We’ve created a custom Linux image in Azure which is visible to the user but is not seen via the Foreman UI. For example, we are able to use the public image for CentOS7.9 using the syntax OpenLogic:CentOS:7_9-gen2:latest but a custom image using the syntax Imageworks:CentOS:7_9 is not visible. We’ve also tried Imageworks:CentOS:7_9:latest.
The ability to use custom Azure images in Foreman 1.24
1.24 Foreman / Foreman Proxy
tfm-rubygem-foreman_azure_rm 2.0.8
Failed to create a compute Azure-westus2-prod (Azure Resource Manager) instance elias-wegrzyn.xxxxxxxxx.com: { “message”: “MsRestAzure::AzureOperationError: InvalidParameter: The value of parameter imageReference.version is invalid.”, “request”: { “base_uri”: “https://management.azure.com”, “path_template”: “subscriptions/{subscriptionId}/resourceGroups/{resourceGroupName}/providers/Microsoft.Compute/virtualMachines/{vmName}”, “method”: “put”, “path_params”: { “resourceGroupName”: “azr-linux-workstation-foreman”, “vmName”: “elias-wegrzyn”, “subscriptionId”: “b9d1b469-ea77-415c-beaa-75e32f204cde” }, “skip_encoding_path_params”: null, “query_params”: { “api-version”: “2019-03-01” }, “skip_encoding_query_params”: null, “headers”: { “Content-Type”: “application/json; charset=utf-8”, “Accept”: “application/json”, “accept-language”: “en-US”, “x-ms-client-request-id”: “7cda920e-2a96-4393-901b-97cb02a227ee” }, “body”: “{“location”:“westus2”,“properties”:{“hardwareProfile”:{“vmSize”:“Standard_NC12s_v3”},“storageProfile”:{“imageReference”:{“publisher”:“Imageworks”,“offer”:“CentOS”,“sku”:“7_9”},“osDisk”:{“osType”:“Linux”,“name”:“elias-wegrzyn-osdisk”,“caching”:“ReadWrite”,“createOption”:“FromImage”,“managedDisk”:{“storageAccountType”:“Standard_LRS”}}},“osProfile”:{“computerName”:“elias-wegrzyn”,“adminUsername”:“xxxx”,“adminPassword”:“xxxxxxxx”,“customData”:“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”,“linuxConfiguration”:{“disablePasswordAuthentication”:false,“ssh”:{“publicKeys”:[{“path”:”/home/guru/.ssh/authorized_keys",“keyData”:“ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDGvwaNJ4E0MeZRt834B3iS5XMod/xcAcvUo2C9gMfzJHa6ZxFLxP0e93F215p/ZpIIck64Va7g9mBir5CXkVkCgLgoSrN8DxH/S7Fwz7HAPYIngEhSn+hkAmCK7O9A2yry30+3UxAz9zBjSCUILBCf3NK8V0Q7QXs3CS1yKMNK5y7rjQjkWpgs6fARxEW8Diil29rkmKBMkAfUkvoak0SqrpWMHKDngNPUKKXxyUlX2+tJg6Dmp7DWauP0Eru6uU64vN3ppJdJAEIdpelgpMrc3CM2J4SdE7kZVUv7qaNDde6wppsg3hRRNikQAJ2MvqlXxNJXUL6NI+DLmuQ+lF9N”}]}}},“networkProfile”:{“networkInterfaces”:[{“id”:"/subscriptions/b9d1b469-ea77-415c-beaa-75e32f204cde/resourceGroups/azr-linux-workstation-foreman/providers/Microsoft.Network/networkInterfaces/elias-wegrzyn-nic0",“properties”:{“primary”:true}}]}}}", “middlewares”: [ [ “MsRest::RetryPolicyMiddleware”, { “times”: 3, “retry”: 0.02 } ], [ “cookie_jar” ] ], “log”: null }, “response”: { “body”: “{\r\n “error”: {\r\n “code”: “InvalidParameter”,\r\n “message”: “The value of parameter imageReference.version is invalid.”,\r\n “target”: “imageReference.version”\r\n }\r\n}”, “headers”: { “Cache-Control”: “no-cache”, “Pragma”: “no-cache”, “Content-Length”: “173”, “Content-Type”: “application/json; charset=utf-8”, “Expires”: “-1”, “x-ms-ratelimit-remaining-resource”: “Microsoft.Compute/PutVM3Min;712,Microsoft.Compute/PutVM30Min;3565”, “Strict-Transport-Security”: “max-age=31536000; includeSubDomains”, “x-ms-request-id”: “5b1e2621-e80e-4c6a-a7d6-61d1599cc4dc”, “Server”: “Microsoft-HTTPAPI/2.0, Microsoft-HTTPAPI/2.0”, “x-ms-ratelimit-remaining-subscription-writes”: “1199”, “x-ms-correlation-request-id”: “d33dfb96-c527-4a2a-b7e9-7a86631a7f14”, “x-ms-routing-request-id”: “WESTUS2:20210426T172231Z:d33dfb96-c527-4a2a-b7e9-7a86631a7f14”, “X-Content-Type-Options”: “nosniff”, “Date”: “Mon, 26 Apr 2021 17:22:30 GMT” }, “status”: 400 } }
Host
Virtual Machine
Operating System
Interfaces
Puppet Classes
Parameters
Additional Information
Name *
elias-wegrzyn
This value is used also as the host’s primary interface name.
Organization *
Location *
Host Group
Deploy On
Compute profile
Environment
Puppet Master
Puppet CA
