Writing facts into comment field
Problem: A fact contains a small description of a host. Since the comment field seems to be the only existent field in Foreman that, if set, is presented on a host’s main page to describe a node, it would be wonderful to get this information out of a fact and stored in the comment.
Foreman and Proxy versions: 1.22
I’ve already learned how to write facts into host parameters. Maybe there is also an approach to do that?
I can do that for you.
Here is the patch:
Have fun
I already got 2 patches from you in the last days. Can I do that in the same way as in the past?
In this way:
cd /usr/share/foreman
wget https://github.com/theforeman/foreman/pull/7008.patch
patch -p1 < 7008.patch
systemctl restart httpd
Absolutely.
@lzap And what shall I do to write a custom fact into comment field?
Sorry what?
How does it work? Or, how do I have to setup Foreman to do that?
It does not work yet, there is a WIP patch that needs more work at the moment.
@lzap Any news on this?Does it already work in 2.0?
Fixed in 2.1
