1. Background & problem
**Problem: Adding redhat registry, documentation missing.
Background: I want to use foreman + katello to create baselines for redhat openstack.
The documentation for using docker registry - see katello install chapter 5.8: (Foreman :: Plugin Manuals) for redhat docker registry using manifest leads to a broken link: (https://theforeman.org/plugins/katello/3.8/user_guide/red_hat_content/content.html).
I did check all versions available from 2.4 -> 3.10 but all have a broken link for this.
I have added a redhat manifest and I use that to download rhel7 + rhosp repos I need, but I cant figure out how to add the registry.
2. What I have tried so far
General information:
Using http proxy to get to internet. I believe I have this working as it should based on that I can download yum repos without issues and I have a wildcard for all redhat domains in the proxy. I installed katello with the necessary parameters for this to work.
This is what I have tried so far:
2.1. Adding the registry via Containers -> Registry -> Create Registry
Url: https://registry.access.redhat.com
Here I also tried to add the namespaces I need without any luck, but I didnt really figure out what this feature really does.
2.2. I added a new product and in there I manually created repos of type docker.
For registry URL and upstream repository I have tried a few different setups, these are a few of them:
1.
Registry URL: https://registry.access.redhat.com/
Upstream repo: rhosp13
Registry URL: https://registry.access.redhat.com/v2
I had to disable SSL verification, otherwise I got an error, I suppose this is due to the proxy:
Dec 13 17:04:37 foreman pulp: requests.packages.urllib3.connectionpool:INFO: [37149198] Starting new HTTPS connection (1): registry.access.redhat.com
Dec 13 17:04:37 foreman pulp: nectar.downloaders.threaded:ERROR: [37149198] Skipping requests to registry.access.redhat.com due to repeated connection failures: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:618)
Dec 13 17:04:37 foreman pulp: pulp.server.async.tasks:INFO: [37149198] Task failed : [37149198-f3a4-4ca0-844b-c42ef298e35a] : Could not find registry API at https://registry.access.redhat.com/v2
Dec 13 17:04:37 foreman pulp: celery.app.trace:INFO: [37149198] Task pulp.server.managers.repo.sync.sync[37149198-f3a4-4ca0-844b-c42ef298e35a] raised expected: PulpCodedException()
Dec 13 17:04:37 foreman pulp: celery.app.trace:INFO: [5dadbe94] Task pulp.server.async.tasks._release_resource[5dadbe94-48b8-4a71-bbbc-bd5517db920f] succeeded in 0.00131727400003s: None
Sync logs for 1
Dec 13 17:07:39 foreman pulp: kombu.transport.qpid:INFO: Connected to qpid with SASL mechanism ANONYMOUS
Dec 13 17:07:39 foreman pulp: celery.worker.strategy:INFO: Received task: pulp.server.async.tasks._queue_reserved_task[f80bb610-dc95-4470-8df5-dc6768cb2f51]
Dec 13 17:07:39 foreman pulp: celery.worker.strategy:INFO: Received task: pulp.server.managers.repo.sync.sync[580b125f-56e1-4edb-b3b1-b8bc1ece0c29]
Dec 13 17:07:39 foreman pulp: py.warnings:WARNING: [580b125f] (9247-17792) /usr/lib64/python2.7/site-packages/pymongo/topology.py:74: UserWarning: MongoClient opened before fork. Create MongoClient with connect=False, or create client after forking. See PyMongo's documentation for details: http://api.mongodb.org/python/current/faq.html#using-pymongo-with-multiprocessing>
Dec 13 17:07:39 foreman pulp: py.warnings:WARNING: [580b125f] (9247-17792) "MongoClient opened before fork. Create MongoClient "
Dec 13 17:07:39 foreman pulp: celery.worker.strategy:INFO: Received task: pulp.server.async.tasks._release_resource[7645df45-c804-433b-9aa9-124bd76d25ee]
Dec 13 17:07:39 foreman pulp: celery.app.trace:INFO: [f80bb610] Task pulp.server.async.tasks._queue_reserved_task[f80bb610-dc95-4470-8df5-dc6768cb2f51] succeeded in 0.01387285901s: None
Dec 13 17:07:39 foreman pulp: requests.packages.urllib3.connectionpool:INFO: [580b125f] Starting new HTTPS connection (1): registry.access.redhat.com
Dec 13 17:07:39 foreman pulp: py.warnings:WARNING: [580b125f] (9247-17792) /usr/lib/python2.7/site-packages/urllib3/connectionpool.py:769: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.org/en/latest/security.html
Dec 13 17:07:39 foreman pulp: py.warnings:WARNING: [580b125f] (9247-17792) InsecureRequestWarning)
Dec 13 17:07:40 foreman pulp: nectar.downloaders.threaded:INFO: [580b125f] Download succeeded: https://registry.access.redhat.com/v2/.
Dec 13 17:07:40 foreman pulp: nectar.downloaders.threaded:INFO: [580b125f] Download failed: Download of https://registry.access.redhat.com/v2/rhosp13/tags/list failed with code 404: Not Found
Dec 13 17:07:40 foreman pulp: pulp.server.async.tasks:INFO: [580b125f] Task failed : [580b125f-56e1-4edb-b3b1-b8bc1ece0c29] : Could not fetch repository rhosp13 from registry https://registry.access.redhat.com/ - Not Found
Dec 13 17:07:40 foreman pulp: celery.app.trace:INFO: [580b125f] Task pulp.server.managers.repo.sync.sync[580b125f-56e1-4edb-b3b1-b8bc1ece0c29] raised expected: PulpCodedException()
Dec 13 17:07:40 foreman pulp: celery.app.trace:INFO: [7645df45] Task pulp.server.async.tasks._release_resource[7645df45-c804-433b-9aa9-124bd76d25ee] succeeded in 0.00141810602508s: None
Dec 13 17:07:40 foreman pulp: pulp.server.db.connection:INFO: Attempting to connect to localhost:27017
Dec 13 17:07:41 foreman pulp: pulp.server.db.connection:INFO: Write concern for Mongo connection: {}
Sync logs for 2
Dec 13 17:09:42 foreman pulp: kombu.transport.qpid:INFO: Connected to qpid with SASL mechanism ANONYMOUS
Dec 13 17:09:43 foreman pulp: celery.worker.strategy:INFO: Received task: pulp.server.async.tasks._queue_reserved_task[dee62ac2-2d17-49b4-abc5-aca65789917d]
Dec 13 17:09:43 foreman pulp: celery.worker.strategy:INFO: Received task: pulp.server.managers.repo.sync.sync[480f748e-2ece-4ea4-aa1c-956fc76a5f2e]
Dec 13 17:09:43 foreman pulp: celery.app.trace:INFO: [dee62ac2] Task pulp.server.async.tasks._queue_reserved_task[dee62ac2-2d17-49b4-abc5-aca65789917d] succeeded in 0.0128797629732s: None
Dec 13 17:09:43 foreman pulp: celery.worker.strategy:INFO: Received task: pulp.server.async.tasks._release_resource[df5c447a-29f7-4622-8a90-840f7e4f79d1]
Dec 13 17:09:43 foreman pulp: py.warnings:WARNING: [480f748e] (9532-17792) /usr/lib64/python2.7/site-packages/pymongo/topology.py:74: UserWarning: MongoClient opened before fork. Create MongoClient with connect=False, or create client after forking. See PyMongo's documentation for details: http://api.mongodb.org/python/current/faq.html#using-pymongo-with-multiprocessing>
Dec 13 17:09:43 foreman pulp: py.warnings:WARNING: [480f748e] (9532-17792) "MongoClient opened before fork. Create MongoClient "
Dec 13 17:09:43 foreman pulp: requests.packages.urllib3.connectionpool:INFO: [480f748e] Starting new HTTPS connection (1): registry.access.redhat.com
Dec 13 17:09:43 foreman pulp: py.warnings:WARNING: [480f748e] (9532-17792) /usr/lib/python2.7/site-packages/urllib3/connectionpool.py:769: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.org/en/latest/security.html
Dec 13 17:09:43 foreman pulp: py.warnings:WARNING: [480f748e] (9532-17792) InsecureRequestWarning)
Dec 13 17:09:44 foreman pulp: nectar.downloaders.threaded:INFO: [480f748e] Download succeeded: https://registry.access.redhat.com/v2/.
Dec 13 17:09:44 foreman pulp: nectar.downloaders.threaded:INFO: [480f748e] Download failed: Download of https://registry.access.redhat.com/v2/rhosp13/tags/list failed with code 404: Not Found
Dec 13 17:09:44 foreman pulp: pulp.server.async.tasks:INFO: [480f748e] Task failed : [480f748e-2ece-4ea4-aa1c-956fc76a5f2e] : Could not fetch repository rhosp13 from registry https://registry.access.redhat.com/v2/ - Not Found
Dec 13 17:09:44 foreman pulp: celery.app.trace:INFO: [480f748e] Task pulp.server.managers.repo.sync.sync[480f748e-2ece-4ea4-aa1c-956fc76a5f2e] raised expected: PulpCodedException()
Dec 13 17:09:44 foreman pulp: celery.app.trace:INFO: [df5c447a] Task pulp.server.async.tasks._release_resource[df5c447a-29f7-4622-8a90-840f7e4f79d1] succeeded in 0.00135567400139s: None
Dec 13 17:09:45 foreman pulp: pulp.server.db.connection:INFO: Attempting to connect to localhost:27017
Dec 13 17:09:46 foreman pulp: pulp.server.db.connection:INFO: Write concern for Mongo connection: {}
I thing 1 is the closest to correct but that I am lacking something or this is completely the wrong track based on that I should use the manifest… Any help is highly appreciated.
3. Versions etc
**Expected outcome: Get it working and hopefully get the documentation corrected
**Foreman and Proxy versions: Foreman 1.19.1, Katello 3.8
