As I started playing with the Dockerfile available in the Foreman repository, I’ve started to feel the pain of re-downloading the devel dependencies every time I was builds when rebuilding the image.
Therefore, I started playing with extracting the base images into separate layers that can be re-used and there is a PR that implements it. You can see more technical details there, but to wrap up the goals for this change, it’s:
- have a faster image build time (to avoid installing ruby/node/python all the time)
- have a image that can be used for development
- speed up plugin image build time by reusing a foreman published build image
- the speed-up can be leveraged both at the devel machines, as well as in CI (if rebuilding the images for specific plugin would be needed before running the tests).
As a downside, we would have additional images we need to take care of in terms of regular rebuilding.
So two questions I’m raising are:
- do others see the benefits of this change to get that in?
- in what frequency this images should be re-build?
