Using Foreman as a read-only reporting tool for Puppet
I've got PuppetDB running, but really need to provide some nice reports and
dashboards for my execs and I reckon that Foreman would do it - but I'm
quite worried about Foreman fiddling with the Puppet infrastructure. For
example, we use a role/profile system where nodes are classified with a
custom facter facts.txt file injected at the same point that the puppet
agent is installed - we can reliably predict every nodes behaviour.
I can't seem to find any definitive answers on how we can ensure it's only
reading data, not fiddling with the manifests - is that something that
might be asked here, or is there a better place?
I apologise if this is a stupid question - my exact infrastructure is a
Puppetmaster running 4.8.1 with PuppetDB installed locally, and I've
deployed a separate machine to install Foreman on and connect to Puppet
from.
> from.
Best place to look at is probably your Puppet master's puppet.conf.
Check that there is no field 'external_nodes' (normally pointint to a
script that fetches information from Foreman), only 'reports = foreman'
should be there in your case.
If this is the case already, I think you can be sure Foreman is just an
endpoint to receive reports from the Puppet master.
··· On 01/27, william.ayerst@capita.co.uk wrote:
Daniel Lobato Garcia
@dLobatog
Keybase: elobato (Daniel Lobato Garcia) | Keybase
Thank you! I will check this now.
··· On Friday, 27 January 2017 13:18:32 UTC, Daniel Lobato wrote: > > On 01/27, william...@capita.co.uk wrote: > > I've got PuppetDB running, but really need to provide some nice reports > and > > dashboards for my execs and I reckon that Foreman would do it - but I'm > > quite worried about Foreman fiddling with the Puppet infrastructure. For > > example, we use a role/profile system where nodes are classified with a > > custom facter facts.txt file injected at the same point that the puppet > > agent is installed - we can reliably predict every nodes behaviour. > > > > I can't seem to find any definitive answers on how we can ensure it's > only > > reading data, not fiddling with the manifests - is that something that > > might be asked here, or is there a better place? > > > > I apologise if this is a stupid question - my exact infrastructure is a > > Puppetmaster running 4.8.1 with PuppetDB installed locally, and I've > > deployed a separate machine to install Foreman on and connect to Puppet > > from. > > Best place to look at is probably your Puppet master's puppet.conf. > Check that there is no field 'external_nodes' (normally pointint to a > script that fetches information from Foreman), only 'reports = foreman' > should be there in your case. > > If this is the case already, I think you can be sure Foreman is just an > endpoint to receive reports from the Puppet master. > > > -- > > You received this message because you are subscribed to the Google > Groups "Foreman users" group. > > To unsubscribe from this group and stop receiving emails from it, send > an email to foreman-user...@googlegroups.com . > > To post to this group, send email to forema...@googlegroups.com > . > > Visit this group at https://groups.google.com/group/foreman-users. > > For more options, visit https://groups.google.com/d/optout. > > > -- > Daniel Lobato Garcia > > @dLobatog > blog.daniellobato.me > daniellobato.me > > GPG: http://keys.gnupg.net/pks/lookup?op=get&search=0x7A92D6DD38D6DE30 > Keybase: https://keybase.io/elobato >
