foreman-nightly-rpm-pipeline 1565 failed
Foreman RPM nightly pipeline failed:
https://ci.theforeman.org/job/foreman-nightly-rpm-pipeline/1565/
foreman-pipeline-foreman-nightly-centos8-stream-install (failed) (remote job)
foreman-pipeline-foreman-nightly-almalinux8-install (failed) (remote job)
foreman-pipeline-foreman-nightly-centos8-stream-upgrade (failed) (remote job)
foreman-pipeline-foreman-nightly-almalinux8-upgrade (failed) (remote job)
This is me trying to get the cicoclient setup working again. The container was updated to ansible-core which means Python 3.8 while cicoclient was installed for Python 3.6. Long term we should move to Duffy, but short term I think we can use pip3.8 install python-cicoclient. However, I don’t have a good way to test other than to make changes and try them which causes some noise.
This should have fixed it:
However, I forgot it needs to install as a user. Let’s see if this does it:
See the fully write up here:
