Error initializing command: RuntimeError - Unable to create directory on remote system /var/tmp/foreman-ssh-cmd-59622865-f6b6-469d-b3a2-8468b1279902: exit code: 255
2:
ssh_exchange_identification: Connection closed by remote host
3:
Exit status: EXCEPTION
Trying to run remote job on host just to echo hello world.
Have just set up Foreman 3.2 with katello 4.4
Installing Foreman 3.2 server with Katello 4.4 plugin on Enterprise Linux followed this manual.
enabled at install foreman_proxy_plugin_remote_execution_ssh,foreman_plugin_remote_execution
Can do passwordless ssh -i ~foreman-proxy/.ssh/id_rsa_foreman_proxy root@...
Have tried scp -v -i ~foreman-proxy/.ssh/id_rsa_foreman_proxy file1 root@...:/var/tmp/file1
file1 appears into host /var/tmp
Job to run successfully.
Foreman version:
Foreman 3.2
CentOS Linux release 7.9.2009
DEBUG from command= scp -v -i ~foreman-proxy/.ssh/id_rsa_foreman_proxy file1 root@...:/var/tmp/file1
Executing: program /usr/bin/ssh host **.**.**.**, user root, command scp -v -t /var/tmp/file1
OpenSSH_7.4p1, OpenSSL 1.0.2k-fips 26 Jan 2017
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 62: Applying options for *
debug1: Executing proxy command: exec /usr/bin/sss_ssh_knownhostsproxy -p 22 **.**.**.**
debug1: identity file /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy type 1
debug1: permanently_drop_suid: 1753000023
debug1: key_load_public: No such file or directory
debug1: identity file /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_7.4
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.4
debug1: match: OpenSSH_7.4 pat OpenSSH* compat 0x04000000
debug1: Authenticating to 10.13.13.70:22 as 'root'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: curve25519-sha256 need=64 dh_need=64
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:+0j2x7a0N7PfUaNI7WBlxiibMJj43jUYLMZrqGy2xoU
debug1: Host '**.**.**.**' is known and matches the ECDSA host key.
debug1: Found key in /var/lib/sss/pubconf/known_hosts:6
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<rsa-sha2-256,rsa-sha2-512>
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,gssapi-keyex,gssapi-with-mic,password,keyboard-interactive
debug1: Next authentication method: gssapi-keyex
debug1: No valid Key exchange context
debug1: Next authentication method: gssapi-with-mic
debug1: Unspecified GSS failure. Minor code may provide more information
Server host/**.**.**.**@***.***.***** not found in Kerberos database
debug1: Next authentication method: publickey
debug1: Offering RSA public key: /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy
debug1: Server accepts key: pkalg rsa-sha2-512 blen 279
debug1: Authentication succeeded (publickey).
Authenticated to **.**.**.** (via proxy).
debug1: channel 0: new [client-session]
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug1: pledge: proc
debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0
debug1: Sending environment.
debug1: Sending env LANG = en_GB.UTF-8
debug1: Sending command: scp -v -t /var/tmp/file1
Sending file modes: C0664 0 file1
Sink: C0664 0 file1
file1 100% 0 0.0KB/s 00:00
debug1: client_input_channel_req: channel 0 rtype exit-status reply 0
debug1: channel 0: free: client-session, nchannels 1
debug1: fd 0 clearing O_NONBLOCK
debug1: fd 1 clearing O_NONBLOCK
Transferred: sent 3024, received 2884 bytes, in 0.1 seconds
Bytes per second: sent 42775.9, received 40795.6
debug1: Exit status 0
/var/log/foreman-proxy/proxy.log
2022-05-05T19:13:49 8cb080dc [I] Started GET /dynflow/tasks/count state=running
2022-05-05T19:13:49 8cb080dc [I] Finished GET /dynflow/tasks/count with 200 (2.3 ms)
2022-05-05T19:13:50 8cb080dc [I] Started POST /dynflow/tasks/launch
2022-05-05T19:13:50 8cb080dc [I] Finished POST /dynflow/tasks/launch with 200 (31.14 ms)
2022-05-05T19:13:50 [E] error while initializing command RuntimeError Unable to create directory on remote system /var/tmp/foreman-ssh-cmd-7399852b-84ac-4aa5-afb3-20cb12ac14d7: exit code: 255
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.5.3/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:387:in `ensure_remote_directory'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.5.3/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:361:in `upload_data'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.5.3/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:357:in `cp_script_to_remote'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.5.3/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:158:in `prepare_start'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.5.3/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:144:in `start'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_dynflow-0.7.0/lib/smart_proxy_dynflow/runner/dispatcher.rb:32:in `start_runner'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/actor.rb:13:in `on_message'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/context.rb:46:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_dynflow-0.7.0/lib/smart_proxy_dynflow/runner/dispatcher.rb:24:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/executes_context.rb:7:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/abstract.rb:25:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/actor.rb:122:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/awaits.rb:15:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/sets_results.rb:14:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/actor.rb:56:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/buffer.rb:38:in `process_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/buffer.rb:31:in `process_envelopes?'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/buffer.rb:20:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/termination.rb:55:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/removes_child.rb:10:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:162:in `process_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:96:in `block in on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:119:in `block (2 levels) in schedule_execution'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/synchronization/mutex_lockable_object.rb:41:in `block in synchronize'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/synchronization/mutex_lockable_object.rb:41:in `synchronize'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:116:in `block in schedule_execution'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/serialized_execution.rb:18:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/serialized_execution.rb:96:in `work'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/serialized_execution.rb:77:in `block in call_job'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:353:in `run_task'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:342:in `block (3 levels) in create_worker'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:325:in `loop'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:325:in `block (2 levels) in create_worker'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:324:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:324:in `block in create_worker'
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-2.3.0/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2022-05-05T19:13:50 [E] Error initializing command - RuntimeError Unable to create directory on remote system /var/tmp/foreman-ssh-cmd-7399852b-84ac-4aa5-afb3-20cb12ac14d7: exit code: 255
2022-05-05T19:13:50 [E] error while dispatching request to runner 7399852b-84ac-4aa5-afb3-20cb12ac14d7:RuntimeError Control socket file does not exist:
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.5.3/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:201:in `close_session'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.5.3/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:215:in `close'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_dynflow-0.7.0/lib/smart_proxy_dynflow/runner/dispatcher.rb:78:in `start_termination'
2022-05-05T19:13:50 8cb080dc [E] Script execution failed
2022-05-05T19:14:00 8cb080dc [E] <RuntimeError> A sub task failed
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/with_sub_plans.rb:231:in `check_for_errors!'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/with_sub_plans.rb:137:in `try_to_finish'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/with_polling_sub_plans.rb:19:in `poll'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/with_polling_sub_plans.rb:11:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:582:in `block (3 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware/stack.rb:27:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware.rb:19:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/progress.rb:31:in `with_progress_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/progress.rb:17:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware/stack.rb:23:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_dynflow-0.7.0/lib/smart_proxy_dynflow/middleware/keep_current_request_id.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_dynflow-0.7.0/lib/smart_proxy_dynflow/middleware/keep_current_request_id.rb:49:in `restore_current_request_id'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_dynflow-0.7.0/lib/smart_proxy_dynflow/middleware/keep_current_request_id.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware.rb:32:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware/world.rb:31:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:581:in `block (2 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:580:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:580:in `block in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:483:in `block in with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:483:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:483:in `with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:575:in `execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:296:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:18:in `block (2 levels) in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract.rb:167:in `with_meta_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:17:in `block in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:32:in `open_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:16:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/director.rb:94:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/executors/parallel/worker.rb:15:in `block in on_message'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/executors.rb:18:in `run_user_code'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/executors/parallel/worker.rb:14:in `on_message'
