Unknown primary key for table settings in model Setting. After PostgreSQL database migration
**Problem: We are currently trying to upgrade our Foreman instance. To test this upgrade, I made a clone of the current machine and dumped the foreman and candlepin db from our external PostgreSQL 9.6 server. After dumping I installed PostgreSQL 9.6 locally on the clone and imported the Foreman and Candlepin db’s to the local PostgreSQL instance (MongoDB is already running locally btw). Then I changed the database host to localhost in the files /etc/foreman/database.yml and /etc/candlepin/candlepin.conf.
As soon as I start the Foreman I get the following error:
Can not validate uniqueness for persisted record without primary key. (ActiveRecord::UnknownPrimaryKey)
**Foreman and Proxy versions: 1.21.4
**Foreman and Proxy plugin versions: 1.21.4
**Distribution and version: Centos 7
**Other relevant data: Log Snippet
Web application could not be started
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/validations/uniqueness.rb:28:in `validate_each'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activemodel-5.2.1/lib/active_model/validator.rb:152:in `block in validate'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activemodel-5.2.1/lib/active_model/validator.rb:149:in `each'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activemodel-5.2.1/lib/active_model/validator.rb:149:in `validate'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:426:in `block in make_lambda'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:198:in `block (2 levels) in halting'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:606:in `block (2 levels) in default_terminator'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:605:in `catch'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:605:in `block in default_terminator'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:199:in `block in halting'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:513:in `block in invoke_before'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:513:in `each'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:513:in `invoke_before'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:131:in `run_callbacks'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:816:in `_run_validate_callbacks'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activemodel-5.2.1/lib/active_model/validations.rb:409:in `run_validations!'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activemodel-5.2.1/lib/active_model/validations/callbacks.rb:118:in `block in run_validations!'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:132:in `run_callbacks'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:816:in `_run_validation_callbacks'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activemodel-5.2.1/lib/active_model/validations/callbacks.rb:118:in `run_validations!'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activemodel-5.2.1/lib/active_model/validations.rb:339:in `valid?'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/validations.rb:67:in `valid?'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/validations.rb:84:in `perform_validations'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/validations.rb:46:in `save'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:310:in `block (2 levels) in save'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:387:in `block in with_transaction_returning_status'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:252:in `transaction'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:212:in `transaction'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:385:in `with_transaction_returning_status'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:310:in `block in save'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:325:in `rollback_active_record_state!'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:309:in `save'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/suppressor.rb:44:in `save'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/persistence.rb:428:in `block in update'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/persistence.rb:426:in `update'
  /usr/share/foreman/app/models/setting.rb:245:in `block in create_existing'
  /usr/share/foreman/app/models/setting.rb:261:in `bypass_readonly'
  /usr/share/foreman/app/models/setting.rb:241:in `create_existing'
  /usr/share/foreman/app/models/setting.rb:201:in `create_find_by_name'
  /usr/share/foreman/app/models/setting.rb:214:in `create!'
  /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.14.6/app/models/setting/foreman_tasks.rb:14:in `block (2 levels) in load_defaults'
  /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.14.6/app/models/setting/foreman_tasks.rb:14:in `each'
  /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.14.6/app/models/setting/foreman_tasks.rb:14:in `block in load_defaults'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:254:in `block in transaction'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:239:in `block in within_new_transaction'
  /opt/rh/rh-ruby25/root/usr/share/ruby/monitor.rb:226:in `mon_synchronize'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:236:in `within_new_transaction'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:254:in `transaction'
  /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.14.6/app/models/setting/foreman_tasks.rb:6:in `load_defaults'
  /usr/share/foreman/config/initializers/foreman.rb:29:in `each'
  /usr/share/foreman/config/initializers/foreman.rb:29:in `<top (required)>'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:281:in `load'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:281:in `block in load'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:253:in `load_dependency'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/engine.rb:657:in `block in load_config_initializer'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/notifications.rb:170:in `instrument'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/engine.rb:656:in `load_config_initializer'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/engine.rb:614:in `block (2 levels) in <class:Engine>'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/engine.rb:613:in `each'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/engine.rb:613:in `block in <class:Engine>'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:32:in `instance_exec'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:32:in `run'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:61:in `block in run_initializers'
  /opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:228:in `block in tsort_each'
  /opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
  /opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:422:in `block (2 levels) in each_strongly_connected_component_from'
  /opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:431:in `each_strongly_connected_component_from'
  /opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:421:in `block in each_strongly_connected_component_from'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:50:in `each'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:50:in `tsort_each_child'
  /opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:415:in `call'
  /opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:415:in `each_strongly_connected_component_from'
  /opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:349:in `block in each_strongly_connected_component'
  /opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:347:in `each'
  /opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:347:in `call'
  /opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:347:in `each_strongly_connected_component'
  /opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:226:in `tsort_each'
  /opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:205:in `tsort_each'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:60:in `run_initializers'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/application.rb:361:in `initialize!'
  /usr/share/foreman/config/environment.rb:5:in `<top (required)>'
  /opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:59:in `require'
  config.ru:5:in `block in <main>'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/builder.rb:55:in `instance_eval'
  /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/builder.rb:55:in `initialize'
  config.ru:1:in `new'
  config.ru:1:in `<main>'
  /usr/share/passenger/helper-scripts/rack-preloader.rb:112:in `eval'
  /usr/share/passenger/helper-scripts/rack-preloader.rb:112:in `preload_app'
  /usr/share/passenger/helper-scripts/rack-preloader.rb:158:in `<module:App>'
  /usr/share/passenger/helper-scripts/rack-preloader.rb:29:in `<module:PhusionPassenger>'
  /usr/share/passenger/helper-scripts/rack-preloader.rb:28:in `<main>'
Error ID
23c1d1af
Hey.
Check if you migrated also indices. Paste the pgdump/pgrestore commands please.
Thanks for your reply
The commands that I used to create the PostgreSQL backups are:
foreman-maintain advanced procedure run backup-offline-candlepin-db --backup-dir /tmp/candlepin/
foreman-maintain advanced procedure run backup-offline-foreman-db --backup-dir /tmp/foreman
Ans the restore commands that I used are
pg_restore -d foreman foreman.dump
pg_restore -d candlepin candlepin.dump
I see you marked the thread as resolved, I suppose you haven’t solved it tho.
Can you dump database schemas on both servers and compare it? There must be a PK missing on the new one.
I didnt stop the foreman instance while backupping the postgresql database.
I just stopped the foreman instance and backupped the data from the postgresql server.
