Using leapp to upgrade from Rocky 8.10 to Rocky 9
Problem: leapp upgrade stuck at “The installed OS version is not supported for the in-place upgrade to the target RHEL version”
Expected outcome: leapp upgrade allowed to proceed
Foreman and Proxy versions: Foreman 3.11.1; Katello 4.13.1
Distribution and version: Rocky Linux 8.10
I’m trying to follow the directions in the “Upgrading Foreman to 3.11.1” page to use leapp to upgrade Rocky 8.10 to Rocky 9. I’m able to install everything and run “leapp preupgrade”, but the leapp-report.txt file starts with:
Risk Factor: high (inhibitor)
Title: The installed OS version is not supported for the in-place upgrade to the target RHEL version
Summary: The supported OS releases for the upgrade process:
 RHEL 8.8
RHEL 8.10
RHEL-SAPHANA 8.8
RHEL-SAPHANA 8.10
CENTOS 8.999
Key: 1c7a98849a747ec9890f04bf4321de7280970715
Is there any way around this? The doc mentions using “leapp answer” but I don’t see anything that would allow me to use “leapp answer --section” since I don’t see anything that tells me what section to give or what answer to provide.
Hi you can try edit line
/usr/share/leapp-repository/repositories/system_upgrade/common/libraries/config/version.py
'8': {'rhel': ['8.8', '8.10'], 'rhel-saphana': ['8.8', '8.10'], 'centos': ['8.999']},
to
'8': {'rhel': ['8.8', '8.10'], 'rhel-saphana': ['8.8', '8.10'], 'centos': ['8.999'], 'rocky':['8.8','8.10']},
or try alma leapp tool
Did you follow this guide? Asking because I think you missed step 3 and did not install leapp-data-rocky.
I forgot to add a patch to leapp-repository, so it doesn’t properly detect Alma and Rocky as supported source platforms.
Working on fixing it.
@evgeni Can you let us know when the problem will be solved?
I’ve released fresh leapp-upgrade-el8toel9 and leapp-data-* that should work on Alma and Rocky now.
Sorry for the oversight!
I’m able to get past the ‘leapp preupgrade’ now, but the ‘leapp upgrade’ fails because of package conflicts with some python files. Here’s a sample:
              file /usr/lib/python3.9/site-packages/__pycache__/six.cpython-39.opt-1.pyc from install of python3-six-1.15.0-9.el9.noarch conflicts with file from package python39-six-1.16.0-2.el8.noarch
              file /usr/lib/python3.9/site-packages/__pycache__/six.cpython-39.pyc from install of python3-six-1.15.0-9.el9.noarch conflicts with file from package python39-six-1.16.0-2.el8.noarch
              file /usr/lib/python3.9/site-packages/six.py from install of python3-six-1.15.0-9.el9.noarch conflicts with file from package python39-six-1.16.0-2.el8.noarch
              file /usr/lib/python3.9/site-packages/idna/__init__.py from install of python3-idna-2.10-7.el9_4.1.noarch conflicts with file from package python39-idna-3.3-2.el8.noarch
              file /usr/lib/python3.9/site-packages/idna/__pycache__/__init__.cpython-39.opt-1.pyc from install of python3-idna-2.10-7.el9_4.1.noarch conflicts with file from package python39-idna-3.3-2.el8.noarch
              file /usr/lib/python3.9/site-packages/idna/__pycache__/__init__.cpython-39.pyc from install of python3-idna-2.10-7.el9_4.1.noarch conflicts with file from package python39-idna-3.3-2.el8.noarch
Python 3.9 was used by Pulp in the past, but isn’t anymore. It should be safe to uninstall it via dnf autoremove or dnf remove python39.
if you have a problem with EFI during migration then before restart give grub2-mkconfig -o /boot/grub2/grub.cfg
Finally had a chance to try it out – dnf autoremove found a lot of stuff to uninstall, including the python39 packages. I’ll give the 8→9 upgrade another go when I have a chance and report how it goes.
I finally made the time to do this today. I was able to complete the upgrade, but afterwards, none of my systems are reporting (the “Last Report” column on the All Hosts page shows “3 Hours ago” right now for all hosts, which is when I started the upgrade. Is there something I need to do to get that working again?
I checked a few hosts and was able to run “puppet agent -t” without issue.
So your Foreman is updated (and working), your clients can do puppet agent -t, but the “last report” timestamp doesn’t update? That’s weird.
Could you provide us with some logs (especially /var/log/foreman/production.log, but a full sos report would be awesome) around the time you perform a puppet agent -t?
Feel free to DM it me here or mail to evgeni at redhat dot com if you do not want so share these publicly.
Logs sent via email. Let me know if you have any trouble accessing them from the Google Drive link I sent.
Thanks. Logs received!
production.log confirms your observation (via grep "Import.*for " production.log):
2024-09-09T12:15:11 [I|app|21133d3e] Import facts for 'testrocky9.example.com' completed. Added: 0, Updated: 4, Deleted 0 facts
2024-09-09T12:15:15 [I|app|5766a1ca] Imported report for testrocky9.example.com in 40.5 ms, status refreshed in 49.7 ms
2024-09-09T12:16:18 [I|app|88e98c91] Import facts for 'udocker1.example.com' completed. Added: 0, Updated: 8, Deleted 0 facts
2024-09-09T12:16:23 [I|app|b6bd1b26] Imported report for udocker1.example.com in 37.8 ms, status refreshed in 63.4 ms
2024-09-09T12:55:41 [I|app|8d5dd404] Import facts for 'ipam2.example.com' completed. Added: 0, Updated: 5, Deleted 0 facts
2024-09-09T12:55:52 [I|app|2dcbff95] Import facts for 'devubuntu22.example.com' completed. Added: 0, Updated: 7, Deleted 0 facts
2024-09-09T12:56:17 [I|app|2f110b5e] Import facts for 'gitlab1.example.com' completed. Added: 0, Updated: 10, Deleted 0 facts
Until 2024-09-09T12:16 we had fact and report imports in tandem (which makes sense, both are sent by the Puppetserver to Foreman – albeit by different code and at different places of the whole thing), starting with 12:55 we still see facts, but no more reports.
I guess in between 12:16 and 12:55 was the actual downtime where the upgrade happened.
Now, if we look at var/log/puppetlabs/puppetserver/puppetserver*.log* we see:
2024-09-09T12:55:53.671-07:00 ERROR [qtp1362430252-56] [puppetserver] Puppet Report processor failed: Could not send report to Foreman at https://foreman.example
.com/api/config_reports: Certificates do not conform to algorithm constraints
(and many more after this)
I must admit my Puppet reporting knowledge is a bit rusty, but I think that’s a good lead to look further.
It would be good to see the certificate. You can use openssl x509 -in /path/to/cert -noout -text to get a human readable description of it. You can find the paths in /etc/puppetlabs/puppet/foreman.yaml.
My suspicion is that it started to reject sha1 certificates.
Here it is:
[root@foreman ~]# openssl x509 -in /etc/pki/katello/puppet/puppet_client.crt -noout -text
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            62:b8:15:bd:6f:b5:26:dc:d0:bc:c7:d2:1a:17:01:3b:46:ae:c1:ef
        Signature Algorithm: sha256WithRSAEncryption
        Issuer: C = US, ST = North Carolina, L = Raleigh, O = Katello, OU = SomeOrgUnit, CN = foreman.fsautomation.com
        Validity
            Not Before: Apr 13 18:27:25 2023 GMT
            Not After : Jan 17 18:27:25 2038 GMT
        Subject: C = US, ST = North Carolina, O = FOREMAN, OU = PUPPET, CN = foreman.fsautomation.com
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
                Public-Key: (4096 bit)
                Modulus:
                    00:ba:f3:8b:ea:a9:6d:c1:64:f7:03:a5:1d:43:0d:
                    b6:65:99:c8:86:d2:0b:65:1d:cb:99:8a:4a:9a:fa:
                    64:75:92:3c:3b:85:74:5b:5a:4c:a1:3e:33:7a:ab:
                    dd:61:dd:36:8b:f4:37:de:73:2b:a5:cf:d9:b3:7f:
                    2e:3d:e9:47:f7:52:b2:62:c8:8f:c7:f3:62:ae:e4:
                    c2:d1:00:a9:2a:b1:39:7f:ee:f7:a4:48:08:d2:b3:
                    c6:8b:c4:bd:fe:a7:6c:61:f5:3b:d3:ac:93:65:bc:
                    4e:7b:58:48:67:56:a0:65:77:cd:ab:61:98:b2:10:
                    4f:59:48:aa:a4:69:f3:30:12:eb:fe:b4:c4:f8:fd:
                    c6:63:db:13:0c:7c:8a:cd:b8:25:67:7f:ba:99:9f:
                    78:f9:49:71:9b:f2:c0:95:57:cb:5e:d5:05:1e:3c:
                    ea:ad:61:f2:05:59:0b:91:b8:f6:91:9f:85:44:11:
                    53:91:86:9b:5a:e2:14:3b:84:ec:12:fd:48:31:f8:
                    6a:a9:b0:8a:93:8c:15:14:12:af:80:d4:f7:29:28:
                    a6:14:f5:4f:c6:a5:b7:61:39:a6:79:3b:d9:96:d5:
                    93:91:9e:0d:63:08:34:bc:3c:1e:1d:fa:64:bf:11:
                    d4:4b:33:c4:18:c7:eb:6a:b9:86:de:f4:b9:f7:4d:
                    03:4d:c6:12:87:e3:24:6b:fe:e5:dd:41:1b:ff:86:
                    29:45:7f:df:d8:f5:29:f1:29:cf:b5:6c:6f:fe:a3:
                    0a:43:3d:4d:10:42:ef:66:87:e4:d0:10:15:68:46:
                    3a:fa:b9:98:e2:68:fd:81:f0:23:9e:d9:f9:24:5d:
                    43:b6:b6:61:91:a6:55:c6:21:78:9b:ce:a5:3c:bd:
                    5e:80:31:2d:4a:1d:ba:e4:4e:bb:4f:e1:6f:07:1d:
                    dc:4d:c2:58:1e:5a:04:f3:40:61:99:1b:4c:2d:b2:
                    9b:8d:53:dd:18:f7:23:bc:d5:ea:70:e3:f1:d4:c2:
                    e9:c0:d9:26:47:59:b7:b4:4b:c7:ee:f8:cc:fb:be:
                    02:06:84:3c:67:3a:ea:1f:b5:7e:77:e4:72:3c:6a:
                    cc:d1:7b:00:c9:b3:39:5f:de:3a:7e:18:92:9c:df:
                    d9:3c:19:f7:a3:00:eb:21:35:23:28:03:51:13:8c:
                    08:f0:a1:14:ba:d4:58:bb:96:aa:2b:ff:f9:e0:00:
                    0f:92:a0:9b:4e:25:6e:ce:fc:3b:1c:b2:35:e5:82:
                    64:88:61:90:72:5e:a7:fc:48:95:d7:d9:07:f3:47:
                    ec:0c:fd:59:a9:2c:44:dc:95:d6:7c:47:a6:02:23:
                    13:27:0c:ee:c0:2e:a9:00:cf:cc:4c:a0:c2:b5:3e:
                    43:12:25
                Exponent: 65537 (0x10001)
        X509v3 extensions:
            X509v3 Basic Constraints:
                CA:FALSE
            X509v3 Key Usage:
                Digital Signature, Key Encipherment
            X509v3 Extended Key Usage:
                TLS Web Server Authentication, TLS Web Client Authentication
            Netscape Cert Type:
                SSL Client
            Netscape Comment:
                Katello SSL Tool Generated Certificate
            X509v3 Subject Key Identifier:
                EC:67:72:D0:48:EE:2E:A7:7C:5D:02:FD:BB:3E:A7:31:72:03:A7:C6
            X509v3 Authority Key Identifier:
                keyid:09:D2:30:01:E5:75:04:E4:D5:76:A7:EE:EA:65:8D:FA:4F:F5:CE:F0
                DirName:/C=US/ST=North Carolina/L=Raleigh/O=Katello/OU=SomeOrgUnit/CN=foreman.fsautomation.com
                serial:62:B8:15:BD:6F:B5:26:DC:D0:BC:C7:D2:1A:17:01:3B:46:AE:C1:CA
            X509v3 Subject Alternative Name:
                DNS:foreman.fsautomation.com
    Signature Value:
        20:9d:98:16:e8:a1:e0:b4:a6:57:39:b9:a6:ea:3c:78:b1:a4:
        b2:83:86:25:97:ea:d7:b2:29:e9:98:dd:4d:1e:ad:eb:17:48:
        2e:9a:09:72:0a:43:cd:7a:36:2e:26:7b:16:8f:fe:0b:0b:30:
        cf:78:c8:c7:8f:b9:ef:d7:17:89:dd:b3:7d:52:e3:e5:54:58:
        2d:83:38:63:f9:18:91:4e:fe:59:02:4d:3b:f0:1b:99:0e:ce:
        50:fd:0a:28:04:4c:c2:6b:ba:49:57:94:e6:3e:1f:b0:e3:af:
        b1:6c:d2:d4:8c:fe:f4:5b:77:e7:50:df:59:af:d8:a1:08:39:
        65:63:f5:f4:0a:0f:04:12:8e:32:56:5e:57:6b:2b:49:c5:23:
        dd:e2:1f:af:7c:09:f4:7e:09:c5:bd:50:31:05:20:0c:12:9e:
        2f:2e:ee:50:c4:6d:66:83:d8:ef:19:cd:ed:3f:68:9b:11:19:
        19:75:61:07:54:7d:4b:10:8b:3e:16:f7:8f:cd:7e:55:69:eb:
        98:57:6c:66:c5:33:78:19:e2:67:8e:7b:46:7e:d1:12:73:26:
        4a:2c:99:78:f1:f5:81:17:e0:d9:f8:e5:c6:ca:3c:f8:79:df:
        cf:c7:27:02:90:01:c2:64:b6:11:8c:b1:fe:35:3f:63:06:3d:
        45:ac:63:79:df:0a:25:4d:8f:7f:96:87:46:dd:58:6f:c8:ae:
        4f:36:72:ef:37:6a:ee:e1:a3:51:fe:ce:b3:f1:71:af:14:13:
        66:c3:e9:e1:cf:bf:93:83:ba:34:1f:c4:30:9c:ee:e0:46:6a:
        9c:c8:29:12:f5:d1:9d:6f:9d:76:85:45:93:41:7e:af:13:ef:
        b1:69:13:8b:87:dd:5f:c2:bd:bf:75:9a:c2:94:c3:6c:82:b5:
        9d:5f:eb:18:a0:5d:a3:d0:17:bc:47:0e:8f:aa:a5:1f:08:bc:
        c9:49:9d:88:21:c5:93:ed:b9:5c:56:97:7e:1a:97:79:3d:4a:
        36:5a:3e:dd:cf:dc:ec:6f:29:85:8a:72:19:f5:ee:cf:ec:9f:
        71:79:62:7b:b5:a0:d4:8e:87:c0:b5:b7:4e:e1:d5:29:7f:b1:
        06:6b:a4:92:1f:19:81:45:12:61:7e:a6:b8:de:67:a5:b1:38:
        62:e8:8a:ac:87:05:9c:e8:2e:21:c4:c4:bd:59:82:f9:0e:f4:
        32:e4:36:15:5a:06:0a:04:56:cd:12:4e:d0:ed:29:41:2e:b8:
        e8:cf:f0:f4:f1:0c:0b:f3:13:47:97:17:82:ab:cc:fc:05:df:
        28:24:2a:bc:49:77:3f:1c:57:86:25:29:ac:ce:7f:13:b9:cb:
        69:c1:f8:c0:92:70:c8:1d
That invalidates my sha1 theory.
Can you do the same for /etc/pki/katello/certs/katello-apache.crt aka /etc/pki/wildcard.example.com/certs/wildcard.example.com.crt?
And technically also /etc/pki/katello/certs/katello-server-ca.crt, which is the CA Cert who signed yours.
Here’s /etc/pki/katello/certs/katello-apache.crt:
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            02:6f:2d:59:a1:7c:b1:0e:7c:9d:89:5d:1e:ec:e9:0d
        Issuer: C = GB, ST = Greater Manchester, L = Salford, O = Sectigo Limited, CN = Sectigo RSA Domain Validation Secure Server CA
        Validity
            Not Before: Mar  1 00:00:00 2024 GMT
            Not After : Apr  1 23:59:59 2025 GMT
        Subject: CN = *.fsautomation.com
                Public-Key: (2048 bit)
                Modulus:
                    00:de:7a:ff:d1:cc:80:95:52:ea:e7:8a:b6:7f:ff:
                    1e:6e:b4:e8:35:0e:3a:0d:cf:30:b2:c2:50:83:4c:
                    0f:9e:8f:f3:d5:7b:32:96:8f:92:24:38:99:d8:13:
                    c0:08:5c:9f:f0:7d:37:93:2f:74:5c:cd:bb:95:c1:
                    0a:21:39:4d:ef:18:b4:1a:45:ba:09:3d:ac:5c:d4:
                    84:7b:27:ec:66:60:b2:7c:77:d4:83:ef:10:f4:4e:
                    c0:92:83:bd:cf:08:88:90:11:9c:18:3e:0c:44:a1:
                    dd:9f:e1:6d:f4:bc:5f:a2:55:7d:9e:36:44:c2:ad:
                    86:3f:a2:7d:a2:b5:63:bc:05:fd:00:0e:43:21:76:
                    b3:70:0f:78:8d:e2:57:19:22:54:ae:63:39:bf:3a:
                    11:c4:19:cb:77:8b:01:61:eb:56:2f:59:ed:92:3b:
                    81:6b:2e:09:f0:e9:e3:1b:00:2a:ed:e4:f3:e3:fd:
                    20:b8:23:a8:a2:4f:16:ec:b9:4b:d1:23:cc:4f:d9:
                    e3:e1:51:9c:77:39:f1:ff:9b:68:54:cb:d5:53:19:
                    81:4a:d3:c4:b8:87:3f:7c:09:01:2b:6a:8b:02:c4:
                    6d:9c:0b:be:7c:6a:eb:f1:5e:4f:f4:a7:53:d2:2d:
                    5d:57:d7:6f:63:26:06:3e:37:09:4b:1a:2a:6f:bb:
                    7a:bb
        X509v3 extensions:
                8D:8C:5E:C4:54:AD:8A:E1:77:E9:9B:F9:9B:05:E1:B8:01:8D:61:E1
                35:A6:2C:E2:BA:39:19:0F:EA:3C:99:53:61:A7:C1:AA:37:74:E4:AF
            X509v3 Key Usage: critical
            X509v3 Basic Constraints: critical
                CA:FALSE
            X509v3 Certificate Policies:
                Policy: 1.3.6.1.4.1.6449.1.2.2.7
                  CPS: https://sectigo.com/CPS
                Policy: 2.23.140.1.2.1
            Authority Information Access:
                CA Issuers - URI:http://crt.sectigo.com/SectigoRSADomainValidationSecureServerCA.crt
                OCSP - URI:http://ocsp.sectigo.com
                DNS:*.fsautomation.com, DNS:fsautomation.com
            CT Precertificate SCTs:
                Signed Certificate Timestamp:
                    Version   : v1 (0x0)
                    Log ID    : CF:11:56:EE:D5:2E:7C:AF:F3:87:5B:D9:69:2E:9B:E9:
                                1A:71:67:4A:B0:17:EC:AC:01:D2:5B:77:CE:CC:3B:08
                    Timestamp : Mar  1 22:11:52.205 2024 GMT
                    Extensions: none
                    Signature : ecdsa-with-SHA256
                                30:45:02:21:00:86:49:52:5E:C6:75:DF:AF:D8:2E:40:
                                04:C4:91:E8:BD:E7:6A:6D:C2:AF:83:D8:D7:D5:8D:5F:
                                C2:7F:20:36:09:02:20:1E:86:47:EC:74:B9:F8:1F:96:
                                EE:CF:D6:51:0B:70:02:2F:3A:D0:C7:29:5B:AC:E2:32:
                                2E:F8:0C:F8:7D:DB:C6
                    Version   : v1 (0x0)
                    Log ID    : A2:E3:0A:E4:45:EF:BD:AD:9B:7E:38:ED:47:67:77:53:
                                D7:82:5B:84:94:D7:2B:5E:1B:2C:C4:B9:50:A4:47:E7
                    Timestamp : Mar  1 22:11:52.238 2024 GMT
                    Extensions: none
                                30:44:02:20:0E:37:43:DC:12:2A:6F:B4:58:DB:E7:96:
                                3A:62:81:7A:AB:EC:8F:BE:A3:68:14:CA:55:52:73:0E:
                                68:68:E6:36:02:20:5F:B4:F1:D7:70:54:C0:09:F1:08:
                                3C:F3:0B:50:33:68:13:CF:4D:3B:86:1A:1E:76:D6:82:
                                94:57:1F:D8:D8:60
                    Version   : v1 (0x0)
                    Log ID    : 4E:75:A3:27:5C:9A:10:C3:38:5B:6C:D4:DF:3F:52:EB:
                                1D:F0:E0:8E:1B:8D:69:C0:B1:FA:64:B1:62:9A:39:DF
                    Timestamp : Mar  1 22:11:52.246 2024 GMT
                    Extensions: none
                                30:45:02:20:24:A5:AF:FB:02:36:0E:5E:C0:0B:57:EE:
                                74:B0:A8:8A:A3:0D:63:8A:86:43:FF:5A:0C:EB:C1:99:
                                54:ED:12:4C:02:21:00:B1:9C:76:CE:B7:36:A4:74:F6:
                                F6:3D:81:F2:91:98:22:EE:15:0D:38:CE:A0:DD:5B:4F:
                                53:4B:B1:53:8F:E2:D0
    Signature Value:
        0f:d5:ff:94:44:50:8d:c8:77:f4:41:e3:1c:b4:d2:65:50:d1:
        b2:c0:f3:68:4b:d2:e1:1c:37:16:fb:55:b9:42:02:37:3c:d2:
        a4:17:3b:26:0e:11:4e:63:d7:73:d4:1e:59:01:4d:66:fb:29:
        90:2b:75:07:36:c6:ef:20:94:b3:19:3b:b1:0e:7d:90:c7:72:
        f0:52:88:97:70:29:f0:a7:50:89:9e:84:1e:db:41:80:f0:d7:
        a0:d4:95:49:a2:f4:38:e5:e1:fe:a3:15:56:7d:e1:f1:1f:46:
        3f:7b:82:e6:f4:ba:49:22:15:4e:98:87:c2:b6:34:51:8f:62:
        ba:1c:48:ad:35:cc:c7:9f:d3:f5:a1:16:2f:ec:70:6c:2a:a1:
        33:9d:12:56:8c:fe:2c:76:88:87:e2:d8:1d:51:35:98:b0:53:
        01:82:a4:3d:c7:2c:9b:4e:fc:00:22:06:be:5f:99:5c:60:49:
        1c:0e:ff:9e:a7:c9:b0:91:c3:92:49:43:1c:1a:68:70:98:a2:
        44:c5:d5:de:a0:b7:ec:b1:1c:32:7e:7f:b8:48:8a:d1:bc:bb:
        a1:32:d0:50:6e:72:4a:ae:d1:60:54:c1:b8:cf:f0:25:1e:b9:
        db:54:28:bb:0e:a8:8a:c7:ef:9f:7c:58:a3:6e:3c:5a:44:8b:
        0a:cf:a9:90
and here’s /etc/pki/katello/certs/katello-server-ca.crt:
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            7d:5b:51:26:b4:76:ba:11:db:74:16:0b:bc:53:0d:a7
        Signature Algorithm: sha384WithRSAEncryption
        Issuer: C = US, ST = New Jersey, L = Jersey City, O = The USERTRUST Network, CN = USERTrust RSA Certification Authority
        Validity
            Not Before: Nov  2 00:00:00 2018 GMT
            Not After : Dec 31 23:59:59 2030 GMT
        Subject: C = GB, ST = Greater Manchester, L = Salford, O = Sectigo Limited, CN = Sectigo RSA Domain Validation Secure Server CA
                Modulus:
                    00:d6:73:33:d6:d7:3c:20:d0:00:d2:17:45:b8:d6:
                    3e:07:a2:3f:c7:41:ee:32:30:c9:b0:6c:fd:f4:9f:
                    cb:12:98:0f:2d:3f:8d:4d:01:0c:82:0f:17:7f:62:
                    2e:e9:b8:48:79:fb:16:83:4e:ad:d7:32:25:93:b7:
                    07:bf:b9:50:3f:a9:4c:c3:40:2a:e9:39:ff:d9:81:
                    ca:1f:16:32:41:da:80:26:b9:23:7a:87:20:1e:e3:
                    ff:20:9a:3c:95:44:6f:87:75:06:90:40:b4:32:93:
                    16:09:10:08:23:3e:d2:dd:87:0f:6f:5d:51:14:6a:
                    0a:69:c5:4f:01:72:69:cf:d3:93:4c:6d:04:a0:a3:
                    1b:82:7e:b1:9a:b9:ed:c5:9e:c5:37:78:9f:9a:08:
                    34:fb:56:2e:58:c4:09:0e:06:64:5b:bc:37:dc:f1:
                    9f:28:68:a8:56:b0:92:a3:5c:9f:bb:88:98:08:1b:
                    24:1d:ab:30:85:ae:af:b0:2e:9e:7a:9d:c1:c0:42:
                    1c:e2:02:f0:ea:e0:4a:d2:ef:90:0e:b4:c1:40:16:
                    f0:6f:85:42:4a:64:f7:a4:30:a0:fe:bf:2e:a3:27:
                    5a:8e:8b:58:b8:ad:c3:19:17:84:63:ed:6f:56:fd:
                    83:cb:60:34:c4:74:be:e6:9d:db:e1:e4:e5:ca:0c:
                    5f:15
        X509v3 extensions:
                53:79:BF:5A:AA:2B:4A:CF:54:80:E1:D8:9B:C0:9D:F2:B2:03:66:CB
                Digital Signature, Certificate Sign, CRL Sign
                CA:TRUE, pathlen:0
                Policy: X509v3 Any Policy
            X509v3 CRL Distribution Points:
                Full Name:
                  URI:http://crl.usertrust.com/USERTrustRSACertificationAuthority.crl
                CA Issuers - URI:http://crt.usertrust.com/USERTrustRSAAddTrustCA.crt
                OCSP - URI:http://ocsp.usertrust.com
    Signature Value:
        32:bf:61:bd:0e:48:c3:4f:c7:ba:47:4d:f8:9c:78:19:01:dc:
        13:1d:80:6f:fc:c3:70:b4:52:9a:31:33:9a:57:52:fb:31:9e:
        6b:a4:ef:54:aa:89:8d:40:17:68:f8:11:10:7c:d2:ca:b1:f1:
        55:86:c7:ee:b3:36:91:86:f6:39:51:bf:46:bf:0f:a0:ba:b4:
        f7:7e:49:c4:2a:36:17:9e:e4:68:39:7a:af:94:4e:56:6f:b2:
        7b:3b:bf:0a:86:bd:cd:c5:77:1c:03:b8:38:b1:a2:1f:5f:7e:
        db:8a:dc:46:48:b6:68:0a:cf:b2:b5:b4:e2:34:e4:67:a9:38:
        66:09:5e:d2:b8:fc:9d:28:3a:17:40:27:c2:72:4e:29:fd:21:
        3c:7c:cf:13:fb:96:2c:c5:31:44:fd:13:ed:d5:9b:a9:69:68:
        77:7c:ee:e1:ff:a4:f9:36:38:08:53:39:a2:84:34:9c:19:f3:
        be:0e:ac:d5:24:37:eb:23:a8:78:d0:d3:e7:ef:92:47:64:62:
        39:22:ef:c6:f7:11:be:22:85:c6:66:44:24:26:8e:10:32:8d:
        c8:93:ae:07:9e:83:3e:2f:d9:f9:f5:46:8e:63:be:c1:e6:b4:
        dc:a6:cd:21:a8:86:0a:95:d9:2e:85:26:1a:fd:fc:b1:b6:57:
        42:6d:95:d1:33:f6:39:14:06:82:41:38:f5:8f:58:dc:80:5b:
        a4:d5:7d:95:78:fd:a7:9b:ff:fd:c5:a8:69:ab:26:e7:a7:a4:
        05:87:5b:a9:b7:b8:a3:20:0b:97:a9:45:85:dd:b3:8b:e5:89:
        37:8e:29:0d:fc:06:17:f6:38:40:0e:42:e4:12:06:fb:7b:f3:
        c6:11:68:62:df:e3:98:f4:13:d8:15:4f:8b:b1:69:d9:10:60:
        bc:64:2a:ea:31:b7:e4:b5:a3:3a:14:9b:26:e3:0b:7b:fd:02:
        8e:b6:99:c1:38:97:59:36:f6:a8:74:a2:86:b6:5e:eb:c6:64:
        ea:cf:a0:a3:f9:6e:9e:ba:2d:11:b6:86:98:08:58:2d:c9:ac:
        25:64:f2:5e:75:b4:38:c1:ae:7f:5a:46:83:ea:51:ca:b6:f1:
        99:11:35:6b:a5:6a:7b:c6:00:b0:e7:f8:be:64:b2:ad:c8:c2:
        f1:ac:e3:51:ea:a4:93:e0:79:c8:e1:81:40:c9:0a:5b:e1:12:
        3c:c1:60:2a:e3:97:c0:89:42:ca:94:cf:46:98:12:69:bb:98:
        d0:c2:d3:0d:72:4b:47:6e:e5:93:c4:32:28:63:87:43:e4:b0:
        32:3e:0a:d3:4b:bf:23:9b:14:29:41:2b:9a:04:1f:93:2d:f1:
        c7:39:48:3c:ad:5a:12:7f
Welp, it was worth a shot. Still no SHA1 to blame.
