Background
More than one person has expressed an interest in utilising openscap on Debian-based foreman clients, there isn’t currently a deb based package for foreman_scap_client. If you install from gem and try to assign a policy to hostgroup from the web console then puppet will still error due to missing package before creating the config and cron files on a client and the failure will turn the client red in foreman web console.
Here’s a quick workaround that satisfies the foreman client configuration routine from puppet - uses “equivs” to create a dummy package. Policies can then be managed in the foreman console and sent out to Debian-based clients with minimum of manual configuration.
I used a test VM to create the package to not pollute any of my live machines.
Watch foreman error out when configuring openscap
Create a policy for Debian in foreman and assign to host group containing Debian client machine
On client machine to be scanned install openscap
apt install libopenscap8
perform a puppet run and see the package error
puppet agent -tv
puppet agent log showing error
Info: Using configured environment ‘production’
Info: Retrieving pluginfacts
Info: Retrieving locales
Info: Loading facts
Info: Caching catalog for myforemanclient.myfqdn.tld
Info: Applying configuration version ‘1598982269’
Error: Execution of ‘/usr/bin/apt-get -q -y -o DPkg::Options::=–force-confold install ruby-foreman-scap-client’ returned 100: Reading package lists…
Building dependency tree…
Reading state information…
E: Unable to locate package ruby-foreman-scap-client
Error: /Stage[main]/Foreman_scap_client/Package[ruby-foreman-scap-client]/ensure: change from ‘purged’ to ‘present’ failed: Execution of ‘/usr/bin/apt-get -q -y -o DPkg::Options::=–force-confold install ruby-foreman-scap-client’ returned 100: Reading package lists…
Notice: /Stage[main]/Foreman_scap_client/File[/etc/foreman_scap_client]: Dependency Package[ruby-foreman-scap-client] has failures: true
Warning: /Stage[main]/Foreman_scap_client/File[/etc/foreman_scap_client]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_scap_client/File[foreman_scap_client]: Skipping because of failed dependencies
Notice: Applied catalog in 0.36 seconds
Install from gem as workaround
gem install foreman_scap_client
perform another puppet run and see error still occurs due to missing package depedency
Build package to remediate the above
install equivs. There could be a number of dependencies installed as well.
apt install equivs
copy the below into a file called ruby-foreman-scap-client
Section: misc
Priority: optional
Standards-Version: 3.9.2
Package: ruby-foreman-scap-client
Description: Dummy package to fake ruby-foreman-scap-client installation
or use “equivs-control ruby-foreman-scap-client” to create the file then modify as above
build the package
equivs-build ruby-foreman-scap-client
If all is good then a package file ./ruby-foreman-scap-client_1.0_all.deb should be created. Install this on client.
dpkg -i ./ruby-foreman-scap-client_1.0_all.deb
Perform another puppet run, this time the output should give a success and show /etc/foreman_scap_client/config.yaml is created.
/etc/cron.d/foreman_scap_client_cron should also be created with entries accordingly.puppet agent -tv
Info: Loading facts
Info: Applying configuration version ‘1598744227’
Notice: /Stage[main]/Foreman_scap_client/File[/etc/foreman_scap_client]/ensure: created
Notice: /Stage[main]/Foreman_scap_client/File[foreman_scap_client]/ensure: defined content as ‘{md5}2f9bd05a9058bcdced978cda46e1dc9c’
Notice: Applied catalog in 0.31 seconds
- Observe scap client running correctly and ARF file uploaded to foreman server
/opt/puppetlabs/puppet/bin/foreman_scap_client 5
DEBUG: running: oscap xccdf eval --fetch-remote-resources --profile xccdf_org.ssgproject.content_profile_standard --results-arf /tmp/d20200902-10780-1fd45k2/results.xml /var/lib/openscap/content/ec2ee849161fb02a90b0410304392669fcfe5cfa7413c9ff70fba462b6280a6a.xml
DEBUG: running: /usr/bin/env bzip2 /tmp/d20200902-10780-1fd45k2/results.xml
Uploading results to https://myforemanserver.mydomain.tld:8443/compliance/arf/5
Report uploaded, report id: 13657
- View report in console
