Hi all,
I’m having an issue with Foreman 1.15
We are trying to deploy CentOS6 and CentOS7 VM guests on CentOS 7 KVM hosts running libvirt x86_64 3.2.0 14.el7_4.7
The deployment process goes smooth initially, foreman shows the guest is pending installation.
When viewing the console for the guests, anaconda dies on both distributions with a similar error:
I/O error, dev vda
The host dmesg also shows the following:
[112225.395018] Buffer I/O error on dev dm-7, logical block 3145712, async page read
[112344.569672] Buffer I/O error on dev dm-7, logical block 3145712, async page read
[113245.075280] Buffer I/O error on dev dm-7, logical block 3145712, async page read
[113430.610101] Buffer I/O error on dev dm-7, logical block 3145712, async page read
[114144.567496] Buffer I/O error on dev dm-7, logical block 3145712, async page read
[115045.259332] Buffer I/O error on dev dm-7, logical block 3145712, async page read
[115230.527487] Buffer I/O error on dev dm-7, logical block 3145712, async page read
What I was expecting to happen is to be able to deploy guests to kvm hosts that are listed in foreman as compute resources.
I have been able to deploy both bus=scsi and bus=virtio on the kvm hosts manually perfectly fine without this error.
I have also been able to use Foreman to deploy to baremetal fine as well, without issue.
There is some notable difference in the options passed in the kvm commands.
This is an example if Foreman deploys:
qemu 165812 1 68 23:34 ? 00:00:06 /usr/libexec/qemu-kvm -name dev-testvm024.mynetwork.net -S -machine pc-i440fx-rhel7.0.0,accel=kvm,usb=off,dump-guest-core=off -m 2048 -realtime mlock=off -smp 2,sockets=2,cores=1,threads=1 -uuid 4ac758ab-7e9f-4b9b-be3e-e0ce04369d5a -no-user-config -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/domain-3-dev-testvm024.myne.s/monitor.sock,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=utc -no-shutdown -boot strict=on -device piix3-usb-uhci,id=usb,bus=pci.0,addr=0x1.0x2 -drive file=/dev/vms/dev-testvm024.mynetwork.net-disk1,format=raw,if=none,id=drive-virtio-disk0 -device virtio-blk-pci,scsi=off,bus=pci.0,addr=0x4,drive=drive-virtio-disk0,id=virtio-disk0,bootindex=2 -netdev tap,fd=34,id=hostnet0,vhost=on,vhostfd=36 -device virtio-net-pci,netdev=hostnet0,id=net0,mac=52:54:00:ef:a0:fb,bus=pci.0,addr=0x3,bootindex=1 -chardev pty,id=charserial0 -device isa-serial,chardev=charserial0,id=serial0 -device usb-tablet,id=input0,bus=usb.0,port=1 -vnc 0.0.0.0:0,password -vga cirrus -device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x5 -msg timestamp=on
root 165823 162331 0 23:35 pts/2 00:00:00 grep --color=auto libvirt
This is an example if I manually deploy using virt-install on the host:
qemu 56450 1 2 14:08 ? 00:14:47 /usr/libexec/qemu-kvm -name dev-foreman02.mynetwork.net -S -machine pc-i440fx-rhel7.0.0,accel=kvm,usb=off,dump-guest-core=off -cpu Broadwell,+rtm,+hle -m 8192 -realtime mlock=off -smp 4,sockets=4,cores=1,threads=1 -uuid 2f61f7e3-490c-43b2-996d-6c1f1edb3062 -no-user-config -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/domain-2-dev-foreman02.myne.s/monitor.sock,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=utc,driftfix=slew -global kvm-pit.lost_tick_policy=delay -no-hpet -no-shutdown -global PIIX4_PM.disable_s3=1 -global PIIX4_PM.disable_s4=1 -boot strict=on -device ich9-usb-ehci1,id=usb,bus=pci.0,addr=0x4.0x7 -device ich9-usb-uhci1,masterbus=usb.0,firstport=0,bus=pci.0,multifunction=on,addr=0x4 -device ich9-usb-uhci2,masterbus=usb.0,firstport=2,bus=pci.0,addr=0x4.0x1 -device ich9-usb-uhci3,masterbus=usb.0,firstport=4,bus=pci.0,addr=0x4.0x2 -device virtio-scsi-pci,id=scsi0,bus=pci.0,addr=0x5 -device virtio-serial-pci,id=virtio-serial0,bus=pci.0,addr=0x6 -drive file=/dev/vms/dev-foreman02.mynetwork.net-disk1,format=raw,if=none,id=drive-scsi0-0-0-0,cache=none,aio=native -device scsi-hd,bus=scsi0.0,channel=0,scsi-id=0,lun=0,drive=drive-scsi0-0-0-0,id=scsi0-0-0-0,bootindex=1 -netdev tap,fd=29,id=hostnet0,vhost=on,vhostfd=31 -device virtio-net-pci,netdev=hostnet0,id=net0,mac=54:52:00:0e:4d:ac,bus=pci.0,addr=0x3 -chardev pty,id=charserial0 -device isa-serial,chardev=charserial0,id=serial0 -chardev socket,id=charchannel0,path=/var/lib/libvirt/qemu/channel/target/domain-2-dev-foreman02.myne.s/org.qemu.guest_agent.0,server,nowait -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=org.qemu.guest_agent.0 -device usb-tablet,id=input0,bus=usb.0,port=1 -vnc 0.0.0.0:1,password -vga cirrus -device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x7 -msg timestamp=on
See here for the full anaconda debug output: https://pastebin.com/VAgxa88w
Any help is greatly appreciated in advance.
- Shawn
