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on realm_id
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on compute_profile_id
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on provision_method
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on grub_pass
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on pxe_loader PXELinux BIOS
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on initiated_at
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on build_errors
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on discovery_rule_id
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on registration_facet_attributes {"id"=>138, "host_id"=>189, "jwt_secret"=>"MeocAZnXhmc9ozbKaWvuAA=="}
2023-06-21T08:12:25 [I|aud|cc4d65c7] Host::Base (189) destroy event on ansible_role_ids []
2023-06-21T08:12:25 [I|app|cc4d65c7] Redirected to https://boldforeman.micron.com/hosts
2023-06-21T08:12:25 [I|app|cc4d65c7] Completed 302 Found in 241ms (ActiveRecord: 43.0ms | Allocations: 59748)
2023-06-21T08:12:25 [I|app|fa51f39d] Started GET "/hosts" for 10.68.25.98 at 2023-06-21 08:12:25 -0600
2023-06-21T08:12:25 [I|app|fa51f39d] Processing by HostsController#index as HTML
2023-06-21T08:12:25 [I|app|fa51f39d] Rendering hosts/index.html.erb within layouts/application
2023-06-21T08:12:25 [I|app|fa51f39d] Rendered common/_pagination.html.erb (Duration: 3.6ms | Allocations: 5753)
2023-06-21T08:12:25 [I|app|fa51f39d] Rendered hosts/_list.html.erb (Duration: 21.4ms | Allocations: 20346)
2023-06-21T08:12:25 [I|app|fa51f39d] Rendered hosts/index.html.erb within layouts/application (Duration: 29.9ms | Allocations: 28724)
2023-06-21T08:12:25 [I|app|fa51f39d] Rendered layouts/_application_content.html.erb (Duration: 3.0ms | Allocations: 6091)
2023-06-21T08:12:25 [I|app|fa51f39d] Rendering layouts/base.html.erb
2023-06-21T08:12:25 [I|app|fa51f39d] Rendered layouts/base.html.erb (Duration: 16.9ms | Allocations: 24299)
2023-06-21T08:12:25 [I|app|fa51f39d] Completed 200 OK in 80ms (Views: 50.9ms | ActiveRecord: 10.8ms | Allocations: 74700)
2023-06-21T08:12:26 [I|app|7855798f] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:12:26 -0600
2023-06-21T08:12:26 [I|app|7855798f] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:12:26 [I|app|7855798f] Completed 200 OK in 11ms (Views: 0.1ms | ActiveRecord: 2.4ms | Allocations: 4732)
2023-06-21T08:12:26 [I|app|b7b62d72] Started GET "/api/v2/hosts/boldforeman.micron.com/power" for 10.68.25.98 at 2023-06-21 08:12:26 -0600
2023-06-21T08:12:26 [I|app|b7b62d72] Processing by Api::V2::HostsController#power_status as JSON
2023-06-21T08:12:26 [I|app|b7b62d72] Parameters: {"apiv"=>"v2", "id"=>"boldforeman.micron.com"}
2023-06-21T08:12:26 [I|app|b7b62d72] Completed 200 OK in 18ms (Views: 0.4ms | ActiveRecord: 3.5ms | Allocations: 3598)
2023-06-21T08:12:26 [I|app|050464d0] Started GET "/api/v2/hosts/bolforemanproxy.micron.com/power" for 10.68.25.98 at 2023-06-21 08:12:26 -0600
2023-06-21T08:12:26 [I|app|050464d0] Processing by Api::V2::HostsController#power_status as JSON
2023-06-21T08:12:26 [I|app|050464d0] Parameters: {"apiv"=>"v2", "id"=>"bolforemanproxy.micron.com"}
2023-06-21T08:12:26 [I|app|050464d0] Completed 200 OK in 10ms (Views: 0.2ms | ActiveRecord: 1.6ms | Allocations: 3598)
2023-06-21T08:12:26 [I|app|6a7f1439] Started GET "/api/v2/hosts/bulforemanproxy.micron.com/power" for 10.68.25.98 at 2023-06-21 08:12:26 -0600
2023-06-21T08:12:26 [I|app|6a7f1439] Processing by Api::V2::HostsController#power_status as JSON
2023-06-21T08:12:26 [I|app|6a7f1439] Parameters: {"apiv"=>"v2", "id"=>"bulforemanproxy.micron.com"}
2023-06-21T08:12:26 [I|app|6a7f1439] Completed 200 OK in 15ms (Views: 0.2ms | ActiveRecord: 2.9ms | Allocations: 3597)
2023-06-21T08:12:26 [I|app|e20c9576] Started GET "/api/v2/hosts/hylformanproxy.micron.com/power" for 10.68.25.98 at 2023-06-21 08:12:26 -0600
2023-06-21T08:12:26 [I|app|e20c9576] Processing by Api::V2::HostsController#power_status as JSON
2023-06-21T08:12:26 [I|app|e20c9576] Parameters: {"apiv"=>"v2", "id"=>"hylformanproxy.micron.com"}
2023-06-21T08:12:26 [I|app|e20c9576] Completed 200 OK in 10ms (Views: 0.2ms | ActiveRecord: 2.5ms | Allocations: 3597)
2023-06-21T08:12:35 [I|app|18be7d38] Started POST "/api/v2/discovered_hosts/facts" for 10.70.87.49 at 2023-06-21 08:12:35 -0600
2023-06-21T08:12:35 [I|app|18be7d38] Processing by Api::V2::DiscoveredHostsController#facts as JSON
2023-06-21T08:12:35 [I|app|18be7d38] Parameters: {"facts"=>"[FILTERED]", "apiv"=>"v2", "discovered_host"=>{"facts"=>"[FILTERED]"}}
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on mac
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on ip
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on type Nic::Managed
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on name mac00505681f807
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on host_id 190
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on subnet_id
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on domain_id
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on attrs {}
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on provider
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on username
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on password [redacted]
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on virtual false
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on link true
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on identifier
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on tag
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on attached_to
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on managed true
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on mode balance-rr
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on attached_devices
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on bond_options
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on primary true
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on provision true
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on compute_attributes {}
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on execution false
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on ip6
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) create event on subnet6_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on name mac00505681f807
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on last_compile
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on root_pass
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on architecture_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on operatingsystem_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on ptable_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on medium_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on build false
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on comment
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on disk
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on installed_at
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on model_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on hostgroup_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on owner_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on owner_type
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on enabled true
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on puppet_ca_proxy_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on managed false
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on use_image
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on image_file
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on uuid
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on compute_resource_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on puppet_proxy_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on certname
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on image_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on organization_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on location_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on otp
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on realm_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on compute_profile_id
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on provision_method
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on grub_pass
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on global_status 0
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on lookup_value_matcher
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on pxe_loader
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on initiated_at
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on build_errors
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) create event on discovery_rule_id
2023-06-21T08:12:35 [I|app|18be7d38] Import facts for 'mac00505681f807' completed. Added: 81, Updated: 0, Deleted 0 facts
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) update event on mac , 00:50:56:81:f8:07
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) update event on identifier , ens192
2023-06-21T08:12:35 [I|app|18be7d38] Detected IPv4 subnet: HYIN-SN87 with taxonomy ["MU"]/["HYIN"]
2023-06-21T08:12:35 [I|app|18be7d38] Assigned location: HYIN
2023-06-21T08:12:35 [I|app|18be7d38] Assigned organization: MU
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) update event on model_id , 1
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) update event on owner_id , 1
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) update event on owner_type , User
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) update event on organization_id , 1
2023-06-21T08:12:35 [I|aud|18be7d38] Host::Base (190) update event on location_id , 8
2023-06-21T08:12:35 [I|aud|18be7d38] Nic::Managed (200) update event on subnet_id , 2
2023-06-21T08:12:35 [W|app|18be7d38] DefaultHostgroupMatch: Could not load :default_hostgroup map from Settings.
2023-06-21T08:12:35 [I|app|18be7d38] Completed 201 Created in 382ms (Views: 1.0ms | ActiveRecord: 107.9ms | Allocations: 156527)
2023-06-21T08:12:36 [I|app|0b71d0fb] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:12:36 -0600
2023-06-21T08:12:36 [I|app|0b71d0fb] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:12:36 [I|app|0b71d0fb] Completed 200 OK in 11ms (Views: 0.1ms | ActiveRecord: 2.3ms | Allocations: 5006)
2023-06-21T08:12:37 [I|app|cea7ea9d] Started POST "/console/framework/skins/wlsconsole/css/%252E%252E%252Fconsole.portal" for 137.201.104.186 at 2023-06-21 08:12:37 -0600
2023-06-21T08:12:37 [F|app|cea7ea9d]
cea7ea9d | ActionController::RoutingError (No route matches [POST] "/console/framework/skins/wlsconsole/css/%252E%252E%252Fconsole.portal"):
cea7ea9d |
cea7ea9d | lib/foreman/middleware/logging_context_request.rb:11:in `call'
cea7ea9d | katello (4.5.1) lib/katello/prevent_json_parsing.rb:12:in `call'
2023-06-21T08:12:46 [I|app|33be8f01] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:12:46 -0600
2023-06-21T08:12:46 [I|app|33be8f01] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:12:46 [I|app|33be8f01] Completed 200 OK in 6ms (Views: 0.1ms | ActiveRecord: 0.9ms | Allocations: 1797)
2023-06-21T08:12:58 [I|app|58c18104] Started POST "/framework/skeletons/wlsconsole/js/%252E%252E%252Fconsole.portal" for 137.201.104.186 at 2023-06-21 08:12:58 -0600
2023-06-21T08:12:58 [F|app|58c18104]
58c18104 | ActionController::RoutingError (No route matches [POST] "/framework/skeletons/wlsconsole/js/%252E%252E%252Fconsole.portal"):
58c18104 |
58c18104 | lib/foreman/middleware/logging_context_request.rb:11:in `call'
58c18104 | katello (4.5.1) lib/katello/prevent_json_parsing.rb:12:in `call'
2023-06-21T08:13:19 [I|app|6b55c117] Started POST "/console/framework/skeletons/wlsconsole/css/%252E%252E%252Fconsole.portal" for 137.201.104.186 at 2023-06-21 08:13:19 -0600
2023-06-21T08:13:19 [F|app|6b55c117]
6b55c117 | ActionController::RoutingError (No route matches [POST] "/console/framework/skeletons/wlsconsole/css/%252E%252E%252Fconsole.portal"):
6b55c117 |
6b55c117 | lib/foreman/middleware/logging_context_request.rb:11:in `call'
6b55c117 | katello (4.5.1) lib/katello/prevent_json_parsing.rb:12:in `call'
2023-06-21T08:14:06 [I|app|e2dfa3d3] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:14:06 -0600
2023-06-21T08:14:06 [I|app|e2dfa3d3] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:14:06 [I|app|e2dfa3d3] Completed 200 OK in 8ms (Views: 0.1ms | ActiveRecord: 1.4ms | Allocations: 1797)
2023-06-21T08:14:07 [I|app|d1fd1325] Started GET "/discovered_hosts" for 10.68.25.98 at 2023-06-21 08:14:07 -0600
2023-06-21T08:14:07 [I|app|d1fd1325] Processing by DiscoveredHostsController#index as HTML
2023-06-21T08:14:07 [I|app|d1fd1325] Rendering /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-21.0.5/app/views/discovered_hosts/index.html.erb within layouts/application
2023-06-21T08:14:07 [I|app|d1fd1325] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-21.0.5/app/views/discovered_hosts/_discovered_host.html.erb (Duration: 4.5ms | Allocations: 6639)
2023-06-21T08:14:08 [I|app|d1fd1325] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-21.0.5/app/views/discovered_hosts/_discovered_host_modal.html.erb (Duration: 10.1ms | Allocations: 8734)
2023-06-21T08:14:08 [I|app|d1fd1325] Rendered common/_pagination.html.erb (Duration: 3.6ms | Allocations: 5750)
2023-06-21T08:14:08 [I|app|d1fd1325] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-21.0.5/app/views/discovered_hosts/_discovered_hosts_list.html.erb (Duration: 25.4ms | Allocations: 30110)
2023-06-21T08:14:08 [I|app|d1fd1325] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-21.0.5/app/views/discovered_hosts/index.html.erb within layouts/application (Duration: 30.7ms | Allocations: 36565)
2023-06-21T08:14:08 [I|app|d1fd1325] Rendered layouts/_application_content.html.erb (Duration: 3.0ms | Allocations: 6098)
2023-06-21T08:14:08 [I|app|d1fd1325] Rendering layouts/base.html.erb
2023-06-21T08:14:08 [I|app|d1fd1325] Rendered layouts/base.html.erb (Duration: 17.1ms | Allocations: 24214)
2023-06-21T08:14:08 [I|app|d1fd1325] Completed 200 OK in 75ms (Views: 53.2ms | ActiveRecord: 6.0ms | Allocations: 80629)
2023-06-21T08:14:09 [I|app|7401e286] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:14:09 -0600
2023-06-21T08:14:09 [I|app|7401e286] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:14:09 [I|app|7401e286] Completed 200 OK in 5ms (Views: 0.1ms | ActiveRecord: 0.8ms | Allocations: 1813)
2023-06-21T08:14:18 [I|app|19481264] Started GET "/discovered_hosts/mac00505681f807/edit?utf8=%E2%9C%93&host%5Bhostgroup_id%5D=10&host%5Borganization_id%5D=1&host%5Blocation_id%5D=8" for 10.68.25.98 at 2023-06-21 08:14:18 -0600
2023-06-21T08:14:18 [I|app|19481264] Processing by DiscoveredHostsController#edit as HTML
2023-06-21T08:14:18 [I|app|19481264] Parameters: {"utf8"=>"✓", "host"=>{"hostgroup_id"=>"10", "organization_id"=>"1", "location_id"=>"8"}, "id"=>"mac00505681f807"}
2023-06-21T08:14:18 [I|app|19481264] Rendering /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-21.0.5/app/views/discovered_hosts/edit.html.erb within layouts/application
2023-06-21T08:14:18 [I|app|19481264] Rendered hosts/_progress.html.erb (Duration: 4.0ms | Allocations: 5766)
2023-06-21T08:14:18 [I|app|19481264] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.5.1/app/views/overrides/activation_keys/_host_environment_select.html.erb (Duration: 17.4ms | Allocations: 10766)
2023-06-21T08:14:18 [I|app|19481264] Rendered nic/_base_form.html.erb (Duration: 34.9ms | Allocations: 23781)
2023-06-21T08:14:18 [I|app|19481264] Rendered nic/_virtual_form.html.erb (Duration: 5.8ms | Allocations: 6577)
2023-06-21T08:14:18 [I|app|19481264] Rendered nic/_provider_specific_form.html.erb (Duration: 4.2ms | Allocations: 5692)
2023-06-21T08:14:18 [I|app|19481264] Rendered nic/manageds/_managed.html.erb (Duration: 54.1ms | Allocations: 48194)
2023-06-21T08:14:18 [I|app|19481264] Rendered nic/_base_form.html.erb (Duration: 33.1ms | Allocations: 24239)
2023-06-21T08:14:18 [I|app|19481264] Rendered nic/_virtual_form.html.erb (Duration: 4.9ms | Allocations: 6574)
2023-06-21T08:14:18 [I|app|19481264] Rendered nic/_provider_specific_form.html.erb (Duration: 3.1ms | Allocations: 5688)
2023-06-21T08:14:18 [I|app|19481264] Rendered nic/manageds/_managed.html.erb (Duration: 48.7ms | Allocations: 48631)
2023-06-21T08:14:18 [I|app|19481264] Rendered hosts/_interfaces.html.erb (Duration: 109.3ms | Allocations: 103176)
2023-06-21T08:14:18 [I|app|19481264] Rendered common/os_selection/_architecture.html.erb (Duration: 6.9ms | Allocations: 7209)
2023-06-21T08:14:18 [I|app|19481264] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_bootdisk-19.0.7/app/views/hosts/provision_method/bootdisk/_form.html.erb (Duration: 3.8ms | Allocations: 5762)
2023-06-21T08:14:18 [I|app|40a000c9] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:14:18 -0600
2023-06-21T08:14:18 [I|app|40a000c9] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:14:18 [I|app|40a000c9] Completed 200 OK in 6ms (Views: 0.1ms | ActiveRecord: 0.8ms | Allocations: 1797)
2023-06-21T08:14:18 [I|app|19481264] Rendered common/os_selection/_pxe_loader.html.erb (Duration: 5.8ms | Allocations: 6436)
2023-06-21T08:14:18 [I|app|19481264] Rendered common/os_selection/_operatingsystem.html.erb (Duration: 46.7ms | Allocations: 29868)
2023-06-21T08:14:18 [I|app|19481264] Rendered hosts/provision_method/build/_form.html.erb (Duration: 51.0ms | Allocations: 36245)
2023-06-21T08:14:18 [I|app|19481264] Rendered hosts/provision_method/image/_form.html.erb (Duration: 4.2ms | Allocations: 5698)
2023-06-21T08:14:18 [I|app|19481264] Rendered hosts/_operating_system.html.erb (Duration: 73.7ms | Allocations: 62992)
2023-06-21T08:14:18 [I|app|19481264] Rendered hosts/_unattended.html.erb (Duration: 77.3ms | Allocations: 68759)
2023-06-21T08:14:18 [I|app|19481264] Rendered common_parameters/_inherited_parameters.html.erb (Duration: 6.9ms | Allocations: 8122)
2023-06-21T08:14:18 [I|app|19481264] Rendered common_parameters/_parameter.html.erb (Duration: 5.2ms | Allocations: 6861)
2023-06-21T08:14:18 [I|app|19481264] Rendered common_parameters/_parameters.html.erb (Duration: 10.8ms | Allocations: 13347)
2023-06-21T08:14:18 [I|app|19481264] Rendered hosts/_form.html.erb (Duration: 283.2ms | Allocations: 240650)
2023-06-21T08:14:18 [I|app|19481264] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-21.0.5/app/views/discovered_hosts/edit.html.erb within layouts/application (Duration: 288.1ms | Allocations: 246442)
2023-06-21T08:14:19 [W|app|19481264] unable to detect breadcrumb title name in for discovered_hosts, defaulting to name
2023-06-21T08:14:19 [I|app|19481264] Rendered layouts/_application_content.html.erb (Duration: 7.8ms | Allocations: 6175)
2023-06-21T08:14:19 [I|app|19481264] Rendering layouts/base.html.erb
2023-06-21T08:14:19 [I|app|19481264] Rendered layouts/base.html.erb (Duration: 21.0ms | Allocations: 24214)
2023-06-21T08:14:19 [I|app|19481264] Completed 200 OK in 380ms (Views: 305.7ms | ActiveRecord: 28.8ms | Allocations: 303099)
2023-06-21T08:14:20 [I|app|a355d293] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:14:20 -0600
2023-06-21T08:14:20 [I|app|a355d293] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:14:20 [I|app|a355d293] Completed 200 OK in 6ms (Views: 0.1ms | ActiveRecord: 0.9ms | Allocations: 1813)
2023-06-21T08:14:20 [I|app|1b79685f] Started GET "/ansible/ui_ansible_roles?page=1&per_page=10&search=&resource_id=190&resource_name=Host" for 10.68.25.98 at 2023-06-21 08:14:20 -0600
2023-06-21T08:14:20 [I|app|1b79685f] Processing by UiAnsibleRolesController#index as JSON
2023-06-21T08:14:20 [I|app|1b79685f] Parameters: {"page"=>"1", "per_page"=>"10", "search"=>"", "resource_id"=>"190", "resource_name"=>"Host"}
2023-06-21T08:14:20 [I|app|1b79685f] Rendering /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_ansible-7.1.4/app/views/ui_ansible_roles/index.json.rabl within api/v2/layouts/index_layout
2023-06-21T08:14:20 [I|app|1b79685f] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_ansible-7.1.4/app/views/ui_ansible_roles/index.json.rabl within api/v2/layouts/index_layout (Duration: 5.9ms | Allocations: 5876)
2023-06-21T08:14:20 [I|app|1b79685f] Completed 200 OK in 17ms (Views: 10.8ms | ActiveRecord: 1.3ms | Allocations: 13868)
2023-06-21T08:14:30 [I|app|6fa82d6b] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:14:30 -0600
2023-06-21T08:14:30 [I|app|6fa82d6b] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:14:30 [I|app|6fa82d6b] Completed 200 OK in 6ms (Views: 0.1ms | ActiveRecord: 1.4ms | Allocations: 1797)
2023-06-21T08:14:36 [I|app|ab1a3148] Started GET "/katello/api/v2/content_views/?environment_id=1&full_result=true" for 10.68.25.98 at 2023-06-21 08:14:36 -0600
2023-06-21T08:14:36 [I|app|ab1a3148] Processing by Katello::Api::V2::ContentViewsController#index as */*
2023-06-21T08:14:36 [I|app|ab1a3148] Parameters: {"environment_id"=>"1", "full_result"=>"true", "api_version"=>"v2"}
2023-06-21T08:14:36 [I|app|ab1a3148] Rendering /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.5.1/app/views/katello/api/v2/content_views/index.json.rabl within katello/api/v2/layouts/collection
2023-06-21T08:14:36 [I|app|ab1a3148] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.5.1/app/views/katello/api/v2/content_views/index.json.rabl within katello/api/v2/layouts/collection (Duration: 27.4ms | Allocations: 12126)
2023-06-21T08:14:36 [I|app|ab1a3148] Completed 200 OK in 40ms (Views: 24.7ms | ActiveRecord: 7.9ms | Allocations: 18454)
2023-06-21T08:14:37 [I|app|0f6ec956] Started POST "/os_selected_discovered_hosts" for 10.68.25.98 at 2023-06-21 08:14:37 -0600
2023-06-21T08:14:37 [I|app|0f6ec956] Processing by HostsController#os_selected as */*
2023-06-21T08:14:37 [I|app|0f6ec956] Parameters: {"discovered_host"=>{"operatingsystem_id"=>"24", "organization_id"=>"1", "location_id"=>"8", "lifecycle_environment_id"=>"1", "content_view_id"=>"1", "environment_id"=>"1", "content_source_id"=>"3", "architecture_id"=>"1"}}
2023-06-21T08:14:37 [I|app|0f6ec956] Rendered common/os_selection/_pxe_loader.html.erb (Duration: 5.1ms | Allocations: 6412)
2023-06-21T08:14:37 [I|app|0f6ec956] Rendered common/os_selection/_operatingsystem.html.erb (Duration: 58.4ms | Allocations: 35828)
2023-06-21T08:14:37 [I|app|0f6ec956] Completed 200 OK in 77ms (Views: 54.2ms | ActiveRecord: 7.5ms | Allocations: 43573)
2023-06-21T08:14:37 [I|app|d243f831] Started POST "/hosts/current_parameters" for 10.68.25.98 at 2023-06-21 08:14:37 -0600
2023-06-21T08:14:37 [I|app|d243f831] Processing by HostsController#current_parameters as */*
2023-06-21T08:14:37 [I|app|d243f831] Parameters: {"utf8"=>"✓", "authenticity_token"=>"JppJ2zcd7S4iQprzhDxXM01lj0VmytOEP6V7/llmCWg5IATNJuNhWC/FUev8JiTuVMil85ZqIwu0IY0OKAn6YQ==", "host"=>{"name"=>"hylsubhvm", "organization_id"=>"1", "location_id"=>"8", "hostgroup_id"=>"10", "content_facet_attributes"=>{"lifecycle_environment_id"=>"1", "content_view_id"=>"1", "content_source_id"=>"3"}, "managed"=>"true", "progress_report_id"=>"[FILTERED]", "type"=>"Host::Managed", "interfaces_attributes"=>{"0"=>{"_destroy"=>"0", "mac"=>"00:50:56:81:f8:07", "identifier"=>"ens192", "name"=>"hylsubhvm", "domain_id"=>"1", "subnet_id"=>"2", "ip"=>"10.70.87.114", "ip6"=>"", "managed"=>"1", "primary"=>"1", "provision"=>"1", "execution"=>"0", "tag"=>"", "attached_to"=>"", "id"=>"200"}}, "architecture_id"=>"1", "operatingsystem_id"=>"24", "build"=>"1", "medium_id"=>"", "ptable_id"=>"", "pxe_loader"=>"PXELinux BIOS", "disk"=>"", "is_owned_by"=>"", "enabled"=>"1", "model_id"=>"1", "comment"=>"", "overwrite"=>"false"}, "media_selector"=>"install_media", "fakepassword"=>"[FILTERED]", "host_id"=>"190"}
2023-06-21T08:14:37 [I|app|d243f831] Rendered common_parameters/_inherited_parameters.html.erb (Duration: 6.9ms | Allocations: 8116)
2023-06-21T08:14:37 [I|app|d243f831] Completed 200 OK in 53ms (Views: 7.1ms | ActiveRecord: 8.8ms | Allocations: 30140)
2023-06-21T08:14:40 [I|app|a6895a8a] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:14:40 -0600
2023-06-21T08:14:40 [I|app|a6895a8a] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:14:40 [I|app|a6895a8a] Completed 200 OK in 8ms (Views: 0.1ms | ActiveRecord: 1.5ms | Allocations: 1804)
2023-06-21T08:14:40 [I|app|8eda3abc] Started POST "/hosts/medium_selected" for 10.68.25.98 at 2023-06-21 08:14:40 -0600
2023-06-21T08:14:40 [I|app|8eda3abc] Processing by HostsController#medium_selected as */*
2023-06-21T08:14:40 [I|app|8eda3abc] Parameters: {"host"=>{"medium_id"=>"29", "operatingsystem_id"=>"24", "architecture_id"=>"1", "use_image"=>"false"}}
2023-06-21T08:14:40 [I|app|8eda3abc] Rendered common/os_selection/_image_details.html.erb (Duration: 8.8ms | Allocations: 6618)
2023-06-21T08:14:40 [I|app|8eda3abc] Completed 200 OK in 21ms (Views: 9.2ms | ActiveRecord: 1.5ms | Allocations: 11469)
2023-06-21T08:14:50 [I|app|76dad2f4] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:14:50 -0600
2023-06-21T08:14:50 [I|app|76dad2f4] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:14:50 [I|app|76dad2f4] Completed 200 OK in 5ms (Views: 0.1ms | ActiveRecord: 0.8ms | Allocations: 1797)
2023-06-21T08:14:55 [I|app|42c325cb] Started PATCH "/discovered_hosts/190" for 10.68.25.98 at 2023-06-21 08:14:55 -0600
2023-06-21T08:14:55 [I|app|42c325cb] Processing by DiscoveredHostsController#update as */*
2023-06-21T08:14:55 [I|app|42c325cb] Parameters: {"utf8"=>"✓", "authenticity_token"=>"JppJ2zcd7S4iQprzhDxXM01lj0VmytOEP6V7/llmCWg5IATNJuNhWC/FUev8JiTuVMil85ZqIwu0IY0OKAn6YQ==", "host"=>{"name"=>"hylsubhvm", "organization_id"=>"1", "location_id"=>"8", "hostgroup_id"=>"10", "content_facet_attributes"=>{"lifecycle_environment_id"=>"1", "content_view_id"=>"1", "content_source_id"=>"3"}, "managed"=>"true", "progress_report_id"=>"[FILTERED]", "type"=>"Host::Managed", "interfaces_attributes"=>{"0"=>{"_destroy"=>"0", "mac"=>"00:50:56:81:f8:07", "identifier"=>"ens192", "name"=>"hylsubhvm", "domain_id"=>"1", "subnet_id"=>"2", "ip"=>"10.70.87.114", "ip6"=>"", "managed"=>"1", "primary"=>"1", "provision"=>"1", "execution"=>"0", "tag"=>"", "attached_to"=>"", "id"=>"200"}}, "architecture_id"=>"1", "operatingsystem_id"=>"24", "build"=>"1", "medium_id"=>"29", "ptable_id"=>"135", "pxe_loader"=>"PXELinux BIOS", "disk"=>"", "is_owned_by"=>"4-Users", "enabled"=>"1", "model_id"=>"1", "comment"=>"", "overwrite"=>"false"}, "media_selector"=>"install_media", "id"=>"190"}
2023-06-21T08:14:56 [I|app|42c325cb] Deploying TFTP PXELinux configuration for hylsubhvm.micron.com
2023-06-21T08:14:56 [I|app|42c325cb] Skipping TFTP PXEGrub2 configuration for hylsubhvm.micron.com
2023-06-21T08:14:56 [I|app|42c325cb] Skipping TFTP PXEGrub configuration for hylsubhvm.micron.com
2023-06-21T08:14:56 [I|app|42c325cb] Skipping TFTP iPXE configuration for hylsubhvm.micron.com
2023-06-21T08:14:56 [I|app|42c325cb] Fetching required TFTP boot files for hylsubhvm.micron.com
2023-06-21T08:14:56 [I|app|42c325cb] Processed 6 tasks from queue 'Host::Managed Main', completed 6/6
2023-06-21T08:14:56 [I|aud|42c325cb] Host::Base (190) update event on name mac00505681f807, hylsubhvm.micron.com
2023-06-21T08:14:56 [I|aud|42c325cb] Host::Base (190) update event on architecture_id , 1
2023-06-21T08:14:56 [I|aud|42c325cb] Host::Base (190) update event on operatingsystem_id , 24
2023-06-21T08:14:56 [I|aud|42c325cb] Host::Base (190) update event on ptable_id , 135
2023-06-21T08:14:56 [I|aud|42c325cb] Host::Base (190) update event on medium_id , 29
2023-06-21T08:14:56 [I|aud|42c325cb] Host::Base (190) update event on build false, true
2023-06-21T08:14:56 [I|aud|42c325cb] Host::Base (190) update event on comment ,
2023-06-21T08:14:56 [I|aud|42c325cb] Host::Base (190) update event on disk ,
2023-06-21T08:14:56 [I|aud|42c325cb] Host::Base (190) update event on hostgroup_id , 10
2023-06-21T08:14:56 [I|aud|42c325cb] Host::Base (190) update event on owner_id 1, 4
2023-06-21T08:14:56 [I|aud|42c325cb] Host::Base (190) update event on managed false, true
2023-06-21T08:14:56 [I|aud|42c325cb] Host::Base (190) update event on grub_pass ,
2023-06-21T08:14:56 [I|aud|42c325cb] Host::Base (190) update event on pxe_loader , PXELinux BIOS
2023-06-21T08:14:56 [I|aud|42c325cb] Nic::Managed (200) update event on name mac00505681f807, hylsubhvm.micron.com
2023-06-21T08:14:56 [I|aud|42c325cb] Nic::Managed (200) update event on domain_id , 1
2023-06-21T08:14:56 [I|aud|42c325cb] Nic::Managed (200) update event on ip6 ,
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on host_id 190
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on uuid
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on content_view_id 1
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on lifecycle_environment_id 1
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on kickstart_repository_id
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on content_source_id 3
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on installable_security_errata_count 0
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on installable_enhancement_errata_count 0
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on installable_bugfix_errata_count 0
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on applicable_rpm_count 0
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on upgradable_rpm_count 0
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on applicable_module_stream_count 0
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on upgradable_module_stream_count 0
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on applicable_deb_count 0
2023-06-21T08:14:56 [I|aud|42c325cb] Katello::Host::ContentFacet (133) create event on upgradable_deb_count 0
2023-06-21T08:14:57 [I|app|1e4b368a] Started GET "/tasks/878626e8-3170-420c-8894-3104e51865fe" for 10.68.25.98 at 2023-06-21 08:14:57 -0600
2023-06-21T08:14:57 [I|app|1e4b368a] Processing by TasksController#show as */*
2023-06-21T08:14:57 [I|app|1e4b368a] Parameters: {"id"=>"878626e8-3170-420c-8894-3104e51865fe"}
2023-06-21T08:14:57 [I|app|1e4b368a] Rendered tasks/_list.html.erb (Duration: 4.8ms | Allocations: 5908)
2023-06-21T08:14:57 [I|app|1e4b368a] Completed 200 OK in 12ms (Views: 5.2ms | ActiveRecord: 1.7ms | Allocations: 7738)
2023-06-21T08:14:58 [I|app|42c325cb] Processed 1 tasks from queue 'Host::Managed Post', completed 1/1
2023-06-21T08:14:58 [I|app|42c325cb] Redirected to https://boldforeman.micron.com/hosts/hylsubhvm.micron.com
2023-06-21T08:14:58 [I|app|42c325cb] Completed 302 Found in 2818ms (ActiveRecord: 47.0ms | Allocations: 143391)
2023-06-21T08:14:58 [I|app|33a50558] Started GET "/hosts/hylsubhvm.micron.com" for 10.68.25.98 at 2023-06-21 08:14:58 -0600
2023-06-21T08:14:58 [I|app|33a50558] Processing by HostsController#show as */*
2023-06-21T08:14:58 [I|app|33a50558] Parameters: {"id"=>"hylsubhvm.micron.com"}
2023-06-21T08:14:58 [I|app|33a50558] Rendering hosts/show.html.erb within layouts/application
2023-06-21T08:14:58 [I|app|33a50558] Rendered hosts/_init_config_tab.html.erb (Duration: 31.3ms | Allocations: 15176)
2023-06-21T08:14:58 [I|app|33a50558] Rendered hosts/show.html.erb within layouts/application (Duration: 52.4ms | Allocations: 27750)
2023-06-21T08:14:58 [I|app|33a50558] Rendered layouts/_application_content.html.erb (Duration: 4.5ms | Allocations: 5714)
2023-06-21T08:14:58 [I|app|33a50558] Rendering layouts/base.html.erb
2023-06-21T08:14:58 [I|app|33a50558] Rendered layouts/base.html.erb (Duration: 22.6ms | Allocations: 24359)
2023-06-21T08:14:58 [I|app|33a50558] Completed 200 OK in 98ms (Views: 75.0ms | ActiveRecord: 13.2ms | Allocations: 67452)
2023-06-21T08:14:58 [I|app|63ee36a2] Started GET "/tasks/878626e8-3170-420c-8894-3104e51865fe" for 10.68.25.98 at 2023-06-21 08:14:58 -0600
2023-06-21T08:14:58 [I|app|63ee36a2] Processing by TasksController#show as */*
2023-06-21T08:14:58 [I|app|63ee36a2] Parameters: {"id"=>"878626e8-3170-420c-8894-3104e51865fe"}
2023-06-21T08:14:58 [I|app|63ee36a2] Rendered tasks/_list.html.erb (Duration: 4.5ms | Allocations: 5907)
2023-06-21T08:14:58 [I|app|63ee36a2] Completed 200 OK in 10ms (Views: 4.9ms | ActiveRecord: 1.3ms | Allocations: 7645)
2023-06-21T08:14:59 [I|app|558a7be7] Started GET "/hosts/hylsubhvm.micron.com/overview" for 10.68.25.98 at 2023-06-21 08:14:59 -0600
2023-06-21T08:14:59 [I|app|558a7be7] Processing by HostsController#overview as HTML
2023-06-21T08:14:59 [I|app|558a7be7] Parameters: {"id"=>"hylsubhvm.micron.com"}
2023-06-21T08:14:59 [I|app|558a7be7] Rendered hosts/_overview.html.erb (Duration: 20.6ms | Allocations: 11944)
2023-06-21T08:14:59 [I|app|558a7be7] Completed 200 OK in 30ms (Views: 18.0ms | ActiveRecord: 4.6ms | Allocations: 15061)
2023-06-21T08:14:59 [I|app|9abe8c7f] Started GET "/hosts/hylsubhvm.micron.com/templates" for 10.68.25.98 at 2023-06-21 08:14:59 -0600
2023-06-21T08:14:59 [I|app|49082595] Started GET "/hosts/hylsubhvm.micron.com/nics" for 10.68.25.98 at 2023-06-21 08:14:59 -0600
2023-06-21T08:14:59 [I|app|9abe8c7f] Processing by HostsController#templates as HTML
2023-06-21T08:14:59 [I|app|9abe8c7f] Parameters: {"id"=>"hylsubhvm.micron.com"}
2023-06-21T08:14:59 [I|app|49082595] Processing by HostsController#nics as HTML
2023-06-21T08:14:59 [I|app|49082595] Parameters: {"id"=>"hylsubhvm.micron.com"}
2023-06-21T08:14:59 [I|app|49082595] Rendered hosts/_nics.html.erb (Duration: 15.0ms | Allocations: 9179)
2023-06-21T08:14:59 [I|app|49082595] Completed 200 OK in 24ms (Views: 13.9ms | ActiveRecord: 3.3ms | Allocations: 12279)
2023-06-21T08:14:59 [I|app|e10725d1] Started GET "/hosts/hylsubhvm.micron.com/runtime?range=7" for 10.68.25.98 at 2023-06-21 08:14:59 -0600
2023-06-21T08:14:59 [I|app|e10725d1] Processing by HostsController#runtime as HTML
2023-06-21T08:14:59 [I|app|e10725d1] Parameters: {"range"=>"7", "id"=>"hylsubhvm.micron.com"}
2023-06-21T08:14:59 [I|app|e10725d1] Rendered hosts/_runtime.html.erb (Duration: 9.6ms | Allocations: 7136)
2023-06-21T08:14:59 [I|app|e10725d1] Completed 200 OK in 35ms (Views: 8.5ms | ActiveRecord: 13.4ms | Allocations: 19227)
2023-06-21T08:14:59 [I|app|9abe8c7f] Rendered hosts/_templates.html.erb (Duration: 10.7ms | Allocations: 8670)
2023-06-21T08:14:59 [I|app|9abe8c7f] Completed 200 OK in 125ms (Views: 10.6ms | ActiveRecord: 52.5ms | Allocations: 60469)
2023-06-21T08:14:59 [I|app|cc38a382] Started GET "/hosts/hylsubhvm.micron.com/resources?range=7" for 10.68.25.98 at 2023-06-21 08:14:59 -0600
2023-06-21T08:14:59 [I|app|cc38a382] Processing by HostsController#resources as HTML
2023-06-21T08:14:59 [I|app|cc38a382] Parameters: {"range"=>"7", "id"=>"hylsubhvm.micron.com"}
2023-06-21T08:14:59 [I|app|cc38a382] Rendered hosts/_resources.html.erb (Duration: 7.1ms | Allocations: 6438)
2023-06-21T08:14:59 [I|app|cc38a382] Completed 200 OK in 16ms (Views: 6.8ms | ActiveRecord: 2.4ms | Allocations: 9539)
2023-06-21T08:15:10 [I|app|9135753c] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:15:10 -0600
2023-06-21T08:15:10 [I|app|9135753c] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:15:10 [I|app|9135753c] Completed 200 OK in 38ms (Views: 0.1ms | ActiveRecord: 2.8ms | Allocations: 4718)
2023-06-21T08:16:00 [I|app|c8eca952] Started GET "/notification_recipients" for 10.68.25.98 at 2023-06-21 08:16:00 -0600
2023-06-21T08:16:00 [I|app|c8eca952] Processing by NotificationRecipientsController#index as JSON
2023-06-21T08:16:00 [I|app|c8eca952] Completed 200 OK in 8ms (Views: 0.1ms | ActiveRecord: 1.8ms | Allocations: 1888)
[root@boldforeman foreman]# cat /var/log/foreman-proxy/proxy.log
2023-06-21T08:12:25 cc4d65c7 [I] Started DELETE /tftp/PXELinux/00:50:56:81:f8:07
2023-06-21T08:12:25 cc4d65c7 [I] Finished DELETE /tftp/PXELinux/00:50:56:81:f8:07 with 200 (0.78 ms)
2023-06-21T08:12:25 cc4d65c7 [I] Started DELETE /tftp/PXEGrub2/00:50:56:81:f8:07
2023-06-21T08:12:25 cc4d65c7 [I] Finished DELETE /tftp/PXEGrub2/00:50:56:81:f8:07 with 200 (0.62 ms)
2023-06-21T08:12:25 cc4d65c7 [I] Started DELETE /tftp/PXEGrub/00:50:56:81:f8:07
2023-06-21T08:12:25 cc4d65c7 [I] Finished DELETE /tftp/PXEGrub/00:50:56:81:f8:07 with 200 (0.52 ms)
2023-06-21T08:12:25 cc4d65c7 [I] Started DELETE /tftp/iPXE/00:50:56:81:f8:07
2023-06-21T08:12:25 cc4d65c7 [I] Finished DELETE /tftp/iPXE/00:50:56:81:f8:07 with 200 (0.97 ms)
2023-06-21T08:13:53 [I] Execution plan cleaner removing 0 execution plans.
2023-06-21T08:14:56 42c325cb [I] Started POST /tftp/PXELinux/00:50:56:81:f8:07
2023-06-21T08:14:56 42c325cb [I] Finished POST /tftp/PXELinux/00:50:56:81:f8:07 with 200 (1.0 ms)
2023-06-21T08:14:56 42c325cb [I] Started POST /tftp/fetch_boot_file
2023-06-21T08:14:56 42c325cb [I] Finished POST /tftp/fetch_boot_file with 200 (1.76 ms)
2023-06-21T08:14:56 42c325cb [I] [19395] Started task /usr/bin/curl\ --silent\ --show-error\ --connect-timeout\ 10\ --retry\ 3\ --retry-delay\ 10\ --max-time\ 3600\ --remote-time\ --time-cond\ /var/lib/tftpboot/boot/ubuntu22-04-ApFTaUh8twX1-vmlinuz\ --write-out\ Task\ done,\ result:\ \%\{http_code\},\ size\ downloaded:\ \%\{size_download\}b,\ speed:\ \%\{speed_download\}b/s,\ time:\ \%\{time_total\}ms\ --output\ /var/lib/tftpboot/boot/ubuntu22-04-ApFTaUh8twX1-vmlinuz\ --location\ http://ptks.micron.com/linux/ubuntu/22.04/dists/jammy/main/installer-amd64/current/legacy-images/netboot/ubuntu-installer/amd64/vmlinuz
2023-06-21T08:14:56 42c325cb [I] Finished POST /tftp/fetch_boot_file with 200 (0.96 ms)
2023-06-21T08:14:56 42c325cb [I] [19399] Started task /usr/bin/curl\ --silent\ --show-error\ --connect-timeout\ 10\ --retry\ 3\ --retry-delay\ 10\ --max-time\ 3600\ --remote-time\ --time-cond\ /var/lib/tftpboot/boot/ubuntu22-04-ApFTaUh8twX1-initrd\ --write-out\ Task\ done,\ result:\ \%\{http_code\},\ size\ downloaded:\ \%\{size_download\}b,\ speed:\ \%\{speed_download\}b/s,\ time:\ \%\{time_total\}ms\ --output\ /var/lib/tftpboot/boot/ubuntu22-04-ApFTaUh8twX1-initrd\ --location\ http://ptks.micron.com/linux/ubuntu/22.04/dists/jammy/main/installer-amd64/current/legacy-images/netboot/ubuntu-installer/amd64/initrd
for below screenshot i have observed
Started task /usr/bin/curl\ –silent\ –show-error\ –connect-timeout\ 10\ –retry\ 3\ –retry-delay\ 10\ –max-time\ 3600\ –remote-time\ –time-cond\ /var/lib/tftpboot/boot/ubuntu22-04-ApFTaUh8twX1-initrd\ –write-out\ Task\ done,\ result:\ %{http_code},\ size\ downloaded:\ %{size_download}b,\ speed:\ %{speed_download}b/s,\ time:\ %{time_total}ms\ –output\ /var/lib/tftpboot/boot/ubuntu22-04-ApFTaUh8twX1-initrd\ –location\ Sign in to your account
location Sign in to your account
but in my installation media we have binary-amd64 instead of installed-amd64
is this problem?
in my installation media we have below folder
when i verified about proxy log which is seems to be different location
if anything, wrong please suggest me
The path you marked where your proxy tries to download the initrd and vmlinuz seem wrong.
I just checked your Foreman version and with Foreman 3.3, there is no support for Ubuntu 20.04.3+ deployment - sorry for mentioning so late, but I thought you would try to deploy older Ubuntu versions.
So, I recommend you to update your Foreman. We had the same issue in this thread:
Foreman 3.4 supports Ubuntu deployment. Still, the best versions of all templates do you get with the latest Foreman release (3.6.1).
can we able to install below version of the servers less than Ubuntu 20.04.3 using foreman 3.3 version?
Please let me know which ubuntu version is supported for foreman3.3 version server so i will try to install.
thank you for your suggestion to upgrade Firmware version.
just i have few doubts if you answer below questions, it would be great help for me .
Currently we have foreman 3.3.1 version which is on centos7 .
- Can we able to upgrade the firmware version from 3.3.1 to 3.6.1?
2)Currently we have foreman 3.3 version so will you able to suggest me which ubuntu operating system is able to install using current formware3.3 version?
Hey!
Answering your questions below.
1.) I can’t help with the upgrade, sry. I think you should open a new thread if you need help with the upgrade progress.
2.) Foreman 3.3.1 supports Ubuntu up to version 20.04.3. That is the last version which supports the Debian installer.
I would recommend upgrading your Foreman. Please, have a look which CentOS/RHEL version is necessary for Foreman 3.6.1.
I hope this helps.
as per your suggestion i have deployed foreman on 3.7 on Alma Linux El8 also created operating system using ubuntu-20.04.6-live-server-amd64.iso.
Please let me know what are the templates needs to be associate apart from below.
