What setting are required within foreman to use ansible callback
Problem: When using the ansible callback to report to foreman I’m receiving HTTP/403 for the client and the server reports No SSL cert with CN supplied or malformed packet The following issues are also identified
  • Turning off setting Restrict registered smart proxies causes there to be no requirement for authentication to upload to the reports endpoint. Even when headers SSL_CLIENT_VERIFY are set including SSL_CLIENT_VERIFY=FAILURE:reason
  • removing header SSL_CLIENT_CERT and only having SSL_CLIENT_S_DN and SSL_CLIENT_VERIFY has no effect, even when SSL_CLIENT_VERIFY=SUCCESS
Scouring DR Google and the forums have yielded nothing of value. Any assistance would be greatly appreciated. Bottom Line trying in integrate AWX job runs to be reported back to foreman.
Expected outcome: can use ansible callback (authenticated) to upload reports to foreman
Foreman and Proxy versions: 3.9.1
Distribution and version: Custom. Alpine linux container running on kubernetes with nginx ingress controller.
ansible.cfg
[defaults]
callback_whitelist = foreman
callbacks_enabled = foreman
[callback_foreman]
client_cert = /home/sysadmin/git/scratchpad/Certificate-Authority-Testing/certs/client2.crt
client_key = /home/sysadmin/git/scratchpad/Certificate-Authority-Testing/certs/client2.pem
url = https://< truncated >.com
report_type = foreman
verify_certs = 0
Foreman log
2024-03-09T07:44:50 [I|app|b41717a8] Started GET "/notification_recipients" for < truncated > at 2024-03-09 07:44:50 +0000
2024-03-09T07:44:50 [I|app|b41717a8] Processing by NotificationRecipientsController#index as JSON
2024-03-09T07:44:50 [D|tax|b41717a8] Current location set to none
2024-03-09T07:44:50 [D|tax|b41717a8] Current organization set to none
2024-03-09T07:44:51 [D|not|b41717a8] Cache Hit: notification, reading cache for notification-4
2024-03-09T07:44:51 [D|app|b41717a8] Body: {"notifications":[]}
2024-03-09T07:44:51 [I|app|b41717a8] Completed 200 OK in 516ms (Views: 0.3ms | ActiveRecord: 1.5ms | Allocations: 1445)
2024-03-09T07:44:53 [I|app|002eaf1b] Started POST "/api/v2/hosts/facts" for < truncated > at 2024-03-09 07:44:53 +0000
2024-03-09T07:44:53 [I|app|002eaf1b] Processing by Api::V2::HostsController#facts as JSON
2024-03-09T07:44:53 [I|app|002eaf1b] Parameters: {"name"=>"laptop2", "facts"=>"[FILTERED]", "apiv"=>"v2", "host"=>{"name"=>"laptop2"}}
2024-03-09T07:44:53 [D|app|002eaf1b] Importer DiscoveryFactImporter does not implement authorized_smart_proxy_features.
2024-03-09T07:44:53 [D|app|002eaf1b] Importer Katello::RhsmFactImporter does not implement authorized_smart_proxy_features.
2024-03-09T07:44:53 [W|app|002eaf1b] No SSL cert with CN supplied - request from < truncated >
2024-03-09T07:44:53 [D|app|002eaf1b] Rendering layout api/v2/layouts/error_layout.json.erb
2024-03-09T07:44:53 [D|app|002eaf1b] Rendering api/v2/errors/access_denied.json.rabl within api/v2/layouts/error_layout
2024-03-09T07:44:53 [I|app|002eaf1b] Rendered api/v2/errors/access_denied.json.rabl within api/v2/layouts/error_layout (Duration: 2.2ms | Allocations: 638)
2024-03-09T07:44:53 [I|app|002eaf1b] Rendered layout api/v2/layouts/error_layout.json.erb (Duration: 3.3ms | Allocations: 897)
2024-03-09T07:44:53 [I|app|002eaf1b] Filter chain halted as #<Proc:0x00007fae171ba108 /home/foreman/app/controllers/concerns/foreman/controller/smart_proxy_auth.rb:14> rendered or redirected
2024-03-09T07:44:53 [I|app|002eaf1b] Completed 403 Forbidden in 37ms (Views: 8.7ms | ActiveRecord: 13.6ms | Allocations: 3586)
2024-03-09T07:44:56 [I|app|a0101f62] Started POST "/api/v2/config_reports" for < truncated > at 2024-03-09 07:44:56 +0000
2024-03-09T07:44:56 [I|app|a0101f62] Processing by Api::V2::ConfigReportsController#create as JSON
2024-03-09T07:44:56 [I|app|a0101f62] Parameters: {"config_report"=>"[FILTERED]", "apiv"=>"v2"}
2024-03-09T07:44:56 [W|app|a0101f62] No SSL cert with CN supplied - request from < truncated >
2024-03-09T07:44:56 [D|app|a0101f62] Rendering layout api/v2/layouts/error_layout.json.erb
2024-03-09T07:44:56 [D|app|a0101f62] Rendering api/v2/errors/access_denied.json.rabl within api/v2/layouts/error_layout
2024-03-09T07:44:56 [I|app|a0101f62] Rendered api/v2/errors/access_denied.json.rabl within api/v2/layouts/error_layout (Duration: 0.7ms | Allocations: 278)
2024-03-09T07:44:56 [I|app|a0101f62] Rendered layout api/v2/layouts/error_layout.json.erb (Duration: 1.1ms | Allocations: 396)
2024-03-09T07:44:56 [I|app|a0101f62] Filter chain halted as #<Proc:0x00007fae1057b410 /home/foreman/app/controllers/concerns/foreman/controller/smart_proxy_auth.rb:14> rendered or redirected
2024-03-09T07:44:56 [I|app|a0101f62] Completed 403 Forbidden in 8ms (Views: 2.5ms | ActiveRecord: 0.5ms | Allocations: 3375)
Headers from behind the NginX Ingress
when setting proxy_set_header SSL_CLIENT_CERT $ssl_client_raw_cert the following headers are set
ssl-client-verify: SUCCESS
ssl-client-subject-dn: CN=client2,O=Internet Widgits Pty Ltd,ST=Some-State,C=AU
ssl-client-issuer-dn: emailAddress=no@reply.com,CN=Testing ONLY CA,O=Internet Widgits Pty Ltd,ST=Some-State,C=AU
X-Request-ID: 92bf4c390c528d4a1c478316c714d778
X-Real-IP: < truncated >
X-Forwarded-For: < truncated >
X-Forwarded-Host: debug.local
X-Forwarded-Port: 443
X-Forwarded-Proto: https
X-Forwarded-Scheme: https
X-Scheme: https
SSL_CLIENT_S_DN: CN=client2,O=Internet Widgits Pty Ltd,ST=Some-State,C=AU
SSL_CLIENT_VERIFY: SUCCESS
SSL_CLIENT_CERT: -----BEGIN CERTIFICATE-----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ansible.cfg
``` ini
[defaults]
[callback_foreman]
verify_certs = 0
Foreman log
X-Scheme: https
E3KNAAiW87El
-----END CERTIFICATE-----
when setting proxy_set_header SSL_CLIENT_CERT $ssl_client_escaped_cert the following headers are set
X-Request-ID: added607a8103e957745479fed0b3e4d
X-Scheme: https
SSL_CLIENT_CERT: -----BEGIN%20CERTIFICATE-----%0AMIIGBTCCA%2B2gAwIBAgIUHctJCt3jhSeOtfoOniqVOSDxeUQwDQYJKoZIhvcNAQEL%0ABQAwfDELMAkGA1UEBhMCQVUxEzARBgNVBAgMClNvbWUtU3RhdGUxITAfBgNVBAoM%0AGEludGVybmV0IFdpZGdpdHMgUHR5IEx0ZDEYMBYGA1UEAwwPVGVzdGluZyBPTkxZ%0AIENBMRswGQYJKoZIhvcNAQkBFgxub0ByZXBseS5jb20wHhcNMjQwMzA3MTU1NDIx%0AWhcNMjUwMzE3MTU1NDIxWjBXMQswCQYDVQQGEwJBVTETMBEGA1UECAwKU29tZS1T%0AdGF0ZTEhMB8GA1UECgwYSW50ZXJuZXQgV2lkZ2l0cyBQdHkgTHRkMRAwDgYDVQQD%0ADAdjbGllbnQyMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEA7RIC%2BSjw%0AO4Y95uEYcAEHdxbue6mer%2FKC6%2BPcA8Sr7zI3BnrxihAH9XDf2lX1%2BBLVSpeyalJp%0AuSPfm3w9U20fbgj6obFZD56xhT7MC915Bx6xqC4ba81ZltcXcRuaf1JCOj9r4KUa%0Aboz6flv5UC9mkr2xnUtTOUGXy%2FqFopSsUA5YTltoQDcfqF7bF1qUi8tpO8yqsXLP%0AxcT1kMBswED%2BSIY1r1B4yqeigaZxav2qvzj2M%2BEZT%2FfIE6Ui0WCMGWJUgier4XGe%0AFWm6dyKeKk0Dp0jbJ53%2B6PS5ejHOJG0oqZ%2B89EqMYmEmFXuy%2FYzbYJ9BOjdQpon6%0AgiuAM58fI9ImkQIDAQABo4IBojCCAZ4wDwYDVR0TAQH%2FBAUwAwIBADARBglghkgB%0AhvhCAQEEBAMCB4AwHQYDVR0OBBYEFDncLvrw33MLZp8PF0ZAOSfv1F0uMIG6BgNV%0AHSMEgbIwga%2BAFJkP9SMkLIe91IE6UWAt3G%2F2xNFCoYGApH4wfDELMAkGA1UEBhMC%0AQVUxEzARBgNVBAgMClNvbWUtU3RhdGUxITAfBgNVBAoMGEludGVybmV0IFdpZGdp%0AdHMgUHR5IEx0ZDEYMBYGA1UEAwwPVGVzdGluZyBPTkxZIENBMRswGQYJKoZIhvcN%0AAQkBFgxub0ByZXBseS5jb22CFDX9%2FiZqCgLU2XtnjSZn1%2Bf4TU5jMHQGCCsGAQUF%0ABwEBBGgwZjA8BggrBgEFBQcwAoYwaHR0cHM6Ly9leGFtcGxlLm15dXJsL2NhLmNy%0AdC9jZXJ0aWZpY2F0ZXMvY2EuY3J0MCYGCCsGAQUFBzABhhpodHRwczovL2V4YW1w%0AbGUubXl1cmwvb2NzcDAOBgNVHQ8BAf8EBAMCA6gwFgYDVR0lAQH%2FBAwwCgYIKwYB%0ABQUHAwIwDQYJKoZIhvcNAQELBQADggIBALhNoR9xpmMfEepzmQdYdiMiRbxEHEZw%0APU5k%2FPir1pMnVtino0TfCzX%2F%2Bk7B%2FF5IYHy%2BrwRV23reePMLx%2BgJmcTc1TpmgeNN%0AqVBEwXT6NLo8e%2FJ3OKbghuLt6L4adgdkDSsEyCutuxDCzLovm%2B5SVnEd4qLQcSDR%0ABbxPU%2B1OTx9wCHBYCWMGIsJqVWNqILu3bVZa6vJgrypV579Q05pF2vYvnXdvCMsy%0AFVJ2DNCkCxhhIPaikUcWcbIXYZ5cFiQW4XA%2BXJGItq85p6yKRdPaLUHvMRvCQhZo%0AErdnxMdu2HnsEFWgnx%2FzjilBlOmZOg8V0DCL3P9Dztn4yHxDk2DhPbuJO0dpHVnC%0AhYpvy%2BJhtHecJ0IDLUu4EQkpv9l32Tg2a84UuVgxO3l%2BDIkwdoLHt9B%2F59000ea0%0AMgAMzx6ZmGcKWJMn4Qjuz0rveyg%2F8B5IFIOzhOmawi9tx6oqCvMd02nr5bwFJHDj%0AH5vLnE5ewnR6txAUWpGvENFjiXb5OLU4r%2FDyqt9RJcS5C6nqtNvMjFtOcJcs1sbj%0AAKDVeufJm9QP2z5NhSdvtCEszwF6YCILot18E3XvTa6U35BpQ0QoIq2%2FUUc%2F453U%0AXLSQOjRg73o4nzzGFKOc4IA4By%2BSZURHSJF0W2jptgUTx%2BfNPbl0JOIM692zanfn%0AE3KNAAiW87El%0A-----END%20CERTIFICATE-----%0A
Content-Length: 864
User-Agent: python-requests/2.31.0
Accept-Encoding: gzip, deflate
Accept: */*
Content-Type: application/json
X-Scheme: https
Content-Length: 864
Accept: */*
edit:
  • fix formatting and add images
anyone?
is this a bug or have I misconfigured something?
The certificate, that the callback uses needs to be trusted by the CA, that is specified in the Foreman config file. You may mix multiple CA certificates in such pem file. You could probably reuse the Foreman’s own certificate, though that feels more like a hack. If you have default Foreman without Katello, your setup is using Puppet CA for generating certificates, so you may just generate a new one for your AWX callback. If you have katello, there’s katello-ssl-tool IIRC.
G’day Marek, thanks for taking the time to reply.
Of note from your response. All certificates are trusted and have been signed by the same CA. (OpenSSL used to create CA and subsequent certs, all with correct extensions.) The mTLS from the client works to the https reverse proxy that sits in front of foreman. The same SSL certs are used within foreman and on the reverse proxy.
I have an inkling you may have missed an important part of the OP. Being Distribution and version: Custom. Alpine linux container running on kubernetes with nginx ingress controller.
I have completely dockerized foreman. I’m using Alpine linux as the base image with foreman installed from ruby gems with node running the interface. Currently I’m testing the dockerized foreman on kubernetes. Whilst the container appears to be working well, I’m having difficulty in being able to authenticate (mTLS) the foreman proxies and the ansible foreman callback. I’ve tried using both nginx and apache as the reverse proxy for foreman. however with no luck when it comes to foreman proxy/ansible callback auth. The proxy has been setup to do the TLS termination and also pass the vars back to foreman. mTLS is successful from the reverse proxy, both apache and nginx.
If I set Restrict registered smart proxies=no this setting appears to allow unauthenticated access to the proxy API, including the ansible foreman callback.
However if I set Restrict registered smart proxies=yes authentication fails as foreman seems to be of the opinion of No SSL cert with CN supplied. this leads me to believe one of two things is occurring: I have misconfigured something or foreman does not respect/use the env vars passed from the proxy (SSL_CLIENT_VERIFY, SSL_CLIENT_CERT and SSL_CLIENT_S_DN)
I’m not a ruby or JS developer so am sort of at a loss. I did source code dive and arrived at smart_proxy_auth.rb Lines 46-63, which has lead me to believe that foreman may not be respecting/using the headers passed by the proxy. I do have the proxy sending headers X-Forwarded-Proto: https, X-Forwarded-Scheme: https and X-Scheme: https. Although I have arrived at this opinion I’m fully aware that I have no idea re the code. honestly, ruby to me looks alien.
Any assistance you may be able to offer would be appreciated.
