I'm using Foreman 1.12 with puppet 3.8.7
I've defined a global parameter which is a list of IP's and I would like to
use it as a value in a smart class parameter. Is this possible?
How can I reference to it? I mean if the parameter is "ips_list" I've tried
$::ips_list, but it does not work.
Excuse me if the answer is trivial.
Thanks for your help.
Frank
<%= @host.params['ips_list'] %> should work.
TemplateWriting - Foreman,
other macros on that page should also work in the context of a smart
class parameter or global parameter.
On 27/10/16 06:48, francesc bassas wrote:
> Hi,
> to use it as a value in a smart class parameter. Is this possible?
> tried $::ips_list, but it does not work.
Dominic Cleal
dominic@cleal.org
It works!!
Thanks a lot Dominic
El dijous, 27 octubre de 2016 9:08:15 UTC+2, Dominic Cleal va escriure:
> > Hi,
> http://projects.theforeman.org/projects/foreman/wiki/TemplateWriting#Host--or-Hostgroup-parameters,
> Dominic Cleal
> dom...@cleal.org
