I am trying to override a single hosts’ smartclass parameters.
For example in host foo.bar.org
I want to update a smartclass param… In this case, ‘jdk_jdkname’ which is a parameter of module ‘jdk’
Every option I find to update a single host winds up putting in a global parameter into that host, it does not override the existing param which is inherited from the jdk class.
Every option I see to do overrides wants to modify the param on the puppet class itself way upstream of where I want to change it (at the node level)
Does anyone have any idea how to accomplish this?
