Good day!
I cannot add a smart-proxy to foreman
Started POST "/smart_proxies" for 192.168.10.239 at 2014-11-28 13:18:05
+0300
Processing by SmartProxiesController#create as /
Parameters: {"utf8"=>"✓",
"authenticity_token"=>"zWyVN77oHzcZSqJOAC4phPgADX6oW5wXmhdOHcBkAys=",
"smart_proxy"=>{"name"=>"puppetca.caravan.dmz",
"url"=>"https://puppetca.caravan.dmz:8443"}}
User Load (0.3ms) SELECT "users".* FROM "users" WHERE "users"."id" = $1
LIMIT 1 [["id", 3]]
Setting current user thread-local variable to admin
AuthSource Load (0.3ms) SELECT "auth_sources".* FROM "auth_sources"
WHERE "auth_sources"."id" = 1 LIMIT 1
(0.1ms) BEGIN
SmartProxy Exists (0.1ms) SELECT 1 AS one FROM "smart_proxies" WHERE
"smart_proxies"."name" = 'puppetca.caravan.dmz' LIMIT 1
SmartProxy Exists (0.2ms) SELECT 1 AS one FROM "smart_proxies" WHERE
"smart_proxies"."url" = 'https://puppetca.caravan.dmz:8443' LIMIT 1
Feature Load (0.4ms) SELECT "features".* FROM "features"
Feature Load (0.2ms) SELECT "features".* FROM "features" WHERE
"features"."name" IS NULL
(0.1ms) ROLLBACK
Failed to save:
Rendered taxonomies/_loc_org_tabs.html.erb (0.0ms)
Rendered smart_proxies/_form.html.erb (3.7ms)
Rendered smart_proxies/new.html.erb (4.2ms)
Completed 200 OK in 165ms (Views: 5.2ms | ActiveRecord: 1.6ms)
foreman=# select * from features;
id | name | created_at | updated_at
----+------------+----------------------------+---------------------------- 1 | TFTP | 2014-11-28 10:13:26.455266 | 2014-11-28 10:13:26.455266 2 | DNS | 2014-11-28 10:13:26.464241 | 2014-11-28 10:13:26.464241 3 | DHCP | 2014-11-28 10:13:26.47049 | 2014-11-28 10:13:26.47049 4 | Puppet | 2014-11-28 10:13:26.473089 | 2014-11-28 10:13:26.473089 5 | Puppet CA | 2014-11-28 10:13:26.478425 | 2014-11-28 10:13:26.478425 6 | BMC | 2014-11-28 10:13:26.480797 | 2014-11-28 10:13:26.480797 7 | Chef Proxy | 2014-11-28 10:13:26.485969 | 2014-11-28 10:13:26.485969 8 | Realm | 2014-11-28 10:13:26.488331 | 2014-11-28 10:13:26.488331 (8 rows)foreman-proxy-1.6.3-1.el6.noarch
foreman-1.6.3-1.el6.noarch
I enabled two features:
grep -v ‘#’ /etc/foreman-proxy/settings.yml
:ssl_ca_file: /var/lib/puppet/ssl/certs/ca.pem
:ssl_certificate: /var/lib/puppet/ssl/certs/puppet.caravan.dmz.pem
:ssl_private_key: /var/lib/puppet/ssl/private_keys/puppet.caravan.dmz.pem
:daemon: true
:daemon_pid: /var/run/foreman-proxy/foreman-proxy.pid
:port: 8443
:tftp: true
:tftproot: /var/lib/tftpboot/
:tftp_servername: 10.3.3.75
:dns: false
:dns_provider: nsupdate
:dns_key: /etc/rndc.key
:dns_server: 127.0.0.1
:dns_ttl: 86400
:dhcp: false
:dhcp_vendor: isc
:virsh_network: default
:puppetca: true
:ssldir: /var/lib/puppet/ssl
:puppetdir: /etc/puppet
:puppet: true
:puppet_conf: /etc/puppet/puppet.conf
:customrun_cmd: /bin/false
:customrun_args: -ay -f -s
:puppetssh_sudo: false
:puppetssh_command: /usr/bin/puppet agent --onetime --no-usecacheonfailure
:bmc: false
:bmc_default_provider: ipmitool
:realm: false
:realm_provider: freeipa
:realm_keytab: /etc/foreman-proxy/freeipa.keytab
:realm_principal: realm-proxy@EXAMPLE.COM
:freeipa_remove_dns: true
:log_file: /var/log/foreman-proxy/proxy.log
in foreman-proxy logs I observe no errors:
10.2.12.179 - - [28/Nov/2014 13:17:20] “GET /features HTTP/1.1” 200 9 0.0035
10.2.12.179 - - [28/Nov/2014 13:18:07] “GET /features HTTP/1.1” 200 9 0.0009
Thanks for help in advance)
