It is a frequent occurrence that a Foreman Task fails because the underlying Pulp Task has failed or timed out.
In such situations it is often helpful to retrieve the Pulp task for further debugging.
I am no expert on how best to achieve this as a Katello user, who is not set up for direct Pulp interactions.
If someone could share some step by step instructions how Katello users should go about retrieving Pulp task information, that would be great!
Ideally the instructions should include where to find the Pulp task ID, and how to use it to retrieve the task, including any needed authentication etc.
