Unique IDs and UI testing automation
Hey,
In order to assist in UI automation, I would like to propose that we add unique IDs to the following elements:
   - Tables and table rows (<tr>s)
   - All inputs, including those not technically in a form (row select    checkboxes, for example)
   - All buttons
These IDs should all follow the same format, perhaps something like object.class-object.id-element.type. For example, product-2-row and product-2-checkbox.
Thoughts on this? Anything that needs to be added or changed?
Walden
Seems reasonable to me. I don't really see a downside other than the work to add all the IDs.
··· On Wed, Nov 29, 2017 at 1:08 PM, Walden Raines <wraines@redhat.com> wrote:
Hey,
- All buttons
product-2-checkbox.
Walden
"foreman-dev" group.
Andrew Kofink
akofink@redhat.com
IRC: akofink
Software Engineer
Red Hat Satellite
+1 This was also the feedback I heard from QE. Sometimes they have to use xpaths to test which are more likely to break than IDs.
- All buttons
product-2-checkbox.
I don't think we should go through the entire application and add the IDs. I think the way to tackle this is two-fold:
   - Add IDs as we update functionality on pages that don't have these IDs    - Encouraging QE to report missing IDs (and potentially open a PR to add    them) on troublesome pages
The latter has already been agreed to, the former is in our hands to remember to do.
Cheers,
Walden
··· On Wed, Nov 29, 2017 at 1:31 PM, Ewoud Kohl van Wijngaarden < ewoud@kohlvanwijngaarden.nl> wrote:
- All buttons
product-2-checkbox.
While I don't mind adding more IDs, care should be taken to make sure there aren't any duplicate ids on the same page.
We already add data-id attributes to all links in a bit of a hacky way [1], I'd be happy to get rid of this unreadable code (which i'm not sure is even used anywhere) and replace it with actual ids in a consistent manner.
[1]
··· On Wed, Nov 29, 2017 at 9:06 PM, Walden Raines <wraines@redhat.com> wrote:
remember to do.
Cheers,
Walden
On Wed, Nov 29, 2017 at 1:31 PM, Ewoud Kohl van Wijngaarden < > ewoud@kohlvanwijngaarden.nl> wrote:
- All buttons
product-2-checkbox.
Have a nice day,
Tomer Brisker
Red Hat Engineering
Just to be sure it does not get lost:
All buttons
All buttons (which are links) already has data-id which is always present and when not, it is auto-generated from HREF attribute. This was added by Og request, perhaps it did not serve well?
Autogeneration cannot be used in other cases, I guess there is no other way than explicitly adding those IDs manually.
I vote for raising an exception when ID is missing and Rails are in development mode so we will never add such an element without an ID. Would be good to have some kind of ID "registry" also available for plugins so we prevent from making double IDs. I can imagine something similar than what's used in i18n world: N_(id) when you can easily create simple parser to verify whole codebase to extract those strings (and easily spot wrong IDs).
Later,
  Lukas @lzap Zapletal
Thanks Walden for bringing this up.
Dne středa 29. listopadu 2017 20:06:50 CET, Walden Raines napsal(a):
to add all the IDs.
Why not? It might be a bit boring but very useful effort. If we only add IDs to new UI, I as an integration tests writer would remain frustrated whenever I add new test that touches existing area. I think it wouldn't be more than 1 day of work to extend all tables in Foreman core. For inputs it should be even simpler as we have form helpers that would just need to be updated (but I think all rails inputs already have id).
This would also be a good opportunity for a contribution for someone who'd like to investigate the whole stack, go over all pages and do small code changes on them.
remember to do.
I think we should also agree on a guideline how to construct such IDs, so we don't end up in random strings which would be prone to duplicates. For parts that are generated by rails, I think using dom_id helper would be a good start [1], obviously UI rendered from JS would need to have it's implementation of this method.
For tables we could have something like this
'table-users'
for tr, this should do
dom_id(user, 'row') # result is row_user_15 where 15 is id of user, or row_user if user is new_record
For inputs, rails follow the rule $resource_$attribute, while this does not necessarily need to be always unique, I think it's a good enough for resource forms. For the rest (e.g. search input) we should generate it uniquely, there are cases where we have 2 search field on the same page, e.g. roles and filters opened in 2pane.
For buttons it can be tricky. Perhaps the same approach as we have with data- id today in core would do, or even keep to data-id only.
[1] https://apidock.com/rails/ActionView/RecordIdentifier/dom_id
Marek
Cheers,
Walden
On Wed, Nov 29, 2017 at 1:31 PM, Ewoud Kohl van Wijngaarden < > > ewoud@kohlvanwijngaarden.nl> wrote:
- All buttons
product-2-checkbox.
This code was actually created by me to server the very same purpose - QAs asked for this. They wanted to have all buttons (links) to have an ID and now they have it.
This is the request: http://projects.theforeman.org/issues/3751
We used data-id to carry the information. It is autogenerated from HREF path, if that's missing then its "aid_not_defined".
I am not sure what happened and why QAs are not using this anymore. If this is not used, it should go away. Indeed it looks like a hack, but I wanted to have a generic solution to the problem - QAs always come to us and request "can you add ID here, and here", this was supposed to solve this issue so they are unblocked until we add explicit IDs there.
LZ
··· On Wed, Nov 29, 2017 at 11:45 PM, Tomer Brisker <tbrisker@redhat.com> wrote:
[1]
remember to do.
Cheers,
Walden
On Wed, Nov 29, 2017 at 1:31 PM, Ewoud Kohl van Wijngaarden >> <ewoud@kohlvanwijngaarden.nl> wrote:
- All buttons
product-2-checkbox.
Have a nice day,
Tomer Brisker
Red Hat Engineering
Later,
