I don't know when it started, but a lot of my systems have the wrong
IP associated with them all of a sudden.
Checking the facts on the system, it should be OK …
So in one instance system A has IP 192.168.1.124 but reporting
192.168.1.170
The system actually does have 192.168.1.124 as its IP, and the fact
reports so as well:
system A:~ # facter -p | grep -i ip
ipaddress => 192.168.1.124
ipaddress_eth0 => 192.168.1.124
But in WebUI on host page its reporting under properties the IP of
192.168.1.170
This isn't just visual. I just stumbled on this when trying to
rebuild a system, and reported that IP was already in use. I was able
to fix the IP and build, but then on another system when I tried to
manually fix it said the IP it should be for this system was in use
also!
This is affecting both managed and unmanaged systems.
Is there a way to check when this was updated to this new/bad IP so I
can try and correlate to perhaps some change that could have been
made?
Jake
So we recently implemented async_storeconfigs. Seems that the agent
system is having its IP updated to the IP of the puppetmaster filing a
report for it when this is turned on. I guess this is a bug with
puppet or how I have things configured.
Thanks!
Jake
> Checking the facts on the system, it should be OK ...
> 192.168.1.170
> reports so as well:
> 192.168.1.170
> also!
> made?
> Thanks,
> Jake
OK, so this may be a foreman issue after … not sure … let me know.
When I look at fact values, they all have the correct value for the
fact. (host = "system A" and fact ~ ip)
system A ipaddress_eth0 192.168.1.124 about 6 hours ago
system A ipaddress 192.168.1.124 about 6 hours ago
When I try to search system A for a fact with value 170 in it I get
nothing … (host = "system A" and value ~ 170)
So it seems like using async_storeconfigs is causing some value to get
changed to the puppetmaster IP, and that is causing foreman to report
the puppetmaster IP as the system IP instead of the system's IP.
Jake
> Thanks!
> Jake
> > 192.168.1.170
> > reports so as well:
> > 192.168.1.170
> > also!
> > made?
> > Thanks,
> > Jake
hmm… that is very odd, and sounds like puppet is updating the ip
address in the hosts table based on the puppetmaster ip.
this is all done behind the scenes, so foreman is not aware of this
change at all.
Ohad
On Tue, Jan 24, 2012 at 10:04 PM, jmccann wrote:
> OK, so this may be a foreman issue after ... not sure ... let me know.
> nothing ... (host = "system A" and value ~ 170)
> Thanks,
> Jake
>> Thanks!
>> Jake
>> > 192.168.1.170
>> > reports so as well:
>> > 192.168.1.170
>> > also!
>> > made?
>> > Thanks,
>> > Jake
Yea, its hosts.ip that is being updated to the wrong value. Since
foreman and puppet share the storeconfig DB I didn't know who was
setting it.
If that is managed by puppet, I will pursue this in their usergroup.
Thanks for the direction!
Jake
> > Thanks,
> > Jake
> >> Thanks!
> >> Jake
> >> > 192.168.1.170
> >> > reports so as well:
> >> > 192.168.1.170
> >> > also!
> >> > made?
> >> > Thanks,
> >> > Jake
> hmm.. that is very odd, and sounds like puppet is updating the ip
> change at all.
> Ohad
> setting it.
looking at the puppet/lib/puppet/rails/host.rb file, this seems like
where it sets the ip address / environment is simply using the wrong
object, maybe at indirector/active_record.rb
Ohad
> Jake
>> > Thanks,
>> > Jake
>> >> Thanks!
>> >> Jake
>> >> > 192.168.1.170
>> >> > reports so as well:
>> >> > 192.168.1.170
>> >> > also!
>> >> > made?
>> >> > Thanks,
>> >> > Jake
>> change at all.
>> Ohad
> To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com.
> For more options, visit this group at http://groups.google.com/group/foreman-users?hl=en.
So I've created thread http://groups.google.com/group/puppet-users/browse_thread/thread/ad55d817feef4614
on the puppet users usergroup
I'm a ruby/rails newb. I've tried taking a look at the files you are
pointing to but it doesn't make much sense to me. Would be greatly
appreciated if you posted some comments on the thread I started over
there if you think they would be useful to tracking down this issue.
Jake
> > setting it.
> Ohad
> > Jake
> >> > Thanks,
> >> > Jake
> >> >> Thanks!
> >> >> Jake
> >> >> > 192.168.1.170
> >> >> > reports so as well:
> >> >> > 192.168.1.170
> >> >> > also!
> >> >> > made?
> >> >> > Thanks,
> >> >> > Jake
> >> change at all.
> >> Ohad
> > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en.
