CentOS 7.9
Foreman 3.2
Katello 4.4
I have been building out a new system. After installing Katello I have been using hammer to script the full install of the rest of the system based on a previous Katello install. Naturally, I have made many mistakes along the way. So once I get everything scripted I would like to know if there is a simple way to wipe the system config without have to remove Katello and re-install it.
Basically, back out the config, remove all the downloaded repos …
Thanks.
