If you are on pulpcore 3.14 and are not explicitly opting into the old tasking system, it is safe to delete the records in the “core_taskreservedresource” table (that is - DELETE FROM core_taskreservedresource; ), which should resolve the issue. They are leftovers from the old tasking system which for some reason have not been cleaned up properly.
@John_Beranek Did this a few days ago, he should be able to confirm.
So, this may be of interest…after running foreman-installer --foreman-proxy-content-enable-katello-agent=false the apparent memory leak in the puma process appears to have stopped.
Services have been running for a week, and look like this:
