Anhu
1
the current Foreman 2.5.2 with Proxmox 6.4-9 resource fails on creating hosts with:
Failure: undefined method `args_for_compute_resource_partial’ for #<#Class:0x000055f5791f9cc0:0x000055f5888f6aa0>
Is this a know issue? My test installation (Debian 10) uses:
Foreman version: 2.5.2
Plugins:
- foreman-tasks 4.1.2
- foreman_ansible 6.3.1
- foreman_fog_proxmox 0.13.3
- foreman_remote_execution 4.5.1
- foreman_templates 9.0.0
Thanks for feedback.
Regards,
Anhu
This appears to be Rails tests fail as plugin is using method which is removed in latest version of foreman · Issue #199 · theforeman/foreman_fog_proxmox · GitHub - @tristanrobert any updates on the issue? Anything I can do to help fix it (other than trying to make sure we properly deprecate helper functions in the future)?
Yes it is planned: #199 and I am working on it.
Anhu
4
Great! @ristanrobert If you need some help to test the changes let me know.
Anhu
5
Thanks for fixing this. Will foreman_fox_proxmox 0.14.0 be available with foreman 5.2.3 instead of foreman_fog_proxmox 0.13.3 via debian apt?
Anhu
6
It works again with Foreman 3.0.0-rc1, although ruby-foreman-fog-proxmox 0.13.3-1 is used. Thanks!
