katello-nightly-rpm-pipeline 1157 failed
https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/1157/
foreman-pipeline-katello-nightly-centos8-stream-upgrade (failed) (remote job)
foreman-pipeline-katello-nightly-centos7-upgrade (passed) (remote job)
foreman-pipeline-katello-nightly-centos7-install (passed) (remote job)
foreman-pipeline-katello-nightly-centos8-install (passed) (remote job)
foreman-pipeline-katello-nightly-centos8-stream-install (passed) (remote job)
[2021-12-05T23:09:23.347Z] e[0;31mfatal: [pipe-up-katello-nightly-centos8-stream]: FAILED! => changed=false e[0m
[2021-12-05T23:09:23.347Z] e[0;31m  failures: []e[0m
[2021-12-05T23:09:23.347Z] e[0;31m  msg: |-e[0m
[2021-12-05T23:09:23.347Z] e[0;31m    Depsolve Error occured:e[0m
[2021-12-05T23:09:23.347Z] e[0;31m     Problem 1: package python38-createrepo_c-0.17.6-4.el8.x86_64 requires createrepo_c-libs = 0.17.6-4.el8, but none of the providers can be installede[0m
[2021-12-05T23:09:23.347Z] e[0;31m      - package python38-pulp-rpm-3.16.1-1.el8.noarch requires python38-createrepo_c >= 0.17.6, but none of the providers can be installede[0m
[2021-12-05T23:09:23.347Z] e[0;31m      - cannot install both createrepo_c-libs-0.17.6-4.el8.x86_64 and createrepo_c-libs-0.17.7-3.el8.x86_64e[0m
[2021-12-05T23:09:23.347Z] e[0;31m      - cannot install the best update candidate for package python3-pulp-rpm-3.14.6-2.el8.noarche[0m
[2021-12-05T23:09:23.347Z] e[0;31m      - cannot install the best update candidate for package createrepo_c-libs-0.17.7-3.el8.x86_64e[0m
[2021-12-05T23:09:23.347Z] e[0;31m     Problem 2: problem with installed package createrepo_c-libs-0.17.7-3.el8.x86_64e[0m
[2021-12-05T23:09:23.347Z] e[0;31m      - package python38-createrepo_c-0.17.6-4.el8.x86_64 requires createrepo_c-libs = 0.17.6-4.el8, but none of the providers can be installede[0m
[2021-12-05T23:09:23.348Z] e[0;31m      - package python38-pulp-rpm-3.16.1-1.el8.noarch requires python38-createrepo_c >= 0.17.6, but none of the providers can be installede[0m
[2021-12-05T23:09:23.348Z] e[0;31m      - problem with installed package python3-pulp-rpm-3.14.6-2.el8.noarche[0m
[2021-12-05T23:09:23.348Z] e[0;31m      - package python3-pulp-rpm-3.14.6-2.el8.noarch requires python3-django-readonly-field, but none of the providers can be installede[0m
[2021-12-05T23:09:23.348Z] e[0;31m      - package python38-django-readonly-field-1.0.5-3.el8.noarch obsoletes python3-django-readonly-field < 1.0.5-3.el8 provided by python3-django-readonly-field-1.0.5-1.el8.noarche[0m
[2021-12-05T23:09:23.348Z] e[0;31m      - cannot install the best update candidate for package python3-django-readonly-field-1.0.5-1.el8.noarche[0m
[2021-12-05T23:09:23.348Z] e[0;31m  rc: 1e[0m
[2021-12-05T23:09:23.348Z] e[0;31m  results: []e[0m
Same issue as Foreman 3.1/Katello 4.3: pulpcore has newer version of createrepo_c-libs on CentOS 8 stream.
