VPC subnets not correct in Foreman
Hello all,
I have a VPC built with Cloud Formation with a 10.x/16 network cut up into
/26 networks for spreading out across the AZs. So x.0/26 is for 1a, x.64/26
is 1b and x.128/26 for 1c. We also have a number of /26 subnets for ELBs.
Foreman only shows 1number /26 network and that isn't even in my Cloud
Formation template, the rest of them it is showing are showing are /24 and
/27 networks and many of those start with 15.x. The correct Subnets are
showing in the AWS console.
The Foreman instance (1.3-rc3 is inside the VPC with SG rules to allow it
to pull packages and talk to the AWS api. It is new installer based and
other than templates and setting based Ohad's post is unmodified.
Has anyone seen this behaviour and help shed a light on what is happening?
Jim
Should I be raising this as a bug, because if this is reproducible it means
VPC support in Foreman-1.3 is broken?
Jim
··· On 8 October 2013 09:30, James Bailey wrote:
Hello all,
Foreman only shows 1number /26 network and that isn’t even in my Cloud
other than templates and setting based Ohad’s post is unmodified.
Jim
Yes please. I only tested it with a very simple VPC setup, so hard for
me to shed any light on it.
You could try getting information out of Fog using the Rails console
about which subnets it's aware of. Which OS are you on?
··· -- Dominic Cleal Red Hat Engineering
means VPC support in Foreman-1.3 is broken?
Jim
On 8 October 2013 09:30, James Bailey <paradoxbound@gmail.com > mailto:paradoxbound@gmail.com> wrote:
Hello all,
up into /26 networks for spreading out across the AZs. So x.0/26 is
for 1a, x.64/26 is 1b and x.128/26 for 1c. We also have a number of
/26 subnets for ELBs. Foreman only shows 1number /26 network and
that isn't even in my Cloud Formation template, the rest of them it
is showing are showing are /24 and /27 networks and many of those
start with 15.x. The correct Subnets are showing in the AWS console.
allow it to pull packages and talk to the AWS api. It is new
installer based and other than templates and setting based Ohad's
post is unmodified.
happening?
Jim
Groups “Foreman users” group.
an email to foreman-users+unsubscribe@googlegroups.com.
Running CentOS-6.4 and Foreman-1.3-rc3.
I am happy to try and get a rails console up and running and share the
output but I have never used one before, sorry more admin than dev.
However if someone can spare a few minutes to help me get going I will do
what I can.
Jim
about which subnets it’s aware of. Which OS are you on?
Dominic Cleal
Red Hat Engineering
Jim
On 8 October 2013 09:30, James Bailey <paradoxbound@gmail.com > > mailto:paradoxbound@gmail.com> wrote:
Hello all,
post is unmodified.
happening?
Jim
Sorry should have added that I am about on irc @paradoxbound
Jim
what I can.
Jim
Dominic Cleal
Red Hat Engineering
Jim
On 8 October 2013 09:30, James Bailey <paradoxbound@gmail.com >> > mailto:paradoxbound@gmail.com> wrote:
Hello all,
post is unmodified.
happening?
Jim
In that case, first install "foreman-console", then run:
cd ~foreman && sudo -u foreman scl enable ruby193 'RAILS_ENV=production
rails c'
then at the console, replacing with your compute resource name, try:
2.0.0p247 :030 > ComputeResource.find_by_name("your CR name").subnets
=> <Fog::Compute::AWS::Subnets
filters={}
It should list all of the subnet info from AWS, it'll be interesting to
compare it to what you expect to list.
do what I can.
Jim
On 8 October 2013 13:10, Dominic Cleal <dcleal@redhat.com > mailto:dcleal@redhat.com> wrote:
Dominic Cleal
Red Hat Engineering
> Jim
> On 8 October 2013 09:30, James Bailey <paradoxbound@gmail.com >     <mailto:paradoxbound@gmail.com> >     > <mailto:paradoxbound@gmail.com <mailto:paradoxbound@gmail.com>>> >     wrote:
>     Hello all,
x.0/26 is
number of
them it
console.
>     post is unmodified.
>     happening?
>     Jim
> You received this message because you are subscribed to the Google
> Groups "Foreman users" group.
<mailto:foreman-users%2Bunsubscribe@googlegroups.com>.
> To post to this group, send email to foreman-users@googlegroups.com <mailto:foreman-users@googlegroups.com>.
> Visit this group at http://groups.google.com/group/foreman-users.
send an email to foreman-users+unsubscribe@googlegroups.com
Tracked down the issue my muppetry, I was using the wrong set of AWS creds.
··· On 8 October 2013 13:50, Dominic Cleal wrote:
In that case, first install “foreman-console”, then run:
cd ~foreman && sudo -u foreman scl enable ruby193 ‘RAILS_ENV=production
rails c’
2.0.0p247 :030 > ComputeResource.find_by_name(“your CR name”).subnets
filters={}
It should list all of the subnet info from AWS, it’ll be interesting to
Dominic Cleal
Red Hat Engineering
do what I can.
Jim
On 8 October 2013 13:10, Dominic Cleal <dcleal@redhat.com > > mailto:dcleal@redhat.com> wrote:
for
Dominic Cleal
Red Hat Engineering
it
> Jim
> On 8 October 2013 09:30, James Bailey <paradoxbound@gmail.com > >     <mailto:paradoxbound@gmail.com> > >     > <mailto:paradoxbound@gmail.com <mailto:paradoxbound@gmail.com>>> > >     wrote:
>     Hello all,
cut
x.0/26 is
number of
and
them it
those
console.
to
Ohad’s
>     post is unmodified.
>     happening?
>     Jim
send
foreman-users@googlegroups.com mailto:foreman-users@googlegroups.com.
