I can not install RHEL 8.3 (RHEL 7 is working) with UEFI but with Legacy it is working.
I have try it with different grubx64.efi (/var/lib/tftpboot/grub2) with no succes.
With default grub2.efi i get:
With grub2.efi from RHEL 8.3 i get:
What else can i try?
foreman-2.1.4-1.el7.noarch
katello-3.16.2-1.el7.noarch
Those modprobe: command not found errors are really weird. Your init RAM disk is likely corrupted. Delete it and rebuild the host to redownload it from scratch.
Edit: Before you delete the initramdisk use lsinitrd to list the contents of the image. That command should error out if there is a problem.
