Yesterday I did some testing with ovirt/the foreman integration. I have
several hosts discovered and deployed some yesterday.
Today I cannot deploy a discovered host anymore (didn't change
anything), I get the following errors:
ForemanDiscovery: Rebooting node2.test.nu as its being discovered
and assigned
Failed to reboot: ERF12-1772 [ProxyAPI::ProxyException]: Unable to
perform power BMC operation ([Errno::ECONNREFUSED]: Connection
refused - connect(2)) for proxy http://xx.xxx.xxx.72:8443/bmc
Rolling back due to a problem: [Rebooting node2.test.nu 10000 failed
As I said, this is weird as it worked for 2 months now and I upgraded to
The Foreman 1.6 a couple of weeks ago.
I then decided to disable BMC in /etc/foreman-proxy/settings.d/bmc.yml ,
restarted the services. But this doesn't help.
Where does it get it's BMC info from and how to disable???
Kind regards,
Jorick Astrego
Netbulae B.V.
> Hi,
> Today I cannot deploy a discovered host anymore (didn't change anything),
> ForemanDiscovery: Rebooting node2.test.nu as its being discovered and
> assigned
> Failed to reboot: ERF12-1772 [ProxyAPI::ProxyException]: Unable to perform
> power BMC operation ([Errno::ECONNREFUSED]: Connection refused -
> failed
> this implies the proxy service is not running or fw is rejecting the
connection.
Ohad
restarted the services. But this doesn’t help.
Where does it get it’s BMC info from and how to disable???
Kind regards,
Jorick Astrego
Netbulae B.V.
“Foreman users” group.
> Hi,
> have several hosts discovered and deployed some yesterday.
> <http://node2.test.nu> as its being discovered and assigned
> Unable to perform power BMC operation ([Errno::ECONNREFUSED]:
> Connection refused - connect(2)) for proxy
> <http://node2.test.nu> 10000 failed
> connection.
> Ohad
The proxy service is running fine and I can deploy a libvirt vm using
network install without problems.
The ip "proxy http://xx.xxx.xxx.72:8443/bmc"
<http://xx.xxx.xxx.72:8443/bmc>isn't the proxy address but the ip of the
discovered host I'm trying to deploy. So it tries to use the dhcp ip of
the host itself as proxy???
Jorick
On 09/18/2014 12:04 PM, Ohad Levy wrote:
> On Thu, Sep 18, 2014 at 12:50 PM, Jorick Astrego > <j.astrego@netbulae.eu > wrote:
> upgraded to The Foreman 1.6 a couple of weeks ago.
> /etc/foreman-proxy/settings.d/bmc.yml , restarted the services.
> Kind regards,
> Jorick Astrego
> Netbulae B.V.
>> Hi,
>> assigned
>> perform power BMC operation ([Errno::ECONNREFUSED]: Connection refused -
>> failed
> connection.
> Ohad
> discovered host I'm trying to deploy. So it tries to use the dhcp ip of the
I see, The proxy code is actually running inside the discovered host (it
saved us from rewriting an agent) with minimal functionality (such as power
management and fact reporting).
in order to trigger a reboot, the proxy needs to be reachable on the
discovered host from foreman (until we use the smart proxy as a real proxy
for this purpose). is that the case?
Ohad
> On Thu, Sep 18, 2014 at 12:50 PM, Jorick Astrego > wrote:
Jorick
Kind regards,
Jorick Astrego
Netbulae B.V.
Ah I see, the host is discovered and it ip address is pingable. The
http://xx.xxx.xxx.72 <http://xx.xxx.xxx.72:8443/bmc>:8443/bmc url isn't
working though. I still use the same discovery image as I used for the
last 2 months.
Jorick
On 09/18/2014 12:34 PM, Ohad Levy wrote:
>> On Thu, Sep 18, 2014 at 12:50 PM, Jorick Astrego >> <j.astrego@netbulae.eu > wrote:
>> Hi,
>> integration. I have several hosts discovered and deployed
>> some yesterday.
>> change anything), I get the following errors:
>> ([Errno::ECONNREFUSED]: Connection refused - connect(2))
>> 10000 failed
>> the connection.
>> Ohad
> using network install without problems.
> of the discovered host I'm trying to deploy. So it tries to use
> the dhcp ip of the host itself as proxy???
> (it saved us from rewriting an agent) with minimal functionality (such
> as power management and fact reporting).
> proxy for this purpose). is that the case?
> Ohad
Found it! And it's a nice one.
I was looking at the facts after discovery and noticed eth0 had no ip
and there was an ovirtmgmt interface:
interfaces eth0,eth1,eth2,eth3,eth4,eth5,lo,ovirtmgmt
ipaddress 10.xxx.xxx.88
ipaddress_eth1 10.xxx.xxx.88
ipaddress_eth2 10.xxx.xxx.46
ipaddress_eth3 10.xxx.xxx.47
ipaddress_lo 127.0.0.1
So my thinking was that as there was ovirt-node installed on the host
and the discovery image also uses ovirt-node. What if the discovery
image reads the network config from disk somehow. I reinitialized the
disk and rebooted in discovery mode.
Tada, no more ovirtmgmt interface:
ipaddress 10.xxx.xxx.85
ipaddress_eth0 10.xxx.xxx.85
ipaddress_eth1 10.xxx.xxx.89
The discovery image shouldn't read anything from the disk I think. I'll
file a bug for it.
Kind regards,
Jorick Astrego
Netbulae B.V.
>> On Thu, Sep 18, 2014 at 1:23 PM, Jorick Astrego >> <j.astrego@netbulae.eu > wrote:
>>> On Thu, Sep 18, 2014 at 12:50 PM, Jorick Astrego >>> <j.astrego@netbulae.eu > wrote:
>>> Hi,
>>> some yesterday.
>>> 10000 failed
>>> the connection.
>>> Ohad
>> (such as power management and fact reporting).
>> Ohad
> http://xx.xxx.xxx.72 :8443/bmc url
> isn't working though. I still use the same discovery image as I used
> for the last 2 months.
> Jorick
