VMware {cpu|memory} Hot Plug not correctly set
The described problem occurs in Satellite 6.15.4.1 during the creation of a VM in VMware version 8!
I have compute profiles where the “CPU Hot Add” and “Memory Hot Add” are activated.
But when I create a new vm with Satellite using the compute profile and the VMware image-template then both “{cpu|memory} Hot Plug” are disabled in VMware!
We need to power off the vm in vmware in order to enable them manual so we can add additional CPU|memory to the VM!
The VM in VMware should have been created with the “{CPU|MEMORY} Hot Add” values from the compute profile configured in Satellite!
RHEL 8.10
