I updated my foreman install from 1.8 to 1.9.3 about 20 days ago and was
able to discover new hosts/deploy/sign discovered host certificates through
the web UI.
Today I tried to add a new discovered host, and am getting an error when
clicking the web UI Infrastructure -> Smart Proxies -> 'Certificates'
button: "ERF12-5356 [ProxyAPI::ProxyException]: Unable to get PuppetCA
certificates ([RestClient::NotAcceptable]: 406 Not Acceptable) for proxy
https://foreman.domain:8443/puppet/ca"
I've tried restarting foreman-proxy service and the host with the same
results.
tail proxy.log
I, [2016-02-03T13:45:38.493622 #9939] INFO – : 'puppet' settings were
initialized with default values: :puppet_provider: puppetrun, :puppetdir:
/etc/puppet, :salt_puppetrun_cmd: puppet.run, :use_cache: true
I, [2016-02-03T13:45:38.496173 #9939] INFO – : 'bmc' module is disabled.
I, [2016-02-03T13:45:38.496522 #9939] INFO – : 'realm' module is disabled.
D, [2016-02-03T13:45:59.839756 #9959] DEBUG – : verifying remote client
142.104.194.18 against trusted_hosts ["foreman.domain"]
D, [2016-02-03T13:45:59.842077 #9959] DEBUG – : Found puppetca at
/usr/bin/puppet
D, [2016-02-03T13:45:59.842192 #9959] DEBUG – : Found sudo at /usr/bin/sudo
D, [2016-02-03T13:45:59.842239 #9959] DEBUG – : Executing /usr/bin/sudo -S
/usr/bin/puppet cert --ssldir /var/lib/puppet/ssl --list --all
W, [2016-02-03T13:46:00.519101 #9959] WARN – : Failed to run puppetca:
E, [2016-02-03T13:46:00.519551 #9959] ERROR – : Failed to list
certificates: Execution of puppetca failed, check log files
142.104.194.18 - - [03/Feb/2016 13:46:00] "GET /puppet/ca HTTP/1.1" 406 74
0.6808
su - foreman-proxy
Last login: Wed Feb 3 13:52:09 PST 2016 on pts/0
-bash-4.2$ /usr/bin/sudo -S /usr/bin/puppet cert --ssldir
/usr/share/gems/gems/json-1.7.7/lib/json/common.rb:155:in encode': "\xC5" on US-ASCII (Encoding::InvalidByteSequenceError) from /usr/share/gems/gems/json-1.7.7/lib/json/common.rb:155:ininitialize'
from /usr/share/gems/gems/json-1.7.7/lib/json/common.rb:155:in new' from /usr/share/gems/gems/json-1.7.7/lib/json/common.rb:155:inparse'
from /usr/share/ruby/vendor_ruby/puppet/module.rb:62:in has_metadata?' from /usr/share/ruby/vendor_ruby/puppet/module.rb:49:ininitialize'
from /usr/share/ruby/vendor_ruby/puppet/node/environment.rb:355:in new' from /usr/share/ruby/vendor_ruby/puppet/node/environment.rb:355:inblock
(2 levels) in <class:Environment>'
from /usr/share/ruby/vendor_ruby/puppet/node/environment.rb:353:in collect' from /usr/share/ruby/vendor_ruby/puppet/node/environment.rb:353:inblock
from /usr/share/ruby/vendor_ruby/puppet/util/cacher.rb:55:in cached_value' from /usr/share/ruby/vendor_ruby/puppet/util/cacher.rb:29:inblock in
cached_attr'
from /usr/share/ruby/vendor_ruby/puppet/node/environment.rb:296:in
each_plugin_directory' from /usr/share/ruby/vendor_ruby/puppet/util/command_line.rb:137:inrun'
from /usr/share/ruby/vendor_ruby/puppet/util/command_line.rb:92:in execute' from /usr/bin/puppet:8:in<main>'
If I run the above as root, or my own user with sudo, I get a return of all
the current certificates listed with fingerprints.
cat /etc/sudoers.d/foreman-proxy
foreman-proxy ALL = (root) NOPASSWD : /usr/bin/puppet cert *
foreman-proxy ALL = (root) NOPASSWD : /usr/bin/puppet kick *
Defaults:foreman-proxy !requiretty
/var/log/secure:
Feb 3 13:52:50 foreman su: pam_unix(su-l:session): session opened for user
foreman-proxy by sdainard(uid=0)
Feb 3 13:52:57 foreman sudo: foreman-proxy : TTY=pts/0 ;
PWD=/usr/share/foreman-proxy ; USER=root ; COMMAND=/usr/bin/puppet cert
–ssldir /var/lib/puppet/ssl --list --all
Feb 3 13:55:21 foreman su: pam_unix(su-l:session): session closed for user
foreman-proxy
su - foreman-proxy
Last login: Wed Feb 3 13:57:29 PST 2016 on pts/0
-bash-4.2$ sudo -l
Matching Defaults entries for foreman-proxy on this host:
requiretty, !visiblepw, always_set_home, env_reset, env_keep="COLORS
DISPLAY HOSTNAME HISTSIZE INPUTRC KDEDIR LS_COLORS",
env_keep+="MAIL PS1 PS2 QTDIR USERNAME LANG LC_ADDRESS LC_CTYPE",
env_keep+="LC_COLLATE LC_IDENTIFICATION LC_MEASUREMENT LC_MESSAGES",
env_keep+="LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER LC_TELEPHONE",
env_keep+="LC_TIME LC_ALL LANGUAGE LINGUAS _XKB_CHARSET XAUTHORITY",
secure_path=/sbin:/bin:/usr/sbin:/usr/bin, !requiretty
User foreman-proxy may run the following commands on this host:
(root) NOPASSWD: /usr/bin/puppet cert *
(root) NOPASSWD: /usr/bin/puppet kick *
ps aux | grep foreman-proxy
foreman+ 2959 0.0 0.4 369800 51540 ? Sl 14:25 0:00 ruby
/usr/share/foreman-proxy/bin/smart-proxy
I can't think of anything that has changed on the Foreman host since the
upgrade to 1.9.3, and I remember rebooting after the upgrade and testing if
everything was working.
Any help is appreciated.
