Error 404 from proxy when filenames between Foreman and Proxy does not match
I updated to Foreman/Katello 3.16/4.18 and it seems to have broken some of our own packages in our own repo. What I noticed was that when trying to install any of a certain type of package from any client ended with error 404, “Not Found”.
What is “special” about these packages is they the filename does not match the filename inside the rpm.**
Ex.
In our own in house repo
rpm filename**:** SSPGateway-2.7.4-el7.x86_64.rpm
$ rpm -qip SSPGateway-2.7.4-el7.x86_64.rpm
Version : 2.7.4
Release : 202210261323.el7
Architecture: x86_64
Source RPM : ssp-gateway-2.7.4-202210261323.el7.src.rpm
Hammer shows when searching the package SSPGateway-2.7.4-el7.x86_64.rpm:
ID FILENAME SOURCE RPM
6905451 SSPGateway-2.7.4-el7.x86_64.rpm ssp-gateway-2.7.4-202210261323.el7.src.rpm
Using curl to browse packages on Foreman and proxy:
# curl -s https://foreman.xxx.internal/pulp/content/xxx/Library/custom/xxxxxx_rpm/prod_el7/Packages/s/| grep -i Gateway-2.7.4
SSPGateway-2.7.4-el7.x86_64.rpm 15-Jan-2025 11:44 76.8 MB
curl -s https://fmproxy.xxx.internal/pulp/content/xxx/Library/custom/xxxxxx_rpm/prod_el7/Packages/s/| grep -i Gateway-2.7.4
ssp-gateway-2.7.4-202210261323.el7.x86_64.rpm 15-Jan-2025 11:45 76.8 MB
So far we see Foreman kept the filename of the original rpm but the proxy does not and instead using the information inside the rpm to create a filename. This has not been an issue before.
The problem is that this package are now impossible to download from the proxy by any client.
I can see dnf find the package and tries to download the filename ssp-gateway-2.7.4-202210261323.el7.x86_64.rpm but error 404.
Trying to download the package using wget fails as well with the same error. It is like there is some kind of disconnect between Foreman and the Proxy and I can not seem to understand why.
ex.
wget https:/fmproxy.xxx.internal/pulp/content/xxx/Library/custom/xxxxxx_rpm/prod_el7/Packages/s/ssp-gateway-2.7.4-202210261323.el7.x86_64.rpm
–2025-10-28 19:42:41-- https://fmproxy.xxx.internal/pulp/content/xxx/Library/custom/xxxxxx_rpm/prod_el7/Packages/s/ssp-gateway-2.7.4-202210261323.el7.x86_64.rpm
Resolving fmproxy.xxx.internal (fmproxy.xxx.internal)… 10.10.10.10
Connecting to fmproxy.xxx.internal (fmproxy.xxx.internal)|10.10.10.10|:443… connected.
HTTP request sent, awaiting response… 404 Not Found
2025-10-28 19:42:43 ERROR 404: Not Found.
Done a lot of trouble shooting, even deleted the package from Foreman, renamed the package to ssp-gateway-2.7.4-202210261323.el7.x86_64.rpm on my repo, updated the repo, resynced the repo with Foreman, package name still shows SSPGateway-2.7.4-el7.x86_64.rpm in Foreman!!! and ssp-gateway-2.7.4-202210261323.el7.x86_64.rpm on the proxy and error 404.
Also tried to reclaim unused space, ran “foreman-rake katello:delete_orphaned_content”, ran full syncs on proxies and Foreman. Also created a new repo, added the same packages to this repo, same problem!
I am a little lost on what is going on and how the even after renaming it still shows as SSPGateway-2.7.4-el7.x86_64.rpm in Foreman. Any trouble shooting tips are welcome :slight_smile:
Can add that we have 1000+ of our own packages from our own repos and I only see this issue for packages where the filename on Foreman and the Proxy is different.
I can confirm this bug. We also experienced it. The only way for us to temporarily fix it was to switch the “Mirroring Policy” to “Complete Mirroring”.
Thanks for the reply! I never thought that would be the workaround. I just tried it and I can confirm that all filenames now are the same on Forman and the proxy and no more error 404.
Actually always used “Content Only” or “Additive” for all my 100+ repos. Maybe “Complete Mirroring” is a good alternative.
There are all manner of limitations and consequences other than working around this particular bug associated with complete mirroring. With complete mirroring you are using identical metadata that the upstream repo is using. In particular this means there is no way of correcting for any idiosyncrasies in the remote upstream repo. This can be a blessing and a curse. Some features like content view filtering may not work (or work in unexpected ways).
You are of course free to try out complete mirroring, just be aware there are consequences.
Thanks for the heads up, I have only changed to “complete mirroring” towards our own repo containing our own rpm’s so hopefully we should be good. We are not using content view filtering either for this content, yet.
I think this might relate to how Pulp handles the internal artifacts & deduplication. I’m not sure if it’s a bug or more that the upstream repository did something funky that’s only savable via complete mirroring. It would be worth opening up an issue at pulp_rpm issues with details.
