Upgrading to Foreman 1.10.2: selinux and connection errors
I've just now updated to F1.10.2 from 1.10.1. My foreman host runs
CentOS7.2, 3.10.0-327.10.1.el7.x86_64
Something seemed to have gone wrong, SELinux blocking foreman and puppet
master, I had to disable SELinux:
: Starting Puppet master version 3.8.6
: Failed to submit 'replace facts' command for w-mpo-03.int.m-box.de to
PuppetDB at foreman.int.m-box.de:8081: Connection refused - connect(2)
: /etc/selinux/targeted/contexts/files/file_contexts: invalid context
system_u:object_r:puppet_etc_t:s0
(ect.pp.)
The relevant selinux packages installed:
libselinux-utils-2.2.2-6.el7.x86_64
libselinux-2.2.2-6.el7.x86_64
selinux-policy-targeted-3.13.1-60.el7_2.3.noarch
libselinux-ruby-2.2.2-6.el7.x86_64
libselinux-python-2.2.2-6.el7.x86_64
foreman-selinux-1.10.2-1.el7.noarch
selinux-policy-3.13.1-60.el7_2.3.noarch
The installer causes errors, apparently packages have been renamed, now
ruby193-rubygem-passenger40-xx
Execution of '/usr/bin/yum -d 0 -e 0 -y list
ruby193-rubygem-passenger-native' returned 1: Error: No matching
Packages to list
/Stage[main]/Foreman::Install/Package[ruby193-rubygem-passenger-native]/ensure: change from absent to present failed: Execution of '/usr/bin/yum -d 0 -e 0 -y list ruby193-rubygem-passenger-native' returned 1: Error: No matching Packages to list
[root@foreman ~]# yum search ruby193-rubygem-passenger
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
  • base: ftp.wrz.de
  • epel: mirrors.coreix.net
  • extras: mirror.cuegee.de
  • updates: centosmirror.netcup.net
    ================================================== N/S matched:
    ruby193-rubygem-passenger ==================================================
    ruby193-rubygem-passenger40-debuginfo.x86_64 : Debug information for
    package ruby193-rubygem-passenger40
    ruby193-rubygem-passenger40.x86_64 : Passenger Ruby web application server
    ruby193-rubygem-passenger40-devel.x86_64 : Apache Module for Phusion
    Passenger
    ruby193-rubygem-passenger40-doc.noarch : Apache Module for Phusion Passenger
    ruby193-rubygem-passenger40-native.x86_64 : Phusion Passenger native
    extensions
    ruby193-rubygem-passenger40-native-libs.x86_64 : Phusion Passenger
    native extensions
Further, I had to remove tfm-rubygem-foreman_cockpit, as it was causing
connection errors:
2016-03-07 19:40:34 [app] [I] Rendered hosts/show.html.erb within
layouts/application (307.5ms)
2016-03-07 19:40:34 [app] [W] Action failed
> Errno::EACCES: Permission denied - connect(2)
> /opt/rh/ruby193/root/usr/share/ruby/net/http.rb:763:in initialize' > /opt/rh/ruby193/root/usr/share/ruby/net/http.rb:763:inopen'
> /opt/rh/ruby193/root/usr/share/ruby/net/http.rb:763:in block in connect' > /opt/rh/ruby193/root/usr/share/ruby/timeout.rb:55:intimeout'
> /opt/rh/ruby193/root/usr/share/ruby/timeout.rb:100:in timeout' > /opt/rh/ruby193/root/usr/share/ruby/net/http.rb:763:inconnect'
> /opt/rh/ruby193/root/usr/share/ruby/net/http.rb:756:in do_start' > /opt/rh/ruby193/root/usr/share/ruby/net/http.rb:745:instart'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbovirt-0.0.35/lib/restclient_ext/request.rb:44:in
transmit' > /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:64:inexecute'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:33:in
execute' > /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient.rb:68:inget'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_cockpit-1.0.3/app/models/concerns/foreman_cockpit/host_extensions.rb:22:in
block in ping_cockpit_service' > /opt/rh/ruby193/root/usr/share/ruby/timeout.rb:69:intimeout'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_cockpit-1.0.3/app/models/concerns/foreman_cockpit/host_extensions.rb:21:in
ping_cockpit_service' > /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_cockpit-1.0.3/app/models/concerns/foreman_cockpit/host_extensions.rb:10:incockpit_enabled?'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_cockpit-1.0.3/app/helpers/concerns/foreman_cockpit/hosts_helper_extensions.rb:13:in
host_title_actions_with_cockpit' > /usr/share/foreman/app/views/hosts/show.html.erb:3:in_37b1c30930b73ec0710732fce54ba477'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/template.rb:145:in
block in render' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications.rb:125:ininstrument'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/template.rb:143:in
render' > /opt/theforeman/tfm/root/usr/share/gems/gems/deface-1.0.1/lib/deface/action_view_extensions.rb:41:inrender'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/template_renderer.rb:47:in
block (2 levels) in render_template' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/abstract_renderer.rb:38:inblock in instrument'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications.rb:123:in
block in instrument' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications/instrumenter.rb:20:ininstrument'
instrument' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/abstract_renderer.rb:38:ininstrument'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/template_renderer.rb:46:in
block in render_template' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/template_renderer.rb:54:inrender_with_layout'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/template_renderer.rb:45:in
render_template' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/template_renderer.rb:18:inrender'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/renderer.rb:36:in
render_template' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/renderer.rb:17:inrender'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/rendering.rb:110:in
_render_template' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/streaming.rb:225:in_render_template'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/rendering.rb:103:in
render_to_body' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/renderers.rb:28:inrender_to_body'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/compatibility.rb:50:in
render_to_body' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/rendering.rb:88:inrender'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rendering.rb:16:in
render' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:40:inblock (2 levels) in render'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/core_ext/benchmark.rb:5:in
block in ms' > /opt/rh/ruby193/root/usr/share/ruby/benchmark.rb:295:inrealtime'
ms' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:40:inblock in render'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:83:in
cleanup_view_runtime' > /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/railties/controller_runtime.rb:24:incleanup_view_runtime'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:39:in
render' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/implicit_render.rb:10:indefault_render'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/implicit_render.rb:5:in
send_action' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/base.rb:167:inprocess_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rendering.rb:10:in
process_action' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/callbacks.rb:18:inblock in process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:660:in
block (4 levels) in _run__4095104249420218070__process_action__4524731289656068627__callbacks' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:215:inblock in _conditional_callback_around_8076'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:326:in
around' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:310:in_callback_around_3080'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:214:in
_conditional_callback_around_8076' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:626:inblock (3 levels) in
block in _conditional_callback_around_8075' > /usr/share/foreman/app/controllers/concerns/application_shared.rb:13:inset_timezone'
_conditional_callback_around_8075' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:625:inblock (2 levels) in
block in _conditional_callback_around_8074' > /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:inclear_thread'
_conditional_callback_around_8074' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:448:inblock in
block in _conditional_callback_around_8073' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:326:inaround'
_callback_around_13' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:214:in_conditional_callback_around_8073'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:414:in
_run__4095104249420218070__process_action__4524731289656068627__callbacks' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:405:in__run_callback'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:385:in
_run_process_action_callbacks' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:81:inrun_callbacks'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/callbacks.rb:17:in
process_action' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rescue.rb:29:inprocess_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:30:in
block in process_action' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications.rb:123:inblock in instrument'
instrument' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications.rb:123:ininstrument'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:29:in
process_action' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/params_wrapper.rb:207:inprocess_action'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/railties/controller_runtime.rb:18:in
process_action' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/base.rb:121:inprocess'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/rendering.rb:45:in
process' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal.rb:203:indispatch'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rack_delegation.rb:14:in
dispatch' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal.rb:246:inblock in action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:73:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:73:indispatch'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:36:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:68:inblock in call'
/opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:56:in
each' > /opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:56:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:600:in
call' > /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.2.6/lib/apipie/extractor/recorder.rb:97:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/static.rb:62:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/static.rb:62:incall'
call' > /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.2.6/lib/apipie/middleware/checksum_in_headers.rb:27:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/best_standards_support.rb:17:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/etag.rb:23:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/conditionalget.rb:25:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/head.rb:14:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/params_parser.rb:21:in
call' > /usr/share/foreman/lib/middleware/catch_json_parse_errors.rb:9:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/flash.rb:242:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/session/abstract/id.rb:205:incontext'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/session/abstract/id.rb:200:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/cookies.rb:339:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/query_cache.rb:64:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/abstract/connection_pool.rb:473:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/callbacks.rb:28:in
block in call' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:405:in_run__897772770191184078__call__2707769411776942791__callbacks'
__run_callback' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:385:in_run_call_callbacks'
run_callbacks' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/callbacks.rb:27:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/remote_ip.rb:31:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/debug_exceptions.rb:16:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/show_exceptions.rb:56:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/rack/logger.rb:26:incall_app'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/rack/logger.rb:16:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/request_id.rb:22:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/methodoverride.rb:21:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/runtime.rb:17:incall'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/cache/strategy/local_cache.rb:72:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/lock.rb:15:incall'
> Hello,
This looks more like the PuppetDB service isn't running, since SELinux
would give a permission denied error (e.g. the cockpit one later on).
If you have SELinux denials they should also be logged as AVCs in
/var/log/audit/audit.log, which gives the debug info we'd need to help
further.
There is a bit of Puppet related policy in foreman-selinux, but
generally Puppet policy shouldn't be provided by the Foreman project…
so nothing's provided by us to permit connections from Puppet to PuppetDB.
If you're running Passenger then the passenger_can_connect_all boolean
could be enabled to allow connections to anything, including PuppetDB.
> Packages to list
This is from 1.9 to 1.10, the package is now
tfm-rubygem-passenger-native. On a major upgrade the installer answers
aren't updated, so you could pass
–foreman-passenger-ruby-package=tfm-rubygem-passenger-native to the
installer command to change it.
> * base: ftp.wrz.de
> * epel: mirrors.coreix.net
> * extras: mirror.cuegee.de
> * updates: centosmirror.netcup.net
> Passenger
> extensions
> native extensions
These passenger40 packages aren't ours, they're from SCL projects.
They're not needed to run Foreman.
> connection errors:
This looks more like SELinux, which won't permit connections from
Foreman to these hosts by default. You could enable the boolean I
mentioned above or add extra policy (audit2allow?) to permit this.
It would be worth filing a bug with the foreman_cockpit or
foreman-selinux projects to add a boolean to allow these connections.
··· On 07/03/16 19:00, Daniel Helgenberger wrote:
Dominic Cleal
dominic@cleal.org
>> Hello,
> further.
Thanks for helping out.
I've attached audit2why.txt - exaples are:
type=AVC msg=audit(1457307116.531:554808): avc: denied { getattr } for
pid=22010 comm="ruby" path="/usr/sbin/dmidecode" dev="sda3" ino=7149843
scontext=system_u:system_r:passenger_t:s0
tcontext=system_u:object_r:dmidecode_exec_t:s0 tclass=file
type=AVC msg=audit(1457371704.867:564261): avc: denied { unlink } for
pid=4421 comm="ruby" name="preloader.4421" dev="tmpfs" ino=59232600
tcontext=system_u:object_r:var_run_t:s0 tclass=sock_file
type=AVC msg=audit(1457370663.383:563993): avc: denied { write } for
pid=2581 comm="httpd" name="request" dev="tmpfs" ino=57659158
scontext=system_u:system_r:httpd_t:s0
PuppetDB is running, passenger related bools:
getsebool -a|grep passenger
passenger_can_connect_all –> on
passenger_can_connect_docker_tcp –> on
passenger_can_connect_docker_unix –> on
passenger_can_connect_ldap –> on
passenger_can_connect_libvirt –> on
passenger_can_connect_openstack –> on
passenger_can_connect_smtp –> on
passenger_can_spawn_ssh –> on
passenger_run_foreman –> on
passenger_run_puppetmaster –> on
>> Packages to list
> --foreman-passenger-ruby-package=tfm-rubygem-passenger-native to the
>> * base: ftp.wrz.de
>> Passenger
>> extensions
>> native extensions
>> connection errors:
Hm, SELinux was already disabled at this time. Enabling SELinux
currently brakes foreman altogether as I get a HTTP/500
audit2why.txt.xz (8.28 KB)
··· On 08.03.2016 13:52, Dominic Cleal wrote: > On 07/03/16 19:00, Daniel Helgenberger wrote:
Daniel Helgenberger (helge000)
daniel@helgenberger.net
