I’m trying to use foreman-ansible-modules
to populate foreman with hosts from an ansible inventory, however when using the foreman_host
ansible module it requires several attributes that are missing but I can’t see how to add them.
Using the following task as an example:
- name: "Create host"
theforeman.foreman.foreman_host:
hostgroup: "Test_hostgroup"
organization: "Default Organization"
password: PASSWORD
server_url: SERVER_ADDRESS
state: present
username: USERNAME
When I run the play, I get the following errors:
"errors": {
"architecture_id": [
"can't be blank"
"interfaces.ip": [
"can't be blank"
"interfaces.ip6": [
"can't be blank"
"interfaces.mac": [
"can't be blank"
"operatingsystem_id": [
"can't be blank"
"full_messages": [
"Mac can't be blank",
"Ip can't be blank",
"Ip6 can't be blank",
"Operatingsystem can't be blank",
"Architecture can't be blank"
However, taking interfaces
for example, there’s no mention of how to add interfaces within the foreman_host
module - foreman_host – Manage Foreman hosts — Foreman Ansible Modules documentation
I’ve tried adding an interfaces list to the host like this:
interfaces:
- ip: IP_HERE
mac: MAC_HERE
subnet: SUBNET_HERE
password: PASSWORD
state: present
username: USERNAME
But it then complains about unsupported parameters:
"Unsupported parameters for (theforeman.foreman.foreman_host) module: interfaces Supported parameters include: build, enabled, hostgroup, location, managed, name, organization, password, server_url, state, username, validate_certs"
How is this intended to work?
Any advice about an alternative method of populating foreman with a vast list of hosts/subnets/domains would also be welcomed if there is an easier/recommended method of doing this
