Sorry, just noticed you specified debug log, not regular log.
Here -
2019-06-17T01:23:33 [I|app|] Started GET "/hosts/demo4.riff.cc/review_before_build" for 10.0.2.2 at 2019-06-17 01:23:33 +0000
2019-06-17T01:23:33 [I|app|86b31] Processing by HostsController#review_before_build as */*
2019-06-17T01:23:33 [I|app|86b31] Parameters: {"id"=>"demo4.riff.cc"}
2019-06-17T01:23:33 [I|app|86b31] Current user set to admin (admin)
2019-06-17T01:23:34 [I|app|86b31] Rendering Preseed default PXELinux
2019-06-17T01:23:34 [I|blo|86b31] Unattended render of 'Preseed default PXELinux' = 'fd6a1084c9840d7f9f9ea17cbc88e6ce52dd667980051cf172a17ddb65cb2205'
2019-06-17T01:23:34 [I|app|86b31] Rendering hosts/review_before_build.html.erb
2019-06-17T01:23:34 [I|app|86b31] Rendered hosts/review_before_build.html.erb (4.0ms)
2019-06-17T01:23:34 [I|app|86b31] Completed 200 OK in 900ms (Views: 9.2ms | ActiveRecord: 67.5ms)
2019-06-17T01:23:36 [I|app|] Started PUT "/hosts/demo4.riff.cc/setBuild?auth_object=demo4.riff.cc&permission=build_hosts" for 10.0.2.2 at 2019-06-17 01:23:36 +0000
2019-06-17T01:23:36 [I|app|6524c] Processing by HostsController#setBuild as HTML
2019-06-17T01:23:36 [I|app|6524c] Parameters: {"utf8"=>"✓", "authenticity_token"=>"WjwtL0TXR/PBv6iff38GR8RvzCCHWXnYSAs4pOwxHauYNLzEDk8CNjo5pkaI+p2o6qJLUtV6/zJyBYh7Kec6qA==", "commit"=>"Build", "auth_object"=>"demo4.riff.cc", "permission"=>"build_hosts", "id"=>"demo4.riff.cc"}
2019-06-17T01:23:36 [I|app|6524c] Current user set to admin (admin)
2019-06-17T01:23:36 [D|app|6524c] Enqueued task 'Disable PuppetCA autosigning for demo4.riff.cc' to 'Host::Managed Post' queue
2019-06-17T01:23:36 [D|app|6524c] Enqueued task 'Cleanup PuppetCA certificates for demo4.riff.cc' to 'Host::Managed Post' queue
2019-06-17T01:23:36 [D|app|6524c] Enqueued task 'Enable PuppetCA autosigning for demo4.riff.cc' to 'Host::Managed Post' queue
2019-06-17T01:23:36 [I|app|] Started GET "/notification_recipients" for 10.0.2.2 at 2019-06-17 01:23:36 +0000
2019-06-17T01:23:36 [I|app|44e32] Processing by NotificationRecipientsController#index as JSON
2019-06-17T01:23:36 [I|app|44e32] Current user set to admin (admin)
2019-06-17T01:23:36 [I|app|6524c] Fetching DHCP reservation demo4.riff.cc for demo4.riff.cc-08:00:27:83:11:8f/10.21.30.48
2019-06-17T01:23:36 [D|not|44e32] Cache Hit: notification, reading cache for notification-4
2019-06-17T01:23:36 [D|app|44e32] Body: {"notifications":[{"id":34,"seen":false,"level":"info","text":"Merge time vs Change complexity in Foreman Core","created_at":"2019-06-16T06:45:44.691Z","group":"Community","actions":{"links":[{"href":"http://theforeman.org/2019/03/merge-time-review-complexity.html","title":"Open","external":true}]}},{"id":30,"seen":false,"level":"info","text":"Foreman Proxy Registration Protocol v2 explained","created_at":"2019-06-16T06:45:44.680Z","group":"Community","actions":{"links":[{"href":"http://theforeman.org/2019/04/smart-proxy-capabilities-explained.html","title":"Open","external":true}]}},{"id":26,"seen":false,"level":"info","text":"2019 Foreman Survey Analysis","created_at":"2019-06-16T06:45:44.658Z","group":"Community","actions":{"links":[{"href":"http://theforeman.org/2019/05/2019-foreman-survey-analysis.html","title":"Open","external":true}]}}]}
2019-06-17T01:23:36 [I|app|44e32] Completed 200 OK in 8ms (Views: 0.2ms | ActiveRecord: 0.4ms)
2019-06-17T01:23:36 [D|app|6524c] Detected a changed required for DHCP record
2019-06-17T01:23:36 [D|app|6524c] Enqueued task 'dhcp_remove_08:00:27:83:11:8f' to 'Host::Managed Main' queue
2019-06-17T01:23:36 [D|app|6524c] Enqueued task 'dhcp_create_08:00:27:83:11:8f' to 'Host::Managed Main' queue
2019-06-17T01:23:36 [D|app|6524c] Current organization set to none
2019-06-17T01:23:36 [D|app|6524c] Current location set to none
2019-06-17T01:23:36 [D|app|6524c] Enqueued task 'Deploy TFTP PXELinux config for demo4.riff.cc' to 'Host::Managed Main' queue
2019-06-17T01:23:36 [D|app|6524c] Enqueued task 'Deploy TFTP PXEGrub2 config for demo4.riff.cc' to 'Host::Managed Main' queue
2019-06-17T01:23:36 [D|app|6524c] Enqueued task 'Deploy TFTP PXEGrub config for demo4.riff.cc' to 'Host::Managed Main' queue
2019-06-17T01:23:36 [D|app|6524c] Enqueued task 'Deploy TFTP iPXE config for demo4.riff.cc' to 'Host::Managed Main' queue
2019-06-17T01:23:36 [D|app|6524c] Enqueued task 'Fetch TFTP boot files for demo4.riff.cc' to 'Host::Managed Main' queue
2019-06-17T01:23:36 [D|app|6524c] Processing task 'Remove DHCP Settings for demo4.riff.cc' from 'Host::Managed Main'
2019-06-17T01:23:36 [I|app|6524c] Delete DHCP reservation demo4.riff.cc for demo4.riff.cc-08:00:27:83:11:8f/10.21.30.48
2019-06-17T01:23:36 [D|app|6524c] Processing task 'Create DHCP Settings for demo4.riff.cc' from 'Host::Managed Main'
2019-06-17T01:23:36 [I|app|6524c] Create DHCP reservation demo4.riff.cc for demo4.riff.cc-08:00:27:83:11:8f/10.21.30.48
2019-06-17T01:23:36 [D|app|6524c] DHCP reservation on net 10.21.30.3 with attrs: {:hostname=>"demo4.riff.cc", :mac=>"08:00:27:83:11:8f", :ip=>"10.21.30.48", :network=>"10.21.30.3", :nextServer=>"10.21.30.3", :filename=>"pxelinux.0", :name=>"demo4.riff.cc", :related_macs=>[]}
2019-06-17T01:23:36 [W|app|6524c] Create DHCP Settings for demo4.riff.cc task failed with the following error: ERF12-6899 [ProxyAPI::ProxyException]: Unable to set DHCP entry ([RestClient::Conflict]: 409 Conflict) for proxy https://fm-master2.riff.cc:8443/dhcp
ProxyAPI::ProxyException: ERF12-6899 [ProxyAPI::ProxyException]: Unable to set DHCP entry ([RestClient::Conflict]: 409 Conflict) for proxy https://fm-master2.riff.cc:8443/dhcp
/usr/share/foreman/lib/proxy_api/dhcp.rb:89:in `rescue in set'
/usr/share/foreman/lib/proxy_api/dhcp.rb:84:in `set'
/usr/share/foreman/lib/net/dhcp/record.rb:43:in `create'
/usr/share/foreman/app/models/concerns/orchestration/dhcp.rb:57:in `block in set_dhcp'
/usr/share/foreman/app/models/concerns/orchestration/dhcp.rb:57:in `each'
/usr/share/foreman/app/models/concerns/orchestration/dhcp.rb:57:in `all?'
/usr/share/foreman/app/models/concerns/orchestration/dhcp.rb:57:in `set_dhcp'
/usr/share/foreman/app/models/concerns/orchestration.rb:222:in `execute'
/usr/share/foreman/app/models/concerns/orchestration.rb:145:in `block in process'
/usr/share/foreman/app/models/concerns/orchestration.rb:137:in `each'
/usr/share/foreman/app/models/concerns/orchestration.rb:137:in `process'
/usr/share/foreman/app/models/concerns/orchestration.rb:44:in `around_save_orchestration'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:118:in `block in run_callbacks'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:136:in `run_callbacks'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:816:in `_run_save_callbacks'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/callbacks.rb:342:in `create_or_update'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/persistence.rb:275:in `save'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/validations.rb:46:in `save'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/transactions.rb:310:in `block (2 levels) in save'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/transactions.rb:387:in `block in with_transaction_returning_status'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:254:in `block in transaction'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:239:in `block in within_new_transaction'
/usr/lib/ruby/2.5.0/monitor.rb:226:in `mon_synchronize'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:236:in `within_new_transaction'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:254:in `transaction'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/transactions.rb:212:in `transaction'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/transactions.rb:385:in `with_transaction_returning_status'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/transactions.rb:310:in `block in save'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/transactions.rb:325:in `rollback_active_record_state!'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/transactions.rb:309:in `save'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/suppressor.rb:44:in `save'
/usr/share/foreman/app/models/concerns/foreman/sti.rb:26:in `save'
/usr/share/foreman/app/models/host/managed.rb:423:in `setBuild'
/usr/share/foreman/app/controllers/hosts_controller.rb:232:in `setBuild'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/abstract_controller/base.rb:194:in `process_action'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_controller/metal/rendering.rb:30:in `process_action'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:109:in `block in run_callbacks'
/usr/share/foreman/vendor/ruby/2.5.0/gems/audited-4.8.0/lib/audited/sweeper.rb:14:in `around'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/abstract_controller/callbacks.rb:41:in `process_action'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_controller/metal/rescue.rb:22:in `process_action'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activesupport-5.2.1/lib/active_support/notifications.rb:168:in `block in instrument'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activesupport-5.2.1/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activesupport-5.2.1/lib/active_support/notifications.rb:168:in `instrument'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activerecord-5.2.1/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/abstract_controller/base.rb:134:in `process'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionview-5.2.1/lib/action_view/rendering.rb:32:in `process'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_controller/metal.rb:191:in `dispatch'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_controller/metal.rb:252:in `dispatch'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:35:in `each'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:35:in `serve'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:840:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/apipie-rails-0.5.15/lib/apipie/static_dispatcher.rb:66:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/apipie-rails-0.5.15/lib/apipie/extractor/recorder.rb:137:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/apipie-rails-0.5.15/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/rack-2.0.6/lib/rack/tempfile_reaper.rb:15:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/rack-2.0.6/lib/rack/etag.rb:25:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/rack-2.0.6/lib/rack/conditional_get.rb:38:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/rack-2.0.6/lib/rack/head.rb:12:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:232:in `context'
/usr/share/foreman/vendor/ruby/2.5.0/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:226:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:98:in `run_callbacks'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/railties-5.2.1/lib/rails/rack/logger.rb:38:in `call_app'
/usr/share/foreman/vendor/ruby/2.5.0/gems/railties-5.2.1/lib/rails/rack/logger.rb:28:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/rack-2.0.6/lib/rack/method_override.rb:22:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/rack-2.0.6/lib/rack/runtime.rb:22:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/activesupport-5.2.1/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/middleware/executor.rb:14:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/actionpack-5.2.1/lib/action_dispatch/middleware/static.rb:127:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/rack-2.0.6/lib/rack/sendfile.rb:111:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/secure_headers-6.0.0/lib/secure_headers/middleware.rb:13:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/railties-5.2.1/lib/rails/engine.rb:524:in `call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/railties-5.2.1/lib/rails/railtie.rb:190:in `public_send'
/usr/share/foreman/vendor/ruby/2.5.0/gems/railties-5.2.1/lib/rails/railtie.rb:190:in `method_missing'
/usr/share/foreman/vendor/ruby/2.5.0/gems/rack-2.0.6/lib/rack/urlmap.rb:68:in `block in call'
/usr/share/foreman/vendor/ruby/2.5.0/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `each'
/usr/share/foreman/vendor/ruby/2.5.0/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `call'
/usr/lib/ruby/vendor_ruby/phusion_passenger/rack/thread_handler_extension.rb:97:in `process_request'
/usr/lib/ruby/vendor_ruby/phusion_passenger/request_handler/thread_handler.rb:160:in `accept_and_process_next_request'
/usr/lib/ruby/vendor_ruby/phusion_passenger/request_handler/thread_handler.rb:113:in `main_loop'
/usr/lib/ruby/vendor_ruby/phusion_passenger/request_handler.rb:416:in `block (3 levels) in start_threads'
/usr/lib/ruby/vendor_ruby/phusion_passenger/utils.rb:113:in `block in create_thread_and_abort_on_exception'
/usr/share/foreman/vendor/ruby/2.5.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2019-06-17T01:23:36 [W|app|6524c] Rolling back due to a problem: [#<Orchestration::Task:0x0000563f64001a78 @name="Create DHCP Settings for demo4.riff.cc", @id="dhcp_create_08:00:27:83:11:8f", @status="failed", @priority=9, @action=[#<Nic::Managed id: 5, mac: "08:00:27:83:11:8f", ip: "10.21.30.48", type: "Nic::Managed", name: "demo4.riff.cc", host_id: 4, subnet_id: 1, domain_id: 1, attrs: {"bindings"=>[{"address"=>"10.21.30.48", "netmask"=>"255.255.254.0", "network"=>"10.21.30.0"}], "bindings6"=>[{"address"=>"fe80::a00:27ff:fe83:118f", "netmask"=>"ffff:ffff:ffff:ffff::", "network"=>"fe80::"}], "mtu"=>1500, "netmask"=>"255.255.254.0", "netmask6"=>"ffff:ffff:ffff:ffff::", "network"=>"10.21.30.0", "network6"=>"fe80::"}, created_at: "2019-06-13 08:06:34", updated_at: "2019-06-13 08:13:54", provider: nil, username: nil, password: nil, virtual: false, link: true, identifier: "enp0s3", tag: "", attached_to: "", managed: true, mode: "balance-rr", attached_devices: "", bond_options: "", primary: true, provision: true, compute_attributes: {}, ip6: nil, subnet6_id: nil>, :set_dhcp], @created=1560734616.4530327, @timestamp=2019-06-17 01:23:36 UTC>]
2019-06-17T01:23:36 [W|app|6524c] Failed to perform rollback on Remove DHCP Settings for demo4.riff.cc - ERF12-6899 [ProxyAPI::ProxyException]: Unable to set DHCP entry ([RestClient::Conflict]: 409 Conflict) for proxy https://fm-master2.riff.cc:8443/dhcp
/usr/share/foreman/app/models/concerns/orchestration.rb:192:in `block in fail_queue'
/usr/share/foreman/app/models/concerns/orchestration.rb:188:in `reverse_each'
/usr/share/foreman/app/models/concerns/orchestration.rb:188:in `fail_queue'
/usr/share/foreman/app/models/concerns/orchestration.rb:162:in `process'
2019-06-17T01:23:36 [I|app|6524c] Processed 1 tasks from queue 'Host::Managed Main', completed 0/7
2019-06-17T01:23:36 [E|app|6524c] Task 'Remove DHCP Settings for demo4.riff.cc' *rollbacked*
2019-06-17T01:23:36 [E|app|6524c] Task 'Create DHCP Settings for demo4.riff.cc' *failed*
2019-06-17T01:23:36 [E|app|6524c] Task 'Deploy TFTP PXELinux config for demo4.riff.cc' *canceled*
2019-06-17T01:23:36 [E|app|6524c] Task 'Deploy TFTP PXEGrub2 config for demo4.riff.cc' *canceled*
2019-06-17T01:23:36 [E|app|6524c] Task 'Deploy TFTP PXEGrub config for demo4.riff.cc' *canceled*
2019-06-17T01:23:36 [E|app|6524c] Task 'Deploy TFTP iPXE config for demo4.riff.cc' *canceled*
2019-06-17T01:23:36 [E|app|6524c] Task 'Fetch TFTP boot files for demo4.riff.cc' *canceled*
2019-06-17T01:23:36 [W|app|6524c] Set build failed: #<ActiveModel::Errors:0x0000563f64620030 @base=#<Host::Managed id: 4, name: "demo4.riff.cc", last_compile: nil, last_report: nil, updated_at: "2019-06-14 02:09:26", created_at: "2019-06-13 08:06:34", root_pass: "REDACTED...", architecture_id: 1, operatingsystem_id: 1, environment_id: 1, ptable_id: 103, medium_id: 10, build: true, comment: "", disk: "", installed_at: "2019-06-13 08:13:39", model_id: 1, hostgroup_id: nil, owner_id: 4, owner_type: "User", enabled: true, puppet_ca_proxy_id: 1, managed: true, use_image: nil, image_file: nil, uuid: nil, compute_resource_id: nil, puppet_proxy_id: 1, certname: "demo4.riff.cc", image_id: nil, organization_id: nil, location_id: nil, type: "Host::Managed", otp: nil, realm_id: nil, compute_profile_id: nil, provision_method: "build", grub_pass: "REDACTED...", global_status: 0, lookup_value_matcher: "fqdn=demo4.riff.cc", pxe_loader: "PXELinux BIOS", initiated_at: "2019-06-17 01:23:36", build_errors: nil>, @messages={:base=>["Create DHCP Settings for demo4.riff.cc task failed with the following error: ERF12-6899 [ProxyAPI::ProxyException]: Unable to set DHCP entry ([RestClient::Conflict]: 409 Conflict) for proxy https://fm-master2.riff.cc:8443/dhcp", "Failed to perform rollback on Remove DHCP Settings for demo4.riff.cc - ERF12-6899 [ProxyAPI::ProxyException]: Unable to set DHCP entry ([RestClient::Conflict]: 409 Conflict) for proxy https://fm-master2.riff.cc:8443/dhcp"]}, @details={:base=>[{:error=>"Create DHCP Settings for demo4.riff.cc task failed with the following error: ERF12-6899 [ProxyAPI::ProxyException]: Unable to set DHCP entry ([RestClient::Conflict]: 409 Conflict) for proxy https://fm-master2.riff.cc:8443/dhcp"}, {:error=>"Failed to perform rollback on Remove DHCP Settings for demo4.riff.cc - ERF12-6899 [ProxyAPI::ProxyException]: Unable to set DHCP entry ([RestClient::Conflict]: 409 Conflict) for proxy https://fm-master2.riff.cc:8443/dhcp"}]}>
2019-06-17T01:23:36 [E|app|6524c] Failed to save: Create DHCP Settings for demo4.riff.cc task failed with the following error: ERF12-6899 [ProxyAPI::ProxyException]: Unable to set DHCP entry ([RestClient::Conflict]: 409 Conflict) for proxy https://fm-master2.riff.cc:8443/dhcp, Failed to perform rollback on Remove DHCP Settings for demo4.riff.cc - ERF12-6899 [ProxyAPI::ProxyException]: Unable to set DHCP entry ([RestClient::Conflict]: 409 Conflict) for proxy https://fm-master2.riff.cc:8443/dhcp
2019-06-17T01:23:36 [I|app|6524c] Redirected to https://localhost:8443/hosts/demo4.riff.cc
2019-06-17T01:23:36 [I|app|6524c] Completed 302 Found in 748ms (ActiveRecord: 15.3ms)
2019-06-17T01:23:36 [I|app|] Started GET "/hosts/demo4.riff.cc" for 10.0.2.2 at 2019-06-17 01:23:36 +0000
2019-06-17T01:23:36 [I|app|d48c7] Processing by HostsController#show as HTML
2019-06-17T01:23:36 [I|app|d48c7] Parameters: {"id"=>"demo4.riff.cc"}
2019-06-17T01:23:36 [I|app|d48c7] Current user set to admin (admin)
2019-06-17T01:23:36 [I|app|d48c7] Rendering hosts/show.html.erb within layouts/application
2019-06-17T01:23:36 [I|app|d48c7] Rendered hosts/_metrics.html.erb (0.1ms)
2019-06-17T01:23:36 [I|app|d48c7] Rendered hosts/show.html.erb within layouts/application (16.3ms)
2019-06-17T01:23:36 [I|app|d48c7] Rendered layouts/_application_content.html.erb (0.3ms)
2019-06-17T01:23:36 [I|app|d48c7] Rendering layouts/base.html.erb
2019-06-17T01:23:36 [I|app|d48c7] Rendered layouts/base.html.erb (9.0ms)
2019-06-17T01:23:36 [I|app|d48c7] Completed 200 OK in 38ms (Views: 25.5ms | ActiveRecord: 3.9ms)
2019-06-17T01:23:37 [I|app|] Started GET "/notification_recipients" for 10.0.2.2 at 2019-06-17 01:23:37 +0000
2019-06-17T01:23:37 [I|app|85029] Processing by NotificationRecipientsController#index as JSON
2019-06-17T01:23:37 [I|app|85029] Current user set to admin (admin)
2019-06-17T01:23:37 [D|not|85029] Cache Hit: notification, reading cache for notification-4
2019-06-17T01:23:37 [D|app|85029] Body: {"notifications":[{"id":34,"seen":false,"level":"info","text":"Merge time vs Change complexity in Foreman Core","created_at":"2019-06-16T06:45:44.691Z","group":"Community","actions":{"links":[{"href":"http://theforeman.org/2019/03/merge-time-review-complexity.html","title":"Open","external":true}]}},{"id":30,"seen":false,"level":"info","text":"Foreman Proxy Registration Protocol v2 explained","created_at":"2019-06-16T06:45:44.680Z","group":"Community","actions":{"links":[{"href":"http://theforeman.org/2019/04/smart-proxy-capabilities-explained.html","title":"Open","external":true}]}},{"id":26,"seen":false,"level":"info","text":"2019 Foreman Survey Analysis","created_at":"2019-06-16T06:45:44.658Z","group":"Community","actions":{"links":[{"href":"http://theforeman.org/2019/05/2019-foreman-survey-analysis.html","title":"Open","external":true}]}}]}
2019-06-17T01:23:37 [I|app|85029] Completed 200 OK in 5ms (Views: 0.2ms | ActiveRecord: 0.5ms)
2019-06-17T01:23:37 [I|app|] Started GET "/hosts/demo4.riff.cc/templates" for 10.0.2.2 at 2019-06-17 01:23:37 +0000
2019-06-17T01:23:37 [I|app|] Started GET "/hosts/demo4.riff.cc/runtime?range=7" for 10.0.2.2 at 2019-06-17 01:23:37 +0000
2019-06-17T01:23:37 [I|app|] Started GET "/hosts/demo4.riff.cc/nics" for 10.0.2.2 at 2019-06-17 01:23:37 +0000
2019-06-17T01:23:37 [I|app|59163] Processing by HostsController#runtime as HTML
2019-06-17T01:23:37 [I|app|] Started GET "/hosts/demo4.riff.cc/resources?range=7" for 10.0.2.2 at 2019-06-17 01:23:37 +0000
2019-06-17T01:23:37 [I|app|14818] Processing by HostsController#nics as HTML
2019-06-17T01:23:37 [I|app|f39cb] Processing by HostsController#templates as HTML
2019-06-17T01:23:37 [I|app|] Started GET "/hosts/demo4.riff.cc/overview" for 10.0.2.2 at 2019-06-17 01:23:37 +0000
2019-06-17T01:23:37 [I|app|59163] Parameters: {"range"=>"7", "id"=>"demo4.riff.cc"}
2019-06-17T01:23:37 [I|app|14818] Parameters: {"id"=>"demo4.riff.cc"}
2019-06-17T01:23:37 [I|app|f39cb] Parameters: {"id"=>"demo4.riff.cc"}
2019-06-17T01:23:37 [I|app|14818] Current user set to admin (admin)
2019-06-17T01:23:37 [I|app|59163] Current user set to admin (admin)
2019-06-17T01:23:37 [I|app|f39cb] Current user set to admin (admin)
2019-06-17T01:23:37 [I|app|bb8fd] Processing by HostsController#overview as HTML
2019-06-17T01:23:37 [I|app|bb8fd] Parameters: {"id"=>"demo4.riff.cc"}
2019-06-17T01:23:37 [I|app|bb8fd] Current user set to admin (admin)
2019-06-17T01:23:37 [D|app|f39cb] Current organization set to none
2019-06-17T01:23:37 [D|app|f39cb] Current location set to none
2019-06-17T01:23:37 [I|app|49bb2] Processing by HostsController#resources as HTML
2019-06-17T01:23:37 [I|app|bb8fd] Rendered hosts/_overview.html.erb (88.1ms)
2019-06-17T01:23:37 [I|app|bb8fd] Completed 200 OK in 136ms (Views: 34.1ms | ActiveRecord: 82.9ms)
2019-06-17T01:23:37 [I|app|49bb2] Parameters: {"range"=>"7", "id"=>"demo4.riff.cc"}
2019-06-17T01:23:37 [I|app|59163] Rendered hosts/_runtime.html.erb (176.5ms)
2019-06-17T01:23:37 [I|app|59163] Completed 200 OK in 271ms (Views: 198.8ms | ActiveRecord: 26.6ms)
2019-06-17T01:23:37 [I|app|f39cb] Rendered hosts/_templates.html.erb (31.4ms)
2019-06-17T01:23:37 [I|app|f39cb] Completed 200 OK in 298ms (Views: 10.4ms | ActiveRecord: 137.5ms)
2019-06-17T01:23:37 [I|app|14818] Rendered hosts/_nics.html.erb (366.1ms)
2019-06-17T01:23:37 [I|app|49bb2] Current user set to admin (admin)
2019-06-17T01:23:37 [I|app|14818] Completed 200 OK in 422ms (Views: 347.0ms | ActiveRecord: 67.2ms)
2019-06-17T01:23:37 [I|app|49bb2] Rendered hosts/_resources.html.erb (19.3ms)
2019-06-17T01:23:37 [I|app|49bb2] Completed 200 OK in 348ms (Views: 19.8ms | ActiveRecord: 43.2ms)
