Problem: /pub directory not listing under the foreman server, same goes for the smart proxies sites.
Expected outcome: expecting /pub to be able to list content.
Foreman and Proxy versions: Foreman 3.3 with RHEL 8.6 (Latest)
Foreman and Proxy plugin versions: Foreman 3.3 with RHEL 8.6 (latest)
Distribution and version: RHEL 8.6
Any assitance on this, or this is the new behavior after the upgrade?
gvde
July 1, 2022, 8:59am
3
Did you stop all services and ran foreman-installer after the upgrade?
Wes
July 1, 2022, 4:07pm
4
What I’m seeing is that directory browsing doesn’t seem to be working, though defined properly in Apache configs, on my particular RHEL 8.6 based instance, though I’ve ensured +Indexes was set on the right Location tag for /pub, which is why /pub isn’t showing a directory listing for me. I can access files within /pub no problem if I specify the full path to the file, such as /pub/katello-ca-consumer-latest.noarch.rpm. If I figure mine out, I’ll share.
gvde, yes all services were stop prior to the upgrade.
I am still getting the folloing under /pub
Not Found
The requested URL was not found on this server.
Thank you Wes for the reply, perhaps this is a small bug that was left out of 3.3,
Maybe someone can help us with the apache config parameters that need to be adjusted for the listing to start working again. Thank you.
gvde
July 1, 2022, 4:42pm
7
So you did not run foreman-installer after the upgrade? That would set up the apache configuration…
Hi gvde, do you happen to have a workaround for those of us experiencing the issue? Thank you in advance.
gvde
July 1, 2022, 6:11pm
9
You have to run foreman-installer after the upgrade…
Hi gvde,
I try running the foreman-installer last night and the issue with /pub remains. Please provide guidance on a workaround if avaiable. Thank you.
gvde
July 2, 2022, 2:20pm
11
Did foreman-installer complete without any errors?
What do you have in /etc/http/conf.d/05-foreman.conf and 05-foreman-ssl.conf?
There is little point manually adding the it to those files. It would be much more important to understand why it’s missing and solve that…
Hi gvde,
Thank you for your input…below find the output of my two files:
Code for 05-foreman.conf
cat /etc/httpd/conf.d/05-foreman.conf
# Vhost template in module puppetlabs-apache
# Managed by Puppet
<VirtualHost *:80>
ServerName foreman.localdomain
## Vhost docroot
DocumentRoot "/usr/share/foreman/public"
## Directories, there should at least be a declaration for /usr/share/foreman/public
<Directory "/usr/share/foreman/public">
Options SymLinksIfOwnerMatch
AllowOverride None
Require all granted
</Directory>
## Load additional static includes
IncludeOptional "/etc/httpd/conf.d/05-foreman.d/*.conf"
## Logging
ErrorLog "/var/log/httpd/foreman_error.log"
ServerSignature Off
CustomLog "/var/log/httpd/foreman_access.log" combined
## Request header rules
## as per http://httpd.apache.org/docs/2.2/mod/mod_headers.html#requestheader
RequestHeader set X_FORWARDED_PROTO "http"
RequestHeader set SSL_CLIENT_S_DN ""
RequestHeader set SSL_CLIENT_CERT ""
RequestHeader set SSL_CLIENT_VERIFY ""
RequestHeader unset REMOTE_USER
RequestHeader unset REMOTE_USER_EMAIL
RequestHeader unset REMOTE_USER_FIRSTNAME
RequestHeader unset REMOTE_USER_LASTNAME
RequestHeader unset REMOTE_USER_GROUPS
<Location "/pulp/deb">
RequestHeader unset X-CLIENT-CERT
RequestHeader set X-CLIENT-CERT "%{SSL_CLIENT_CERT}s" env=SSL_CLIENT_CERT
ProxyPass unix:///run/pulpcore-content.sock|http://pulpcore-content/pulp/content disablereuse=on timeout=600
ProxyPassReverse unix:///run/pulpcore-content.sock|http://pulpcore-content/pulp/content
</Location>
<Location "/pulp/isos">
</Location>
<Location "/pulp/repos">
</Location>
Alias /pub /var/www/html/pub
<Location /pub>
<IfModule mod_passenger.c>
PassengerEnabled off
</IfModule>
Options +FollowSymLinks +Indexes
Require all granted
</Location>
<Location "/pulp/content">
</Location>
## Proxy rules
ProxyRequests Off
ProxyPreserveHost On
ProxyAddHeaders On
ProxyPass /pulp !
ProxyPass /pulp2 !
ProxyPass /streamer !
ProxyPass /pub !
ProxyPass /icons !
ProxyPass / unix:///run/foreman.sock|http://foreman/ retry=0 timeout=900
ProxyPassReverse / unix:///run/foreman.sock|http://foreman/
## Rewrite rules
RewriteEngine On
#Upgrade Websocket connections
RewriteCond %{HTTP:Upgrade} =websocket [NC]
RewriteRule /(.*) unix:///run/foreman.sock|ws://foreman/$1 [P,L]
## Server aliases
ServerAlias foreman
## Custom fragment
# Return compressed assets if they are precompiled
<IfModule mod_rewrite.c>
RewriteEngine on
# Make sure the browser supports gzip encoding and file with .gz added
# does exist on disc before we rewrite with the extension
RewriteCond %{HTTP:Accept-Encoding} \b(x-)?gzip\b
RewriteCond %{REQUEST_FILENAME} \.(css|js|svg)$
RewriteCond %{REQUEST_FILENAME}.gz -s
RewriteRule ^(.+) $1.gz [L]
# Set headers for all possible assets which are compressed
<FilesMatch \.css\.gz$>
ForceType text/css
Header set Content-Encoding gzip
SetEnv no-gzip
</FilesMatch>
<FilesMatch \.js\.gz$>
ForceType text/javascript
SetEnv no-gzip
</FilesMatch>
<FilesMatch \.svg\.gz$>
ForceType image/svg+xml
SetEnv no-gzip
</FilesMatch>
</IfModule>
<LocationMatch "^/(assets|webpack)">
AllowOverride None
Require all granted
# Use standard http expire header for assets instead of ETag
<IfModule mod_expires.c>
Header unset ETag
FileETag None
ExpiresActive On
ExpiresDefault "access plus 1 year"
</IfModule>
</LocationMatch>
AddDefaultCharset UTF-8
</VirtualHost>
Code for 05-foreman-ssl.conf
cat /etc/httpd/conf.d/05-foreman-ssl.conf
# Managed by Puppet
<VirtualHost *:443>
## Vhost docroot
AllowOverride None
Require all granted
</Directory>
IncludeOptional "/etc/httpd/conf.d/05-foreman-ssl.d/*.conf"
## Logging
ErrorLog "/var/log/httpd/foreman-ssl_error_ssl.log"
ServerSignature Off
CustomLog "/var/log/httpd/foreman-ssl_access_ssl.log" combined
RequestHeader set X_FORWARDED_PROTO "https"
RequestHeader set SSL_CLIENT_S_DN "%{SSL_CLIENT_S_DN}s"
RequestHeader set SSL_CLIENT_CERT "%{SSL_CLIENT_CERT}s"
RequestHeader set SSL_CLIENT_VERIFY "%{SSL_CLIENT_VERIFY}s"
# SSL Proxy directives
SSLProxyEngine On
ProxyPass /pulp_ansible/galaxy/ unix:///run/pulpcore-api.sock|http://pulpcore-api/pulp_ansible/galaxy/
ProxyPassReverse /pulp_ansible/galaxy/ unix:///run/pulpcore-api.sock|http://pulpcore-api/pulp_ansible/galaxy/
<Location "/pulpcore_registry/v2/">
RequestHeader set REMOTE_USER "%{SSL_CLIENT_S_DN_CN}s" env=SSL_CLIENT_S_DN_CN
ProxyPass unix:///run/pulpcore-api.sock|http://pulpcore-api/v2/
ProxyPassReverse unix:///run/pulpcore-api.sock|http://pulpcore-api/v2/
</Location>
ProxyPass /pulp/container/ unix:///run/pulpcore-content.sock|http://pulpcore-content/pulp/container/
ProxyPassReverse /pulp/container/ unix:///run/pulpcore-content.sock|http://pulpcore-content/pulp/container/
</Location>
</Location>
</Location>
<Location /pub>
</IfModule>
Require all granted
</Location>
</Location>
<Location "/pulp/api/v3">
RequestHeader set REMOTE_USER "admin" "expr=%{SSL_CLIENT_S_DN_CN} == 'sjglcsappprdg15.na.gilead.com'"
ProxyPass unix:///run/pulpcore-api.sock|http://pulpcore-api/pulp/api/v3 timeout=600
ProxyPassReverse unix:///run/pulpcore-api.sock|http://pulpcore-api/pulp/api/v3
</Location>
ProxyPass /pulp/assets/ unix:///run/pulpcore-api.sock|http://pulpcore-api/pulp/assets/
ProxyPassReverse /pulp/assets/ unix:///run/pulpcore-api.sock|http://pulpcore-api/pulp/assets/
## Proxy rules
ProxyRequests Off
ProxyAddHeaders On
ProxyPass /pulp !
ProxyPass /pulp2 !
ProxyPass /pub !
ProxyPass /icons !
## Rewrite rules
RewriteEngine On
## Server aliases
ServerAlias foreman
## SSL directives
SSLEngine on
SSLCertificateFile "/etc/pki/katello/certs/katello-apache.crt"
SSLCertificateKeyFile "/etc/pki/katello/private/katello-apache.key"
SSLCertificateChainFile "/etc/pki/katello/certs/katello-server-ca.crt"
SSLVerifyClient optional
SSLVerifyDepth 3
SSLCACertificateFile "/etc/pki/katello/certs/katello-default-ca.crt"
SSLOptions +StdEnvVars +ExportCertData
## Custom fragment
RewriteEngine on
ForceType text/css
SetEnv no-gzip
</FilesMatch>
SetEnv no-gzip
</FilesMatch>
SetEnv no-gzip
</FilesMatch>
</IfModule>
AllowOverride None
Require all granted
Header unset ETag
FileETag None
ExpiresActive On
</IfModule>
</LocationMatch>
</VirtualHost>
gvde
July 3, 2022, 3:31pm
13
I am sorry, but it‘s extremely hard if you don‘t answer the questions you have been asked…
Again: Did foreman-installer run without errors after the upgrade?
What do you have in /var/www/html/pub?
Hi gdve, The formain-installer run fine after the upgrade no issues.
under /var/www/html/pub I have the following:
[root@foreman pub]# ls -la
total 112
drwxr-xr-x 2 apache apache 274 Jul 1 01:30 .
drwxr-xr-x 3 root root 17 Jul 1 01:29 ..
-rw-r--r-- 1 apache apache 74211 Apr 20 06:00 bootstrap.py
lrwxrwxrwx 1 root root 84 Jul 1 01:30 katello-ca-consumer-latest.noarch.rpm -> /var/www/html/pub/katello-ca-consumer-foreman.localdomain-1.0-1.noarch.rpm
-rw-r--r-- 1 root root 10168 Jul 1 01:30 katello-ca-consumer-foreman.localdomain-1.0-1.noarch.rpm
-rw-r--r-- 1 root root 9445 Jul 1 01:30 katello-ca-consumer-foreman.localdomain-1.0-1.src.rpm
-rwxr-xr-x 1 root root 7837 Jul 1 01:30 katello-rhsm-consumer
-rw-r--r-- 1 root root 2516 Jul 1 01:30 katello-server-ca.crt
gvde
July 3, 2022, 4:23pm
15
/pub is there and it’s configured in httpd.
Verify foreman.localdomain really resolves to your foreman server and that your client/browser isn’t using a proxy interfering.
$ host foreman.localdomain
$ curl -v http://foreman.localdomain/pub
$ curl -v http://foreman.localdomain/pub/
cucu007:
o
Hi gvde, Below if the output I mam getting:
foreman.localdomain has address 10.22.9.140
* Trying 10.22.9.140...
* TCP_NODELAY set
* Connected to foreman.localdomain (10.22.9.140) port 80 (#0)
> GET /pub HTTP/1.1
> Host: foreman.localdomain
> User-Agent: curl/7.61.1
> Accept: */*
< HTTP/1.1 404 Not Found
< Date: Sun, 03 Jul 2022 16:30:56 GMT
< Server: Apache
< Content-Length: 196
< Content-Type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL was not found on this server.</p>
</body></html>
* Connection #0 to host foreman.localdomain left intact
[root@foreman conf.d]# curl -v http://foreman.localdomain/pub/
* TCP_NODELAY set
> GET /pub/ HTTP/1.1
> Accept: */*
< Date: Sun, 03 Jul 2022 16:31:24 GMT
< Server: Apache
<html><head>
</head><body>
<h1>Not Found</h1>
</body></html>
gvde
July 3, 2022, 5:05pm
17
And 10.22.9.140 is the up address of that foreman server you are on?
What files do you have in /etc/httpd/conf and conf.d?
$ ls -laR /etc/httpd/conf{,.d}
Hi gvde,
Below is the output of the conf directory as requested.
FYI, everything is working fine with my forman except the publish of the /pub directory.
/etc/httpd/conf:
total 24
drwxr-xr-x 2 root root 55 Jul 1 01:31 .
drwxr-xr-x 5 root root 105 Jul 1 01:27 ..
-rw-r--r-- 1 root root 1029 Jul 1 01:31 httpd.conf
-rw-r--r-- 1 root root 13064 Jun 15 05:27 magic
-rw-r--r-- 1 root root 185 Jul 1 01:31 ports.conf
/etc/httpd/conf.d:
total 24
drwxr-xr-x 4 root root 141 Jul 3 09:24 .
-rw-r--r-- 1 root root 4643 Jul 3 09:28 05-foreman.conf
-rw-r----- 1 root root 4643 Jul 3 09:24 05-foreman.conf.original.07032022
drwxr-xr-x 2 root root 6 Jul 1 01:33 05-foreman.d
-rw-r--r-- 1 root root 6569 Jul 1 01:33 05-foreman-ssl.conf
drwxr-xr-x 2 root root 26 Jul 1 01:33 05-foreman-ssl.d
/etc/httpd/conf.d/05-foreman.d:
total 0
drwxr-xr-x 2 root root 6 Jul 1 01:33 .
drwxr-xr-x 4 root root 141 Jul 3 09:24 ..
/etc/httpd/conf.d/05-foreman-ssl.d:
total 4
drwxr-xr-x 2 root root 26 Jul 1 01:33 .
-rw-r--r-- 1 root root 791 Jul 1 01:33 katello.conf
gvde, any new update son this pending item? Please advise.
gvde
July 7, 2022, 4:52pm
20
Configuration looks good. /pub should be served directly out of httpd. You should check httpd logs in /var/log/httpd if there is anything indicating why it’s not serving /pub. Also check httpd logs right after a restart if it shows any errors or warnings.
