Virt-builder script for easy VM spawning
I've put together a blog post about my script called "fvb" which I use
last couple of weeks to provision VMs with Foreman core and Foretello
(Foreman w/ Katello plugin):
http://lukas.zapletalovi.com/2014/05/virt-builder-quick-provision-script.html
Check it out. Send commends, likes, patches.
··· -- Later,
Lukas “lzap” Zapletal
irc: lzap #theforeman
Lukas,
Could you expand a little more on where this fits into our infrastructure
ecosystem? Without digging too deeply, this looks like a deployment method
and I am wondering how this fits in with things like foreman-bats and
katello-deploy. I think we would be well served, and our community in turn
to converge on a recommended deployment strategy that covered our different
OSes and types (e.g. production, development).
Eric
··· On Thu, May 15, 2014 at 6:05 AM, Lukas Zapletal wrote:
I’ve put together a blog post about my script called “fvb” which I use
https://lukas.zapletalovi.com/posts/2014/virt-builder-quick-provision-script/
Later,
“foreman-dev” group.
It's just a convenient way of spawning VMs on libvirt. The main
advantage is it's zero configuration, it works out-of-box with default
libvirt configuration from Fedora. If you configure dnsmasq, you have
the benefit of DHCP/DNS and it is also compatible with virsh provider
from Foreman.
The tool works with foreman-bats or katello-deploy, it complements them.
Another advantage is I do not need to care about "templates".
Virt-builder has its own official repository with all distros we need.
Namely: CentOS, Fedora, Debian and Ubuntu.
I don't have an ambition to set a deployment standard with this. It's a
script for libvirt which gives boxes quickly, including Debian/Ubuntu
which we do support too.
··· -- Later,
